Old 06-01-2014, 03:39 PM   #1
fredcyr OP
Oddometer: 11
Eek R1150GS 2001 / Bad noise / video
Just returned from an hour of highway drive and this is the sound I heard when I stoped the music....
https://www.youtube.com/watch?v=bYUKfF2clwU
It sounds like it's comming from the back of the engine.
Can someone give me an idea what's wrong? (espacially if you experience the same noise)
Fred
fredcyr is offline   Reply With Quote
Old 06-01-2014, 03:55 PM   #2
(none)
poser
(none)'s Avatar
Oddometer: 2,635
Sound go away when you pull the clutch? Sounds like the slave cylinder. Mine did the same. Not an expensive part, kinda a PITA to replace though
Current:
R1150GS
GN400
LC80
JK Rubi
(none) is offline   Reply With Quote
Old 06-01-2014, 03:56 PM   #3
Jim Moore
Jim Moore's Avatar
Oddometer: 14,577
How many miles on the bike? Does the noise change when you pull in the clutch? I'm thinking slave cylinder going bad or metal-to-metal contact in the clutch.
Jim Moore
Jax, FL
Pay the lady, PirateJohn, you thieving piece of garbage.
http://advrider.com/forums/showthread.php?t=949341
Jim Moore is offline   Reply With Quote
Old 06-01-2014, 04:18 PM   #4
fredcyr OP
Oddometer: 11
105 000km and yes the sound stops when I pull the clutch.
I guess it's pointing toward the slave cylinder....
Old 06-01-2014, 05:14 PM   #5
Jim Moore
Jim Moore's Avatar
Oddometer: 14,577
Check the condition of the fluid in the clutch reservoir. A lot of times when the slave is going bad it causes the fluid to cloud up.
Have you noticed a slight chagne in the engagement point of the clutch lever? That's another sign.
Jim Moore
Jax, FL
Old 06-01-2014, 06:21 PM   #6
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,197
Sounds like the slave cylinder integral bearing.
BB has them priced well. Be sure to add grease to the little bearing, the are chronically undergreased from the factory..
Flush system with plenty of fresh DOT4
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Old 06-01-2014, 06:40 PM   #7
fredcyr OP
Oddometer: 11
Here's the fluid color:
Old 06-01-2014, 06:40 PM   #8
fredcyr OP
Oddometer: 11
What do BB stands for?
Old 06-01-2014, 06:44 PM   #9
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,197
BIG BREASTS!
just kidding
Link to what u need.
.http://www.beemerboneyard.com/21522335061n.html
Old 06-01-2014, 06:45 PM   #10
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,197
Yep, that is a indication of a failed slave cylinder!
Old 06-01-2014, 06:49 PM   #11
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,197
Also!
When you are doing the job....
Be sure you trim the pressure line sheath back as per this :
(the sheath holds water against the fitting crimp and will eventually rust thru)
Old 06-01-2014, 07:49 PM   #12
fredcyr OP
Oddometer: 11
Do I need to work forward of the cylindrical cross member or there's a way to get some loose on the clutch hose and pull back past the cross member to unscrew the fitting?
Old 06-01-2014, 07:53 PM   #13
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,197
Remove the tank, cut the ty(s) that are holding the clutch line, you should be able to pull back enough to undo.
Be sure to use new crush washers or at minimum anneal the originals if you are going to re-use.
Anneal by heating with a blow torch untin the copper turns brown in colour.
Old 06-01-2014, 08:02 PM   #14
fredcyr OP
Oddometer: 11
It looks like the hose is stuck somewere under the battery tray.
Any advice on how to clean the slave cylinder hole? A lot of dirt inside. Any thing else I should change working in the area?
Thanks for your help GS Addict!
Old 06-01-2014, 08:29 PM   #15
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,197
If there is no gear oil smell to the crud in the hole you are probably ok just replacing the slave assy. The rear seals on the trans shaft are pretty reliable. The crud will wash out with water as it dot 4 fluid based.
Use a small screwdriver wrapped with a damp rag and wipe out carefully.
Times are GMT -7.   It's 05:51 PM.
