Old 04-22-2013, 08:57 AM   #1
ausfahrt OP
mach schnell
ausfahrt's Avatar
Oddometer: 1,763
Bing or Mikuni?
I bought my airhead in 2010. I made good progress towards getting the R75/7 running again for the first few months or so and then the project got bogged down due to......life. I am moderately competent with a wrench and I do all the maintenance on my FI hexhead GS but carbs have always frustrated and vexed me.
The main thing left to do on the R75 is the carbs. I have been reading the Mikuni thread with interest and at first I thought that a Mikuni was my answer but I see that there are frustrations there too. I am mostly looking for reliability and a "plug n play" carb and I don't really care about performance. So that brings me back to my original question.
Should I send out the Bings to be rebuilt or should I go with new Mikunis?
BTW here is a link to my original thread if you're interested:
http://advrider.com/forums/showthread.php?t=570173
You can always count on the Americans to do the right thing, after they have tried everything else.
-Winston Churchill
ausfahrt is offline   Reply With Quote
Old 04-22-2013, 09:07 AM   #2
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,464
If you aren't concerned about performance or super snappy throttle response, I'd just rebuild what you have... yourself. Don't bother sending them out, it's REALLY easy to do yourself. Just don't bother with the butterfly shafts, they're a little tougher to do correctly, but the rest is stupidly simple. Just order a couple rebuild kits from bing and a few cans of carb cleaner and you can do it yourself in an afternoon.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 04-22-2013, 09:20 AM   #3
blaine.hale
blaine.hale's Avatar
Oddometer: 3,066
What he said. Bings are mega easy to clean, tune and maintain. They do sometimes just shit out on you though...
That's what lead me to getting Mikunis. One of my Bings out right failed and I can't chase down the issue to save my life, that's another thread with all kinds of trouble shooting.
Now, I haven't had mikunis on long and I haven't even had time to tune them and ride for more than 2 miles. So my observations are on the negative side, since I haven't gotten to see performance. I know there will be some really great pluses once I'm smoothed out.
-They aren't true left/right side so the idle mixture screw on either carb will be super awkward to adjust, as well as fuel inlet.
-There's no vacuum take off port for my carb balancer
-Unless you buy them from rocky point, rubber connects can be weird. We've found a decent solution in the mikuni thread, that I use...it involves way too many hose clamps, though IMO.
-There STILL isn't a consensus on jetting for each model. Not even a really clear baseline for an all stock bike. Adding more free flowing
-If your engine isn't blasted and clean, they stick out like a sore thumb...but who honestly cares about that, we ride.
-Individual thumb chock paddles...not really a negative, I ditched my pull cable stock bmw choke set up years ago.
I did like the cable set up, really easy to adjust, even while I'm riding (in line adjusters.) They do start up super quick with little throttle.
I'll report back in the mikuni thread when I have them running nicely. Right now, my idle circuit is running so rich that it shits black smoke. Turning the idle mixture screw out about 3 turns kills the smoke, but I should probably rejet that. Balancing is going to be hard for me, I'm not used to ear tuning.
1974 BMW R90 /6
1968 Bultaco Matador MK3
1973 BMW R75 /5 Toaster LWB
1969 Bultaco Bandido MK2
2013 Husqvarna Terra TR650
blaine.hale is offline   Reply With Quote
Old 04-22-2013, 10:09 AM   #4
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,476
I'm drilling my keihins for vacuum ports hopefully this weekend. They have an obvious raised spot for them. Maybe the mikunis do?
@OP: I've ridden several airheads with round slides, flat slides, Dels...they do tend to have a better throttle response in that split second after you crack open the throttle. They should flow more air since there's no butterfly valve blocking the intake track.
However, as performance isn't an issue for you, I'd rebuild the Bings. I think you'd have more luck selling it later if it's stock too.
There's an inmate named Infracaninophile who did a veeeery thorough, photo-heavy explanation of the carb rebuild in his r100gs thread...which I can't find right now. I'd recommend finding that instead of using the book.
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 04-22-2013, 10:41 AM   #5
oldroadie
Two wheel addict
Oddometer: 468
Just so you know, my VM32 Mikunis came with vacuum ports installed. Since I bought them used I can't identify the original source but the ports are there and they look factory.
oldroadie is offline   Reply With Quote
Old 04-22-2013, 11:01 AM   #6
some_guy
some_guy's Avatar
Oddometer: 144
I can't comment on the Mikunis. I can comment on how easy Bings are to rebuild. I rebuilt mine without trouble or issue. The tricky part is tuning them after.
some_guy is offline   Reply With Quote
Old 04-22-2013, 11:56 AM   #7
Uncle Pollo
happy cachiporra
Uncle Pollo's Avatar
Oddometer: 47,594
Meh
Uncle Pollo is offline   Reply With Quote
Old 04-22-2013, 11:59 AM   #8
Beater
Dirty
Beater's Avatar
Oddometer: 3,198
No question. Mikuni's. Indestructable. The diaphram won't split on you. And the 32 round sides are perfect for your application / engine.
