Old 04-27-2013, 05:39 PM   #1
YetiGS OP
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,524
HELP: Shock Bolt Sheared Off
I was trying to remove the rear shock on my 2004 R1150GS Adventure. The bolt just kept spinning but wouldn't come out. I put a little sideways English on it and the bolt came out. Minus the threads.
Not sure if the PO put too much torque on the bolt installing it or if it sheared while riding, no idea. Either way, there is too much of the bolt left in the swingarm to remove the rear shock.
I've tried an easy out, but (I suspect) because the bolt was Locktite'd in there, it won't come out.
Does anyone have any ideas how I can get the bolt threads out of there?
Thanks in advance!!
-Scott- MotoGearGrinder.com
Semper Fi
YetiGS is offline   Reply With Quote
Old 04-27-2013, 06:26 PM   #2
erkmania
Still Adventuring
erkmania's Avatar
Oddometer: 983
That's a bummer! You might be able to use the fluted style of extractors that use drill guides. If you're lucky you will find a drill guide that will fit in the screw bore enough to help guide a drill on-center. If the guides are in between sizes then use the largest guide that will fit and wrap electrical tape or some metal shim material (a beer can come to mind) to increase the diameter of the guide until it fits snugly and centered in the bolt hole bore.
After drilling a straight hole then redrill the hole to the size of the largest flute extractor that will fit that leaves some meat. I'd probably use a flute bore of about 80% or 90% of the sheared bolt's outer diameter.
Before trying to remove the sheared bolt, do apply heat to the remainder of the bolt to release the Locktite. You may also pre-spray the remaining bolt with WD40 or some other solution to help break any corrosion that may exist. Pre-spraying with WD (or whatever you choose) does not hurt your chances of releasing the Locktite.
This kit might be useful,
http://www.amazon.com/Screw-Extracto.../dp/B006YDQ812
I hope this offers some help. Proceed methodically. You really only get one good shot at repairing this w/o removing the swingarm for some laser work.
I have faith in this technique, so good luck.
-Sticks and stones, love.
-Insurmountable problems exist in the imaginations of the less traveled.
2011 BMW R1200GS, 2004 KTM 950, 1996 ATK 605 ESDS
erkmania is offline   Reply With Quote
Old 04-28-2013, 08:11 AM   #3
YetiGS OP
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,524
I'm thinking abuot using a dremel to cut through one of the aluminum(?) spacers which holds the shock in place. That way I can get teh shock out and get better access to the broken off threads. Thoughts?
Semper Fi
Old 04-28-2013, 08:23 AM   #4
YetiGS OP
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,524
Looks like this:
I believe the threads come out about as far into the spacer as the blue line. I'm thinking of cutting the spacers where the red line is.
Semper Fi
Old 04-28-2013, 08:36 AM   #5
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,954
I'd cut the spacer on the left side to make sure you leave as much bolt/thread whatever as possible.
Old 04-28-2013, 08:48 AM   #6
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,741
If you're going to try the drill and EZout route, use a transfer punch to mark the center of the bolt for drilling. McMaster has metric transfer punches - measure the head of the broken bolt and buy that size. When you do get in there with the ezout, heat the swingarm to help soften the loctite and expand the aluminum around the bolt. I'd use a heat gun instead of a torch, the temperature can be set lower and less likely to disturb the temper of the Aluminum than a flame.
Twilight Error is offline   Reply With Quote
Old 04-28-2013, 09:33 AM   #7
YetiGS OP
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,524
I did consider that. The problem I had with the idea was that I'm not sure that'll give me enough slack to get the right side spacer to move off the threads. If I cut on the right side, it will be able to come out. Based on the length of bolt left, I'm pretty sure that cutting where I indicated won't cut any of the thread off. We'll see.
TE, thanks for the tip. I'll look into that when it comes time to remove the broken off threads. I may have a pro do that.
