Old 05-11-2013, 02:37 AM   #46
Olvi
Ice Butt
Olvi's Avatar
Oddometer: 98
Originally Posted by jj le roux View Post
The guys at Wilbers make a good shock as well don't they. I believe even their entry level is great. Also made to rider spec, conditions and pillion.
Hmm, couple of dudes I know had Wilbers on their bikes. Both has blown at least ones (because of long-lasting stress) so I didn't take the same path. Pavement they may handle but if you put load and take you bike to the bumpy roads, you may end up to troubles.
You must remember where you are going to use the bike. Many shocks can handle "easy flat roads" but if you plan to adventure elsewhere, long-lasting stress will kill many of the shock or the damping will die to to a overheat.This is where the design and quality plays its role and you can't do lasting shock in cheap.
www.dustywobbls.com
Olvi is offline   Reply With Quote
Old 05-11-2013, 08:04 AM   #47
epicxcrider
epicxcrider's Avatar
Oddometer: 645
I imagine were going to start seeing blown touratech shocks too sooner or later. With higher performance damping comes higher maintenance cost and shorter intervals. Keep it clean and have it rebuilt every year and the thing should last.
Old 05-11-2013, 08:25 AM   #48
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,751
TT stated every 30.000 kms.
Loutre is offline   Reply With Quote
Old 05-11-2013, 02:36 PM   #49
epicxcrider
Oddometer: 645
Seems reasonable to me, right in line with other aftermarket options
Old 05-16-2013, 11:54 PM   #50
shin938
Oddometer: 43
Originally Posted by Konflict Motorsports View Post
Which models are you speaking of? Explore, explore hp, expedition, or extreme. I have tested every model on the F800's.
Do you know if its possible to have a touratech rear shock for 1150 ADV with remote reservoir and high/low compression adjustment? like the expedition for the 1200?
what about the suspension travel? will it be the same or less then as OEM?
shin938 is offline   Reply With Quote
Old 05-17-2013, 08:59 AM   #51
KM TUNER
Konflict Motorsports's Avatar
Oddometer: 860
Shine,
I haven't done it before, but I don't see why I couldn't build you one. I could take the remote reservoir off lets say they Expedition series shock for the BMW F800GS and modify it to the Explore HP. It would maintain the stock height of the GS Adventure.
Pricing and parts availability would be something I would need to follow up with if you are serious.
PM me for any other questions you might have.
Konflict Motorsports & Suspension www.KonflictMotorsports.com
Konflict Motorsports is offline   Reply With Quote
Old 05-17-2013, 08:00 PM   #52
shin938
Oddometer: 43
Shine,
Sent you a message.
Old 05-18-2013, 06:00 AM   #53
jeff34
aventurier français
jeff34's Avatar
Oddometer: 19
ohlins + toutatech
I 'd mounted bitubo kit and a Wilbers shock but I have exploded bitubo kit and I wanted to better
then, I have sought the best for our 800
I have put the TTX22 ohlins kit into the fork and shock touratech extrem
I have not handled it as best as possible, but even with the first basic settings, it's awesome
jeff34 is offline   Reply With Quote
Old 05-26-2013, 12:53 PM   #54
rmhrc628
rmhrc628's Avatar
Oddometer: 2,591
Any Offroad reports on the extreme ?
How did your bitubo blow up? I thought they were good quality?
rmhrc628 is online now   Reply With Quote
Old 05-26-2013, 01:14 PM   #55
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,751
Tuesday I'll get the Highend version basicly the same thing but without that anti bottoming and hight feature.
Will mount it during the week and'll start offroading next weekend. Hope it'll be able to help you too.
Old 05-26-2013, 02:41 PM   #56
rmhrc628
rmhrc628's Avatar
Oddometer: 2,591
Excellent.
Are they the only differences ?
Old 05-26-2013, 03:12 PM   #57
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,751
Excellent.
Would say so, the only differences in discription are PDS and height adjustment.
Old 05-29-2013, 04:27 PM   #58
chris73
Oddometer: 250
I think I will need this shock for my 2013. I am in canada, so that sucks. I am 260 lbs and want to two up with my 120 lb wife soon. I am fairly happy with the existing suspension with my weight and 25 lbs of gear, so you guys topping out at 300 lbs. With gear should be fine.
chris73 is offline   Reply With Quote
Old 05-30-2013, 02:20 AM   #59
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,751
Little update:
I have the shock and it is a beaut': about 4.9kgs heavy. Problem is that I don't have (yet) the Torx 60 to untorque both screws. Really sucks =/. Went to my local hardware store and they only had 50. So now I have to wait for my placed order ( 2 days?) to get the right size. My review will have a little delay
Old 05-30-2013, 01:33 PM   #60
jj le roux OP
Oddometer: 25
Originally Posted by Loutre View Post
Little update:
I can't wait!
jj le roux is offline   Reply With Quote
Times are GMT -7.   It's 08:05 PM.
