Old 04-27-2013, 03:00 PM   #1
frozenpeas OP
Oddometer: 28
Question Rear brake shoes R60/5
Ok, the bike is pretty, but now the fun begins. I have gear oil weeping from the rear end hole. So I figured I'd take a look at the now non existent braking from the rear. Yes, it's full of dirt and greasy substance. I wanted to remove the brake shoes, but the Clymer mention a c clip to remove, but I don't have. Can you tell me what do I remove and how, to get the brake shoes off?
Looks like the splines need service too. I'm gonna try and post a few pics. Thanks
frozenpeas screwed with this post 04-27-2013 at 03:13 PM
frozenpeas is offline   Reply With Quote
Old 04-27-2013, 04:28 PM   #2
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,478
That circlip is only on the fronts shoes. On the rears, remove the springs and they're off.
--Bill
'73 R60/5 Toaster
Old 04-27-2013, 05:24 PM   #3
frozenpeas OP
Oddometer: 28
http://i1179.photobucket.com/albums/...ps373ba560.jpg
Thanks Bill, do these splines look beat?
Old 04-27-2013, 08:20 PM   #4
Bill Harris
Oddometer: 7,478
Seen better days. Maybe 2/3 worn. Hansen can weld and remachine the splines and fix that nasty leak.
--Bill
'73 R60/5 Toaster
Old 04-28-2013, 11:23 PM   #5
Plaka
Brevis illi vita est
Oddometer: 4,588
Toast. How bad are the ones in the wheel?
One morning I wake up and I got 3 nuts. Only had 2 when I went to bed. I go to the doctor and he confirms an inguinal hernia. He says I can live with it as long as I want but avoid long trips and especially air travel.
You got splines like that.
Old 04-29-2013, 05:31 AM   #6
frozenpeas OP
Oddometer: 28
That's hysterical. What ya figure the mileage it would take to wear those suckers like that? The wheel has to be done to. Your doctor would prescribe the same limitations for the cup.
Old 04-29-2013, 06:22 AM   #7
Plaka
Oddometer: 4,588
depends on how little they were lubed and how the bike was ridden.
Old 04-29-2013, 12:24 PM   #8
Pokie
Just plain Pokie.
Pokie's Avatar
Oddometer: 892
It's easy to pop the shoes off, just jam a large flat blade screwdriver between the upper shoe and the rear drive and pry. The shoes will "fly" off so don't get your hand in the way. To put them back on, fit both springs to the shoes (while they're off), fit the bottom shoe then hook the top shoe on it's mount and lever it up. If it doesn't snap into place, you may have to make sure the shoe isn't hung up on the case (by taking a flat blade screw driver and prying out the bottom of the shoe at the pivot.
Does that make sense?
Pokie is offline   Reply With Quote
Old 04-30-2013, 06:23 PM   #9
frozenpeas OP
Oddometer: 28
sounds good to me
I think Ill do it!
Times are GMT -7.   It's 02:37 AM.