Semper Fi
Old 04-28-2013, 09:47 AM   #8
bdarling
Weatherman
bdarling's Avatar
Oddometer: 427
Doh! I don't have anything useful to add, but I'm sending you good juju.
Rock on with your socks on!
-B
P.S. I second the need for heat. That loctite can be pretty damn strong.
SoCal Dual Sport - http://www.socaldualsport.com
bdarling is offline   Reply With Quote
Old 04-28-2013, 09:47 AM   #9
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,954
As a pro, I'd prefer that you didn't mangle anymore...leave the shock alone and take the pro your swingarm with the shock stuck right where it is.
Old 04-28-2013, 09:56 AM   #10
biometrics
biometrics's Avatar
Oddometer: 141
+1 on the Pro
DIY is taking a chance on real risk to very Expensive repair parts. Trailer your bike to a local machine shop where they can guarantee results for a lot less than the cost of parts if you slip and screw it up. They handle this kind of issue on a regular basis and will have all the tools necessary to do it right. Just my $0.02
-John
biometrics is offline   Reply With Quote
Old 04-28-2013, 10:12 AM   #11
mfbRSV
mfbRSV's Avatar
Oddometer: 295
+1
Cut in the same area on the left as the red line is on the right.
mfbRSV is offline   Reply With Quote
Old 04-28-2013, 10:38 AM   #12
Bluecomet
What, me worry?
Bluecomet's Avatar
Oddometer: 112
Your goal was to remove the shock and seems to still be your first priority. Given the broken bolt, you may want to consider making fixing the bolt as job #1. Cutting the bolt may make the job of removal more difficult. I'd trailer it to a machine shop first, then continue with your shock project after this is fixed.
My 2 cents........
Bluecomet is offline   Reply With Quote
Old 04-28-2013, 10:38 AM   #13
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,079
How about a bushing that is a close fit in the swing arm with a hole in the center the diameter of the bolt. Use it to guide a drill bit to drill out the bolt. A lot of lubrication, a lot of pressure and very slow drill speed. You could also use a series of bushings starting with a small pilot hole. When you get near the final size, try a left hand drill. Perhaps the heat from the drilling will have softened e thread lock enough for the left hand bit to spin the remains of the bolt out. Otherwise, drill until all that remains of the bolt is a coil of threads in the swing arm.
Remove the drill from the hole and clean out the remains often. I'd use motor oil if cutting fluid isn't easy to find. I'd leave the shock in place.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 04-28-2013, 10:56 AM   #14
mike54
You don't get me
mike54's Avatar
Oddometer: 13,261
You need to contact Gillafunk. He'll know what to do.
If you're not confident with what you're doing I'd quit right now and take it to the dealership or where ever and have them deal with it. I'm sure they have experience.
Cutting to the left of that spacer would get the shock out of the way and give you room to work. There may be enough of a stub sticking out to get some vice grips on it. Heck once the weight of the shock and rear of the bike is off the bolt may come out easy. (Ever hopeful) There's not going to be much room in there for an easy out. I'd rather try to weld a nut onto the bolt and try that first. The heat from the welding should take care of any loctite in there. I've never put locktite on that bolt myself so who knows.
That bolt is under a lot of stress. I've had mine bend a few times. I discover it when I'm taking the shock out for some reason. Some guys that ride a lot harder than I do off road complain of bending that bolt a lot. Some of them even replace the bolt with something harder. I figure it's easier to deal with a banana shaped bolt than a broken one like that.
Good luck man. If everything goes south a swing arm from Beemer Boneyard is $185.
A genius is the one most like himself. - T. Monk via S. Lacy
Do stand up guys lie?
mike54 is offline   Reply With Quote
Old 04-28-2013, 10:58 AM   #15
Twilight Error
Oddometer: 22,741
-John
Better yet, pull the swingarm/shock and bring it to them. They'll be able to fixture it properly and it will cost less than if they had to dismantle the assembly themselves.
Times are GMT -7.   It's 09:00 PM.
