Old 04-30-2013, 04:41 AM   #1
ipaulog OP
ipaulog's Avatar
Oddometer: 42
Question Wheel Bearing Codes
I can't understand any of the numbers on the parts fiche for my 950 wheel bearings - presumably they are obscure for a reason!
Can someone give me the generic numbers. I've got an SKS supplier just around the corner and they usually cost less than half m/c dealer prices.
Thanks, Paul.
ipaulog is offline   Reply With Quote
Old 04-30-2013, 05:59 AM   #2
ipaulog OP
ipaulog's Avatar
Oddometer: 42
Ok, maybe not obscure at all I'm just easily blinded by lots of numbers and I did mean SKF!
Front: 6906-2RS (30mm x 47mm x 9mm)
Rear: 6205-2RS (25mm x 52mm x 15mm)
If I'm wrong I'd like to know before I order.
ipaulog screwed with this post 04-30-2013 at 06:06 AM
Old 04-30-2013, 10:25 AM   #3
crazybrit
crazybrit's Avatar
Oddometer: 8,553
Those are (correct) generic numbers. SKF makes them. Your local bearing supply house will likely have a "house brand" that's a lot cheaper than SKF and just as good for this application. Standard clearance, commodity item. Nothing magic. My local supplier sells KBC (Korean).
Sprocket support is 2 bearings (stacked) also. On other KTM cush drives it's sometimes an expensive double-row.
crazybrit is offline   Reply With Quote
Old 04-30-2013, 11:15 AM   #4
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,775
Originally Posted by crazybrit View Post
Nothing magic.
If you're going to all the trouble to replace them, might as well do it right the first time and put in the magic ones.
Look for the "M" suffix on the part numbers.
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 04-30-2013, 03:47 PM   #5
ipaulog OP
ipaulog's Avatar
Oddometer: 42
Thanks. I'm sorted. And now for the next unplanned job.
Old 05-06-2013, 05:17 PM   #6
FakeName
FakeName's Avatar
Oddometer: 1,775
Just bought two pairs off ebay with these numbers. The rears are $5.88 for the pair.
I'll grant you, they are not what I'd use in under ideal conditions, but for spares to carry on the bike, I'll do it. I'll pack them full of waterproof grease in advance, store them in plastic bags, and break them out for emergencies.
Here's my last wheel bearing experience in somewhere in Utah- lucked out my buddy was just about to leave the KTM dealer 100 miles away- caught him just in time for a parts run.
2014 500EXC Black
Times are GMT -7.   It's 03:50 PM.