Fred
'85 R80RT G/Sified <|> '91 R100GS Bumblebee (103K miles and climbing) <|> '73 R75/5 LWB
Airhead Zen: Ride - Repair - Ride - Maintain - Ride - Repeat
Beater is offline   Reply With Quote
Old 04-22-2013, 04:12 PM   #9
Plaka
Brevis illi vita est
Oddometer: 4,588
"rebuild" yourself. not much to it, take apart, clean, replace the o-rings, put back together. Don't replace the diaphrams unless they have holes, do have a spare set on the shelf and with you on long trips. if the needles are alloy (non-magnetic) consider replacing them and the needle jets. Early steel needles last a very long time. There are jets in the carb bowl, clean them. The enricher gasket has a narrow spot. Common point of failure. Glue it well there. Put in a stainless top screw kit, totally worthwhile. That's it.
There is a deep well of wisdone on setting these up, tuning, etc. And they are effecient and tough. Takes some REALLY bad gas to make them stumble. A snap to change jets by the side of the road for altitude, the bowls just clip off to give you a quarter cup of gas for starting campfires...just very nice all around.
The Mikunis and Dells have snappier throttle response which is fun. But you tend to use it, which hurts mileage and wears out tires, etc. As the big Mikuni thread reveals, people are doing a lot of fumbling around trying to set them up. Not an issue with the Bings.
Old 04-22-2013, 04:19 PM   #10
oldroadie
Two wheel addict
Oddometer: 468
I have two Bings on the shelf and a bag of Bing jets that suggest otherwise.
Old 04-22-2013, 05:11 PM   #11
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,182
Mikunis are usually a step up from Bings. If you are ready to make the move, now is the time. It is likely that you will eventually get the Mikunis so don't waste any time on the Bings, if you are ready.
---Albert Einstein
Old 04-22-2013, 05:19 PM   #12
Plaka
Oddometer: 4,588
methinksthat's not the fault of the carbs. Try the stock setup on a stock bike. Works good. The manufacturer already sorted it out. Plug and play. There is also a table of altitude corrections in the manual. No guesswork there.
I mean, no offense, but how do you get Bings wrong?
Old 04-22-2013, 06:15 PM   #13
ausfahrt OP
mach schnell
ausfahrt's Avatar
Oddometer: 1,763
See? This is what I'm talking about. There is no real consensus on this board but you guys have me thinking about staying with the Bings.
My history with carb work is not pretty. I own the Bing cd on rebuilds but.....
Thanks for all the replies.
-Winston Churchill
Old 04-22-2013, 08:30 PM   #14
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,415
You'll never know if you don't have a go. The BINGs are easy. One at a time though. Disassembly is straightforward, as is reassembly.
If you change the needles, it's also easy, but not intuitive if you've not been there before. Ask back.
* Mixture screw and o-ring.
* Pilot jet and o-ring.
* Main jet/washer/jet stock/needle jet/atomiser.
* Top dome/springs/diaphragms/slide and needle.
* Enrichener circuits.
Do one system at a time. A dental pick is a handy device to help get new o-rings on. Change the dome screws to allen heads.
Ask back when reinstalling the main jet stack as it's vital to place the atomiser correctly.
Soak and clean, including the small holes in the orifice. Blast with air, ream with copper wire or fishing line. Flush and blast with air again.
Reassemble and tune the cables.
You'll get as much help as you need here, at every step. Have a crack.
boxerboy81 is online now   Reply With Quote
Old 04-23-2013, 05:24 AM   #15
oldroadie
Two wheel addict
Oddometer: 468
Sometimes even a carb as simple as the earliest Bing can't be resurrected even with the $200 rebuild kit. Toss in previous owners ham handed damage. And if you don't have a handy dealership trying to obtain parts is a frustrating, time consuming affair. In my case a meticulous complete rebuild did not solve erratic starting and varying idle...a different rpm at every stop.
On the other hand there's no option for vacuum leaks or torn diaphragms with the Mikuni. Parts are easily sourced from any local Yamahondasuzikawa dealer. Cable drive makes balancing a snap. Totally separate enrichner circuit makes starting a breeze. And then there's the performance.
Feel the same way about Amal carbs, too. Why struggle when you can ride?
Times are GMT -7.   It's 12:13 AM.
