Old 05-01-2013, 12:43 PM   #1
Spark Plug OP
Low on compression
Spark Plug's Avatar
Oddometer: 1,343
85 G/S Charging issue
Help please. 85 R80 G/S. Gen light won't come on.
Checked at the battery first. 11.8 at idle, 11.8 at 3K
Found tests here...http://jhau.maliwi.de/mot/r-elec.html
Checked Diode Board. Looks like crap (Black potting on the forward facing side is flaking off) Bench tested fine.
Checked Rotor 3.7ohms.
Checked stator no opens or grounds
Jumped regulator and checked again 11.8
Anyone have any ideas?
Nothing to see here.
Spark Plug is offline   Reply With Quote
Old 05-01-2013, 01:02 PM   #2
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,764
gen light dead?
under 12v isnt right anyway, and under 12v at 3krpm certainly isnt right either. The charging chain is broken, somewhere.
back to hte first thing i said, try touching one of the D's to the stator housing with the key on. That should hotpatch the gen light, I think.
Next problem I would look at is why the thing read under 12v at 3k rpm even with the regulator jumped. Without the regulator in place it should spike up to 15-16v at 3K.
Also look at the brushes.
Confirm you have a known good battery, as well.
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 05-01-2013, 01:05 PM   #3
Mugwest
Mugwest's Avatar
Oddometer: 6,367
+1 on the panel bulb.
And even if the bulb is continuous, i used to get a lot of schmutz on those dinky indicator terminals in that pod/panel from time to time. Would make the bulbs flaky or dead
Mugwest is offline   Reply With Quote
Old 05-01-2013, 01:15 PM   #4
Spark Plug OP
Low on compression
Spark Plug's Avatar
Oddometer: 1,343
I'm charging the battery up right now. Problem is I'm at work so I'm limited on what I can do right now. Brushes are a possibility but would they go over night? Seems to me that they would be a little more intermittent. Bike operated fine yesterday.
Does the light have to be working properly for the bike to charge?
Whats the procedure for testing a/c output at the stator? I'm going to try this when I get home.
Old 05-01-2013, 01:23 PM   #5
Mugwest
Mugwest's Avatar
Oddometer: 6,367
Yep. I forgot the terminology but it's an exciter circuit thru the bulb or some such
Old 05-01-2013, 01:26 PM   #6
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,764
Ah! Yes, the charge light in integral to charging. It should come on when the ignition is on, go out when starting, come on at idle, and go off at about 2K rpms or so. Its definitely needed for proper charging function, as it acts as a resistor on the circuit, with the added benefit that you can use it for diagnostic purposes. SOme people install a parallel resistor inline aroudn the lamp, which works great when the lamp blows, but then again, you cant tell if its not working by looking at it, like you cna with a lamp
AC testing at the stator should be straightforward. It should be producing a buttload of AC voltage at the three-wire bundle on the stator. Its the diode board what rectifies it to DC.
Old 05-01-2013, 01:29 PM   #7
Mugwest
Mugwest's Avatar
Oddometer: 6,367
I like how this guy s'plains it:
Without getting into too much confusing detail as to how it works, there’s basically a little bulb on your dash that says your bike is (not) charging (when illuminated). This bulb apparently provides light to a tiny magical gnome just below the light socket. When this light first comes on when you start your bike, it awakens him. He then summons the hamsters behind the front motor cover to begin spinning the wheels to charge your bike.
Spot on!!
Old 05-01-2013, 01:33 PM   #8
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,764
oh yeah thats much better tha I what i was gonna say
Old 05-01-2013, 01:36 PM   #9
Spark Plug OP
Low on compression
Spark Plug's Avatar
Oddometer: 1,343
That was it, swapped the high beam bulb with the gen and presto..... were charging again.
Thanks guys.
Old 05-01-2013, 02:02 PM   #10
Mugwest
Mugwest's Avatar
Oddometer: 6,367
Excellent, Plug
Now Teachable MomentTM Part 2: Can you see why it's A Very Good Thing to have a spare of that little magic gnome in your on-board spares kit?
Old 05-01-2013, 02:04 PM   #11
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,764
Originally Posted by Mugwest View Post
Excellent, Plug
Dont most people carry a spare in the high beam socket?
Old 05-01-2013, 02:34 PM   #12
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,752
In my /5 (with warning lamps. etc in the headlight bucket) I carry spare lamps and fuses in a Ziploc Snack Bag perched between the nest of wires. So when I need to change a bulb or a fuse, spares are available.
It's different in later models, but you get the idea.
--Bill
'73 R60/5 Toaster
Old 05-01-2013, 06:43 PM   #13
Spark Plug OP
Low on compression
Spark Plug's Avatar
Oddometer: 1,343
Excellent, Plug
I've always wanted a gnome in my tool bag.
Off to Ebay...
Times are GMT -7.   It's 09:55 PM.
