Old 05-05-2013, 05:16 PM   #16
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,865
Originally Posted by Chinookmark View Post
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 05-06-2013, 08:07 AM   #17
JTMETZ54
Oddometer: 27
Here is a picture from the bat as I installed the mount. I am thinking I may need to build a bracket to support it from the bottom, but currently it does feel pretty stable.
Here is what the finished product looks like today.
I will hopefully get to test this out next weekend.
JTMETZ54 is offline   Reply With Quote
Old 05-06-2013, 09:06 AM   #18
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,971
That is not bad at all, nice work.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Old 05-06-2013, 02:54 PM   #19
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,176
The positioning looks great.
However I would argue the supporting plate is way too thin.
Cheers.
Old 05-06-2013, 05:08 PM   #20
JTMETZ54
Oddometer: 27
I'm more worried about the plastic dash than the metal. It is a pretty heavy gauge steel, but does look tin in the picture. My biggest concern is the screw holding the base down, I may add some thread lock to it.
Old 05-07-2013, 05:50 AM   #21
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,527
Finally was able to get pics on my installation. AMPS with the Ram screwed to the stock holes in the triple clamp.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is online now   Reply With Quote
Old 05-07-2013, 08:25 AM   #22
FakeName
FakeName's Avatar
Oddometer: 1,865
Originally Posted by Boatman View Post
[/URL]
2014 500EXC Black
Old 05-07-2013, 08:47 AM   #23
renogeorge
Oddometer: 1,482
Montana Mount
Ram mounts with Garmin Rugged Mount. I like mine on the left side for easier access with my left hand. I switch my Montana back and forth between my 990/950 and my 300 2 stroke. This mount setup has worked very well for me and has proven very durable through a lot of very rough use.
FWIW
KTMs--300, 518, 990
renogeorge is online now   Reply With Quote
Old 05-07-2013, 11:15 AM   #24
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,176
You mean these covered holes are threaded? and fit exactly with the two bolts RAM mount?
Old 05-07-2013, 12:28 PM   #25
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,971
Nice
Old 05-07-2013, 03:10 PM   #26
LarryChile
Oddometer: 4
Hi buddies.. inspired on all yours examples i used the on-dash gps mount that was already installed... I lent a milling machine to a friend, and here is the result
See ya!!
LarryChile is offline   Reply With Quote
Old 05-07-2013, 08:16 PM   #27
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,527
Yup,,,, pry out the plastic plugs and they ahve threads. The holes are ust a tad closer together than the RAM holes but with a Dremel or file they work out perfect.
Old 05-09-2013, 03:02 PM   #28
ybracing
Oddometer: 670
Here is how I chose to mount my Zumo 550. I mounted it in 2005 and have had no problems with it.
To mount the Montana the same way you will need the following parts:
These are all Touratech part numbers:
Toutatech 950/990 mounting adapter # 040-06632 $75.20
Garmin Montana mount and power cable # G 11654 $37.99
Touratech locking mount # 065-0600 $184.90
These are the only parts needed to install your gps onto your bike.
The locking feature is a must if you don't want to pull the gps off every time you stop for lunch.
I hooked the power to the accessory power under the dash that is on regardless of the key position. I don't like the gps switching off every time I shut off the bike.
The ram mounts work good but look like an add on instead of something that was made for the bike. Personal preference!
ybracing is offline   Reply With Quote
Old 05-09-2013, 03:33 PM   #29
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,971
Having it mounted above the speedo looks nice, but you can get a little GPS fixation with it up there. That is why I like down a little lower. I really like Boatman's mount - considering putting it there myself.
Old 05-09-2013, 07:44 PM   #30
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,527
A couple points.... the AMPS and Ram are $62 from GPS City. It comes with a short Ram arm but I'm sure GPS City can swap for a longer arm if you want it higher.
The AMPS mount has a security screw to lock it in place. I've never used it,,, whenI need to take the gps with me,,, press the button and it's out in less than a second. Pops back in in the same amount of time.
I'm still using my 60Cx on the Super Enduro because I have the Scotts triples and there are no mounting holes. But I have an idea to make a simple bracket that will bolt on to where the ignition switch bots up and hold the Ram mount.
Times are GMT -7.   It's 07:08 PM.
