Old 04-29-2013, 07:57 PM   #1
Trials/Rider OP
Trials/Rider's Avatar
Oddometer: 50
'89 BMW R100 GS/ Steering bearing replacement / upgrade
Anyone replaced the steering bearings? I did a parts search and found this on eBay:
http://www.ebay.com/itm/BMW-R100GS-R...item257bb6440d
Anyone use these or know of a better set to build with?
Any help would be greatly appreciated!!
Trials/Rider is offline   Reply With Quote
Old 04-29-2013, 08:01 PM   #2
Trials/Rider OP
Oddometer: 50
Found this- would this style be better?
http://www.ebay.com/itm/All-Balls-St...p2047675.l2557
Old 04-29-2013, 08:14 PM   #3
bmwrench
Oddometer: 2,057
I wouldn't use them for steering head bearings. I didn't like the finish on them and suspect they won't last as long as they should.
bmwrench is offline   Reply With Quote
Old 04-29-2013, 08:17 PM   #4
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,667
All Balls bearing....made in China, if you want good bearings , Koyo, SKF, Timken, FAG......get the bearing number and either go to a local bearing supply house or maybe try Houston Bearings. I think the BMW fiche list the bearing size.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 04-29-2013, 08:46 PM   #5
Trials/Rider OP
Oddometer: 50
Thanks! Thats good info. We have a large bearing supply here and they probably have them.
What style should I use- the top or bottom style?
Will I need to get any nee seals when I tear int this? Thats why I was looking for a kit.
Old 04-29-2013, 11:34 PM   #6
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,461
The bearings you see on eBay are same ones sold through most of the larger motorcycle parts suppliers and they work just fine. Save some money and buy them.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 04-30-2013, 11:15 AM   #7
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,115
The Stock steering head bearings are like the wheel bearings- pretty robust, eh?
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 04-30-2013, 12:40 PM   #8
supershaft
Oddometer: 9,110
You can get good quality bearings from a BMW dealer for cheaper than that.
Old 04-30-2013, 01:22 PM   #9
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,174
The bearing is a 28 x 52 x 16 Tapered roller bearing. The original part number for these was 07 11 9 985 070. This part number is some what revealing. It starts with the 07 that indicates it is not a special BMW part but is something that BMW buys on the open market and resells to you. Part numbers that start with 07 are mainly nuts, bolts and washers and can often be found cheaper elsewhere.
According to Max BMW the original number is now superseded by 07 11 7 663 941. Notice it too seems to be a generic part.
These cost $27.95 each from Max. The Ebay bearings are almost half that price. I have the All Balls bearings in my bike for several years now. The dealer sells the bearings each so you need two. The Ebay seller of the All Balls bearings is a kit and one kit is both bearings. So cheaper.
BTW the sellers are listing their bearings for 1987 and up but the same bearings are used in all Airheads from 1970 on.
---Albert Einstein
disston is online now   Reply With Quote
Old 04-30-2013, 03:59 PM   #10
Trials/Rider OP
Oddometer: 50
Thanks! I was wondering what I was going to find inside this, and was wondering if it was actualy ball bearings as mentioned above (was wondering as most are listing this as an upgrade).
I'm almost ready to pull the assembly off.
Old 04-30-2013, 04:25 PM   #11
garthg
garthg's Avatar
Oddometer: 376
Do you have the internal puller?
I'm informed there are other ways to remove the inner races, such as welding a bead on them with a MIG or TIG welder, but you can't just drive the races out like you can on a Japanese bike. The above tools make it a lot less traumatic.
garthg is offline   Reply With Quote
Old 04-30-2013, 04:31 PM   #12
johnalex
Rider of rides.
johnalex's Avatar
Location: Los Angeles, CA, USA l Todos Santos, BCS, Mexico
Oddometer: 53
Can you share a good source for these tools?
TIA,
JohnA in LA
85 RZ500 - Tricked out
00 Pegaso - SOLD - 01 RSVR - SOLD
98 VFR - 133,000 miles
89 BMW R100GS - in Mexico
johnalex is offline   Reply With Quote
Old 04-30-2013, 04:45 PM   #13
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,174
This is the kit made and sold by Cycle Works. If you do not have the welder or expertise to do this job other wise then get the tool.
http://www.cycleworks.net/index.php?...products_id=64
It's not really cheap at $85 but maybe your local Airheads might already have it. It does pay for it self at least by the second time you use it so you could own it if you keep this bike for ten years or own two bikes or something.
The Kukko Pullers shown earlier cost more.
---Albert Einstein
Old 04-30-2013, 05:02 PM   #14
garthg
garthg's Avatar
Oddometer: 376
TIA,
Years ago, I ordered them through my BMW dealer.
Samstag Sales lists them on their web site:
http://www.samstagsales.com/
The Kukko puller is definitely more expensive, but it works, positively, every time, without drama. It can also be used to pull wheel bearings on certain models. There are also non-BMW uses.
This place also show them:
http://www.toolwarehaus.com/
It's Kukko, Counterstay 22/2 and internal extractor 21-5 (I think--they come in different sizes depending on what bearing size you're pulling).
Old 04-30-2013, 06:05 PM   #15
supershaft
Oddometer: 9,110
Oops! I thought the price was a piece.
At any rate, I would not put a Chinese made bearing in my bike or my customers' bikes. So far in my experience, they have all been beyond junk. Many of them right out of the box!
Times are GMT -7.   It's 10:19 AM.
