Old 05-03-2013, 07:16 PM   #1
Okie Preacher OP
Okie Preacher's Avatar
Oddometer: 889
Question GS Turn Signal Mods for OffRoad?
I have not turned up any clear answers on search, but was wondering if there are any simple mods or alternatives on the GS's front turn signals to make them more durable?
Okie Preacher is offline   Reply With Quote
Old 05-03-2013, 07:43 PM   #2
Lonestar2112
scatology expert
Lonestar2112's Avatar
Oddometer: 7,679
Yup, but they are expensive. I went with the Euro turn signals. They are much shorter and tend to survive crashes better. I don't recall how much but they have been on my bike for 5 years and I love them.
Before the install.
Installed.
My BMW parts guy got my the part numbers. There is an OLD thread here on ADV about the conversion.
http://share.findmespot.com/shared/f...SKgzdmS9ir0XK3
Wypierdalaj ty chuju jebany
F*CK CANCER
Lonestar2112 is offline   Reply With Quote
Old 05-03-2013, 08:42 PM   #3
Hikertrash
Oddometer: 2,906
Buy a set of oem rear turn signals and put them up front. They're shorter. You can find them on eBay a lot of times pretty cheap.
IBA #50489
Hikertrash is offline   Reply With Quote
Old 05-03-2013, 09:27 PM   #4
oz97tj
oz97tj's Avatar
Oddometer: 819
The Euro LEDs run about 45 bucks a pop. I just swapped all mine out on my new LC GS.
'13 BMW 1200 GSW
'05 Honda ST1300
oz97tj is offline   Reply With Quote
Old 05-04-2013, 08:13 AM   #5
Okie Preacher OP
Oddometer: 889
Thanks for the tips.
Old 05-04-2013, 04:41 PM   #6
jachard
Oddometer: 603
+1 on this mod, just did it today. Super sano!! I'll post pictures in a bit. Keeps the OE look without the goofy length.
Cheers, James
2005 640e
2012 R1200GS Rallye
1993 Porsche 964 RS
http://octaneworks.wordpress.com/
jachard is offline   Reply With Quote
Old 05-04-2013, 08:45 PM   #7
MJS
MJS's Avatar
Oddometer: 1,905
you can get the stand offs separately. use either the rear stand off (very short stem) or the euro stand off (slightly longer) with your OEM turn signal housings. Both with move the turn signal inward and help prevent damage in a drop.
"You can follow me, but it's gonna hurt"
http://www.blackswanmoto.com
MJS is offline   Reply With Quote
Old 05-04-2013, 11:28 PM   #8
paulhdick
Wannabe Adventurer
paulhdick's Avatar
Oddometer: 328
mods not necessary
If you buy the front turn signal mount from an F800 they are as short as the rear and require no slotting to make them work! Did that to my 09 GS when I first bought it.
Paul
09 R1200GS
Been riding pretty much all my life. Raced SoCal desert in the 60's early 70's.
paulhdick is offline   Reply With Quote
Old 05-05-2013, 03:52 AM   #9
Okie Preacher OP
Oddometer: 889
Anyone have a part number for these? Are they 63 13 7 676 316?
Old 05-05-2013, 04:19 AM   #10
paulhdick
Wannabe Adventurer
paulhdick's Avatar
Oddometer: 328
Yes, that is the correct part number ... here is a previous post showing them mounted on my GS ..
http://www.advrider.com/forums/showthread.php?t=639144
Paul
09 R1200GS
Old 05-05-2013, 07:16 AM   #11
El Gato
El Gato's Avatar
Oddometer: 776
+1 for the euro LED's. They're not the low-cost option, but IMO they look far better on the bike, are brighter, and short enough to not get damaged in most drops. Here are the part numbers. The front left and right are the same part number. Rear signals have different numbers for left and right. $58.50 each and they are plug and play - though on the Adventure the rears are a bit of a PITA as you have to loosen the luggage racks and swing them out of the way to get the undertail plastic cover off to access the wiring.
2/63138522499 |LED FLASHER | $58.50| $117.00
1/63238522502 |LED TURN SIGNAL, REAR RIGHT | $58.50| $58.50
1/63238522501 |LED TURN SIGNAL, REAR LEFT | $58.50| $58.50
El Gato is offline   Reply With Quote
Old 05-05-2013, 09:41 AM   #12
Okie Preacher OP
Oddometer: 889
Outstanding! I do believe the problem has been solved for $32.00 plus shipping.
Old 05-05-2013, 12:49 PM   #13
oz97tj
oz97tj's Avatar
Oddometer: 819
A&S and Max both have them for far cheaper.
'13 BMW 1200 GSW
'05 Honda ST1300
Old 05-05-2013, 04:42 PM   #14
jachard
Oddometer: 603
So, I just did this over the weekend and here are a few shots. One item of note is that the hole for the fastener needs to be moved slightly inboard in order to fit the front mount.
Here are the results, I showed the original for anyone who wishes to see the difference.
2005 640e
2012 R1200GS Rallye
1993 Porsche 964 RS
Old 05-06-2013, 08:22 PM   #15
El Gato
El Gato's Avatar
Oddometer: 776
Those are the Max prices
Times are GMT -7.   It's 10:29 PM.
