Old 04-27-2013, 07:41 PM   #1
Farscape OP
Oh, look! Orange koolaid!
Farscape's Avatar
Location: Kickin' stones down the road to hell - Edmond, OK
Oddometer: 553
KTM 520 exc - new sprockets/chain question
I had 14:48 112 links setup, am now going to a 14:50 setup. The chain I got has 120 links.
How many links should I use for the 14:50 setup? Is there kind of a standard/average number of links to use for 14:50?
Any advice is appreciated. I haven't had to change sprockets/chain in like ever...
-- Jody
'04 KTM 950 Adventure "Garfield" '02 KTM 520 exc-r "Hooligan Machine"
Looks like someone swung a turd covered stick through a junkyard dumpster and that's what stuck to it. - Barman
Farscape is offline   Reply With Quote
Old 04-27-2013, 07:44 PM   #2
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,901
Its a matter of putting the sprockets on and cutting the chain to fit,drape the chain over said sprockets,move the axle forward with the adjusters,make sure you dont cut the wrong link and make it too short to work.
Take your time you'll do fine.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 04-27-2013, 07:46 PM   #3
Idle
Oddometer: 719
Should be the same # of links, but it will pull the axle forward a little for two reasons.
1, the bigger rear sprocket
2, the old chain will have worn and would be longer than the new one.
Probably will only move it forward a 1/4" or so.
Idle is offline   Reply With Quote
Old 04-28-2013, 12:21 AM   #4
Off the grid
Seeker of the Unf
Off the grid's Avatar
Oddometer: 11,554
Remember to run your chain really loose. Like almost too loose. Those RFS bikes do not like a tight chain.
Wedding(s) = $30,000
Divorce(s) = $25,000
2009 Husky TE610 = Priceless
Off the grid is offline   Reply With Quote
Times are GMT -7.   It's 01:47 AM.
