Old 04-27-2013, 09:57 AM   #1
alexisan OP
Oddometer: 190
2006 KTM 450 - reduce throttle response?
I know it sounds like a stupid question but is there a way to smoothen the throttle response? On technical stuff that power machine is hard to handle...
alexisan is offline   Reply With Quote
Old 04-27-2013, 11:01 AM   #2
SRG
SRG
SRG's Avatar
Oddometer: 1,325
These work:
http://www.g2ergo.com/dirt-bike-g2-e...ttle-tube.html
SRG is offline   Reply With Quote
Old 04-27-2013, 01:37 PM   #3
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,421
Throttle cams work well for what you describe but I wonder if it's geared super low. That can cause the same issue, I know plenty of riders who ride 450s in technical terrain without needing the differet throttle tube.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 04-27-2013, 05:24 PM   #4
fullmonte
Reformed Kneedragger
fullmonte's Avatar
Oddometer: 5,433
If you don't have girly sized hands, install some larger grips. I like the Pro Grip 718s on all my thumpers. The pencil thin stock KTM grips suck.
"If you are looking for the typical ride to a restaurant, eat tacos, hold the middle finger over the food, stop and take a picture of a gravel road type ride, you probably won't be interested." - dlrides
"A guy I know was the lead researcher for the University of Utah federally funded study of cellphone and texting use while driving. He found that your twice as dangerous as a drunk while using your cell phone and I think it was up to six times worse if the driver was texting."-dakardad
fullmonte is offline   Reply With Quote
Old 04-27-2013, 11:29 PM   #5
alexisan OP
Oddometer: 190
13:50
Well, its is rideable of course...but I can manage slower technical stuff much better on a drz400 for example..
The 450 is hard to tame on rocky trially stuff...
Old 04-28-2013, 12:19 AM   #6
Off the grid
Seeker of the Unf
Off the grid's Avatar
Oddometer: 11,543
13:50
The throttle has 2 adjustment screws where they originate at the engine. These can be adjusted to give you more play to lower the "hit".
Also, you can actually move the cable back one notch in the pulley. (it's in the Haynes manual)
Wedding(s) = $30,000
Divorce(s) = $25,000
2009 Husky TE610 = Priceless
Off the grid is offline   Reply With Quote
Old 04-28-2013, 03:56 AM   #7
400psi
Cropdusting
400psi's Avatar
Oddometer: 518
Check if it has o ring mod done over throttle spring on carb. If so, this can be removed thus slowing the response
I'm so far behind I think I'm in first
400psi is online now   Reply With Quote
Times are GMT -7.   It's 06:05 AM.
