Old 05-24-2013, 07:03 PM   #1
bigbadandugly OP
Oddometer: 408
How to disconnect throttle cable from handgrip
What's the best way to disconnect the throttle cable from the hand grip? I have to reroute the throttle cable under the handlebars instead of over the handlebars to accommodate my new steering damper. I've removed the one screw and the cover, but don't know if I should loosen some of the adjusters before trying to slip the cable out of the grip or what.
BigBadAndUgly
Current: 2012 R1200GS
Past: 2009 Moto Guzzi Stelvio, 1979 Suzuki GS750L, XR350R, DT125, CT70
Dyno testing of a PC-V + Full Akropovic system on an R1200GS
bigbadandugly is offline   Reply With Quote
Old 05-24-2013, 07:09 PM   #2
jdub
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,825
If your 2012 cable is like the one on my 2007, there should be an adjuster a couple of inches from the grip. If you loosen that it'll give enough slack to remove the cable end from the grip.
Current: 2014 R1200GSW
jdub is offline   Reply With Quote
Old 05-24-2013, 07:11 PM   #3
LaurelPerryOnLand
Oddometer: 3,480
100 THREADS all GS/GSA owners should read.
http://advrider.com/forums/showthread.php?t=836736
42. HOW DO I INSTALL THOSE ROX RISERS ON MY BIKE?
http://advrider.com/forums/showthread.php?t=347359 (Re-routing the throttle cable...afterwards)
LaurelPerryOnLand is offline   Reply With Quote
Old 05-24-2013, 08:20 PM   #4
bigbadandugly OP
Oddometer: 408
Yep, that's the trick. Nice too see that once you twist the grip it reveals a little slot to get a pick (or a cotter pin puller in my case) under the cable to create the necessary slack to remove the cable.
The throttle cable has been successfully rerouted under the handlebar and no longer catches on the steering damper. All's well now!
BigBadAndUgly
Times are GMT -7.   It's 10:00 AM.
