Old 04-27-2013, 02:55 PM   #1
bobframe OP
Oddometer: 289
Soft Bags on ('06 1200GS) Adv Rack?
I added a BMW Adventure rack and side cases to my ('06)1200GS. While the OEM boxes are nice, they have me concerned about how robust they are and I'm considering soft bag substitutes...using the existing BMW racks. I'd envision a set of waterproof bags that I could somehow strap onto the OEM Adv racks.
Anyone done this?
bobframe is offline   Reply With Quote
Old 04-27-2013, 06:11 PM   #2
LVGS
LVGS's Avatar
Oddometer: 471
Trax adpater kit + Wolfman Expedition Bags...
I have been contemplating the same question and have come up with a solution:
The Trax adpater kit uses the standard OEM GSA racks (http://www.twistedthrottle.com/trax-...-oem-sideracks) and coupled with the Wolfman bags and mounting straps( http://wolfmanluggage.com/index.cfm?...&product_id=96) could be an ideal solution.
My only uncertainty is whether there would sufficient distance from the exhaust on the left side to prevent burning the bag. I have seen heat sheilds made by other inmates that would prevent this from happening.
LVGS is online now   Reply With Quote
Old 04-27-2013, 06:56 PM   #3
Hikertrash
Oddometer: 2,778
Wolfman, Kreiga, http://www.adventure-spec.com/defaul...-panniers.html You could also upgrade to Jesse or Globescout aluminum panniers that will use your OEM GSA Adventure rack and bee 100% more robust.
Hikertrash is offline   Reply With Quote
Old 04-27-2013, 07:01 PM   #4
bobframe OP
Oddometer: 289
We're thinking alike. The exhaust side is the problem side...both from a heat issue and an irregular mounting rack issue. I'd think that as long as the bike was moving, the hot air would be blown to the rear. But summer time stop 'n go traffic could be an issue. I'd like to see a turn-key soft bag mounting solution.
Old 04-28-2013, 08:49 AM   #5
bobframe OP
Oddometer: 289
I've looked at this closely and I think it just might work. The installation instructions from Wolfman show the bags mounted fairly close to a (non-GS) exhaust pipe. Using the Trax adapter kit positions the bag about where it would be if you started with the Wolfman rack. This looks like a good approach.
The only drawback is their capacity...just 19 liters each. Current OEM boxes hold 35-40 liters...although honestly, for me, this is just a invitation to overpack.
Old 04-28-2013, 08:58 AM   #6
Tonopah
Tonopah's Avatar
Oddometer: 457
The Wolfman Rocky Mountain saddle bags hold 32 liters each. I have them on my F650GS twin and like them.
A gun is like a parachute. If you need one, and don’t have one, you’ll probably never need one again
Tonopah is offline   Reply With Quote
Old 04-28-2013, 09:21 AM   #7
bobframe OP
Oddometer: 289
Drawback...bag's not waterproof. You are given an inner liner that's waterproof. Not a fan of clothing or bags with the waterproofing coming from inner liners. Though as often as I ride in the rain, the biggest problem here is between my ears.
Old 04-28-2013, 09:40 AM   #8
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,370
Adventure Spec.
I'll be ordering a set of these soon enough.
€350 is somewhere near 450 USD, last I exchanged. Waterproof, lockable to a point, tested tough, easy to mount to any rack.
I never did like Jesses. They are tough. They are also heavy. They have never linked the arse end of the bags together well enough to keep the bottoms from caving in towards the centre of the bike. In almost every photo you can see them toeing in. Not photos of the fresh installs, the photos of the bikes that have been dropped.
I know he's a good fellow and lots of a people like them, but not for me. A 41 litre Zega is 5.5 lbs. 11 lbs for the set of panniers. Add the weight of the what is perhaps the best rack in the business and you're good to go.
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
Schlug screwed with this post 04-28-2013 at 09:45 AM
Schlug is offline   Reply With Quote
Old 04-28-2013, 10:32 AM   #9
bobframe OP
Oddometer: 289
Originally Posted by BobbySands View Post
Adventure Spec.
Price on their website is shown as $540US. http://www.adventure-spec.com/defaul...-panniers.html
Seems like a robust system...but not cheap either. Still...I paid nearly that for EACH of my OEM boxes, so maybe not so bad.
What is NOT clear (at least to me) is how exactly these would mount to myAdventure racks. Particularly on the exhaust side. Thoughts?
Old 04-28-2013, 10:49 AM   #10
bobframe OP
Oddometer: 289
Here's someone who makes a heat shield. Looking at the design tells me something about how much clearance is needed (not as much as I'd have guessed)....
http://www.giantloopmoto.com/product...gs-heat-shield
Old 04-29-2013, 10:05 AM   #11
LVGS
LVGS's Avatar
Oddometer: 471
That would do the trick, although perhaps two might be required for the GS/A
Additionally, an exhaust extender could further dissipate the heat e.g. http://www.excelcyclewerkes.com/index_files/Page612.htm
Old 05-04-2013, 05:43 PM   #12
bobframe OP
Oddometer: 289
Just ordered this combo...will review it when they arrive. Thanks for the tip...
Old 05-04-2013, 06:00 PM   #13
Hikertrash
Oddometer: 2,778
All this talk of soft bags got me thinking about using some on my CDR trip this summer. I'm really liking the Rocky Mountain saddlebags, but see where the exhaust would interfere on the GSA racks. So far I think I'll buy the Trax adaptor, but surely someone has made their own adaptor.
Old 05-04-2013, 06:49 PM   #14
kk3an
kk3an's Avatar
Oddometer: 88
bobframe - I was in the same position as you, and simply couldn't get around the fact the exhaust-side OEM mount was shaped like it was, so I replaced both sides with the stainless rack mounts that Touratech has (flat on both sides) and added a set of Magadan panniers to the GSA. Couldn't possibly be happier with these.
The weight savings I personally measured between the Jesse Odyssey boxes and the Magadans is about 19 LBS or thereabouts - Magsdans being the lighter of the two of course.
kk3an is offline   Reply With Quote
Old 05-04-2013, 07:30 PM   #15
bobframe OP
Oddometer: 289
I like what you did with AS bags...what is the Touratech mount that you refer to?
Times are GMT -7.   It's 11:54 AM.
