Old 03-04-2012, 09:27 AM   #1
GSWayne OP
Old Guy nOOb
GSWayne's Avatar
Oddometer: 3,092
FD Drain Plug Buggered Threads Fix
In case some other fumble fingered home mechanic cross threads the drain plug on an 05 R1200GS Final Drive here is what I did to fix it. I thought about trying to clean up the threads with a tap but it is an unusual thread, 12 mm x 1 mm pitch so I didn't have a tap and I doubt if any place in Santa Barbara had one (standard 12 mm pitches are 1.5 and 1.75 mm). I was also concerned that tap would start wrong and cut new wrong threads. So I decided just to remove the first few damaged threads, because there were plenty of good threads left.
So I made a brass bushing to protect the sealing surface and center the cutter.
That just fit a 1/2" counter sink
And using a hand drill, carefully cut away the bad threads and left a tapered guide into the good threads. With thick cutting oil on the countersink, frequent cleaning of the countersink and hole, and blowing air into the fill port of the FD I don't think I got any aluminum chips in the FD. Now the plug went in fine. Typical case of one of those simple one hour jobs turning into an exciting afternoon of improvised repairs.
All you brain surgeons in the audience you will recognize the hand drill as standard issue in an expendable brain surgery kit (no I am not a brain surgeon and don't even play one on TV).
It isn't the conditions its the decisions
Don't bring a motorcycle to a car fight
GSWayne is online now   Reply With Quote
Old 04-25-2013, 05:28 PM   #2
John Smallberries
John Smallberries's Avatar
Oddometer: 1,300
Crap!!! I just did this
I"m glad I found this old thread - as I just did this on my '05 1200GS - turning an 30-minute final drive oil change into an "oh shit - now what" moment. I'm stopping at the dealership tomorrow to see if they have any tap to help me out.
'05 BMW 1200GS '09 Honda CRF230 '10 Yamaha TW200 '07 KTM 400 XCW/EXC '15 Jialing 150 GY2
John Smallberries is offline   Reply With Quote
Old 04-25-2013, 05:45 PM   #3
hammick
hammick's Avatar
Oddometer: 1,940
Don't feel bad guys. I stripped out the fill hole on the final drive on an '07 GSA two days before I was to leave on a 3k mile trip. The plug would just spin and I couldn't get it out either. I packed around the plug with JB Weld and it held until I traded it in at which point the dealer put in a helicoil and fixed it proper. The metal on the final drives is soft. I couldn't find a torque spec so I assumed it was the same as the tranny fill. Wrong! Tranny is hard steel. Final drive is not. I don't use a torque wrench on the final drive any more.
2015 R1200 GSA
2014 Moto Guzzi California Custom
2014 Husky FE501
hammick is offline   Reply With Quote
Old 04-25-2013, 06:35 PM   #4
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,465
Torque value for the plug is "good-n-snug" and no more!
Jim
Old 04-25-2013, 07:49 PM   #5
rdwalker
Oddometer: 2,542
Originally Posted by JimVonBaden View Post
Torque value for the plug is "good-n-snug" and no more! ... Jim
WRONG!
Tighten until it strips, then back off a quarter turn.
(Could not resist... )
Robert in Northern NJ __ '09 R12GS, '03 R1150RT, '01 F650GS
-->> James Bay & North Road Solo Blitz -->> Patagonia / Tierra del Fuego Cappuccino Tour
-->> Trans-Labrador Highway Solo Blitz --->> South African Cappuccino Tour
rdwalker is offline   Reply With Quote
Old 04-25-2013, 08:08 PM   #6
JimVonBaden
"Cool" Aid!
Oddometer: 53,465
Originally Posted by rdwalker View Post
WRONG!
Jim
Old 04-26-2013, 12:54 AM   #7
Spyker
Oddometer: 186
WRONG!
That is known in the industry as Suzuki tight.
Originally Posted by scottie boy
If you calculated the money spent versus time actually used, vaginas cost more per hour than the space shuttle.
Spyker is offline   Reply With Quote
Old 04-26-2013, 02:40 AM   #8
John Smallberries
Oddometer: 1,300
My plan - bad as it is
I also have a 1900 mile trip coming up next weekend and an off-road day with a bunch of guys tomorrow. I want my GS back TODAY (gotta try out my new Hiedenau rear tire).
So here is my plan - bad as it is:
A) Visit the dealer to ask their advice and get a price for a proper fix, should my other plans fail. Take whatever advice they give me (I'm a bit afraid of my ability to execute the good fix that started this thread!)
B) Buy a new drain plug and o-ring
C) Try tonight to clean out the old thread (only the top aluminum thread is bad, the rest look fine) with a dental pick (or other technique recommended)
D) If C fails, I'll grind all the threads off my old plug, slip it in to get the O-ring to seal, then apply some Sugru to hold it in place. This should "protect the crime scene" for a proper repair of the aluminum threads at a later date.
I feel like a complete dumb-ass today!
Old 04-26-2013, 02:52 AM   #9
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,946
I met a guy with a (83'?) XT550 yesterday. I thought my bike was in bad condition, but that thing was uglier than mine and the frigging thing pissed oil, like literally He said he bought it and the PO was doing the clutch and stripped all but two of the crankcase bolts and two of the three oil filter bolts. Got it for cheap needless to say, but I'm surprised one could ride something like that. let alone strip almost all the bolts. I need to carry around a camera, this dude matched his bike.
Don't feel bad!
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust + over sized header
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is online now   Reply With Quote
Old 04-26-2013, 03:00 AM   #10
John Smallberries
Oddometer: 1,300
JVB Tech Day
JVB;
This should give you a good "what not to do" lesson for your Tech Day!
That looks like a good time, BTW.
Old 04-26-2013, 04:17 AM   #11
JimVonBaden
"Cool" Aid!
Oddometer: 53,465
JVB;
Should be fun.
On your drain plug, is the O-ring showing, or still inside the FD?
Jim
Old 04-26-2013, 05:12 AM   #12
John Smallberries
Oddometer: 1,300
Drain plug
Should be fun.
Jim
O-ring is in good condition and still on the drain plug. The hole in the FD looks clean as well, I just can't find the start to the first thread. All the threads beyond the first look fine. It isn't an over-torque issue - I think I just cross threaded the plug as I was trying to re-install. The hole is at an odd angle - but I didn't think I could damage the threads with just finger-torque. These 12x1mm are very fine and fragile. To make things worse, our diabolical pals in Germany didn't put a dog-point on the plug to help get it started.
Old 04-26-2013, 05:27 AM   #13
JimVonBaden
"Cool" Aid!
Oddometer: 53,465
Gotcha. Use a small 90 pick and chase the threads from the inside out. If the last thread is loose, break it off so you have a clean start.
Jim
Old 04-26-2013, 04:12 PM   #14
rdwalker
Oddometer: 2,542
Originally Posted by Dracus124 View Post
... the frigging thing pissed oil, like literally ...
There is a serious side to this - though it is open to all our jokes and sneers in previous posts.
The problem is that dripping oil may coat the rear tire. Then it's "To the Moon, Alice!".
Call me a coward, but I, for one, would never ride with an active leak.
Old 04-26-2013, 08:02 PM   #15
JimVonBaden
"Cool" Aid!
Oddometer: 53,465
Jim
Times are GMT -7.   It's 07:04 AM.
