Old 04-30-2013, 10:58 AM   #16
Plaka
Brevis illi vita est
Oddometer: 4,614
Originally Posted by boxerboy81 View Post
Are the float bowl gaskets in good condition? If not, that can contribute to poor cold starts via a leaning of the start-up mixture.
How does that work?
The bowls are fully vented to the atmosphere. As long as the gaskets are present (which sets the bowl height)....
Old 05-01-2013, 04:01 AM   #17
Lee 303
razryadka
Lee 303's Avatar
Oddometer: 69
Contrary control filled with 29 years worth of crud
Inspected and repaired as neccesary the carbs on a newly acquired 84 r80rt. Cold stalling problem resolved after I cleaned the dirt and saponified grease out the choke lever detents on the left handlebar control. Now the full setting stays locked. Whereas before you had to hold it with your thumb or it would automaticly creep back to half way and stall out. Now it'll fire right up and stays running (given enough thottle). I no doubt saved all kinds of wear and tear on the switches and relay contacts and starting motor,along with a fair amount foul language.
Lee 303 screwed with this post 05-01-2013 at 09:34 AM
Lee 303 is offline   Reply With Quote
Old 05-02-2013, 05:44 AM   #18
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,665
Originally Posted by Plaka View Post
How does that work?
If the gaskets aren't good, they can allow too much air to enter the circuit during start up and then you have difficult cold starting. Trying new gaskets and ensuring the jet in the corner of the bowl is clear might be an easy fix.
boxerboy81 is offline   Reply With Quote
Old 05-02-2013, 06:39 AM   #19
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,606
There's a loctite product that I've used on the choke cover in place of a gasket that works great. It doesn't have the tendency to get sucked in like that tiny gasket likes to do. I can't remember the specific product, but it was transparent red and called "anaerobic gasket maker" or something like that. Maybe this stuff? http://www.amazon.com/Loctite-38655-.../dp/B0002KKTTA
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 05-02-2013, 05:59 PM   #20
Plaka
Oddometer: 4,614
jet has to be clear. Air is a non issue so long as there is plenty. If the bowl vent is clear, there is plenty. You want the air pressure in the bowl to be at almospheric at all times. Fuel flow is controlled from the bowl, not air.
Old 05-03-2013, 02:56 AM   #21
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,665
If air is too much, the enrichener won't be as rich, or rich enough for the start up mixture.
I'm not talking about air from the bowl, but air from outside the bowl. If the bowl gasket is faulty and allows too much air in via the "bowl to carb body" interface, the extra air may dilute the startup mixture, then starting can be difficult.
The blue arrows bottom left in the picture above, above the fuel take up tube, show the potential pathway of air, which should be fuel...if the gasket is faulty there, it may be the problem.
boxerboy81 screwed with this post 05-03-2013 at 06:42 AM
Times are GMT -7.   It's 12:07 AM.
