Old 05-03-2013, 07:45 PM   #1
tvbh40a OP
PSUViking
tvbh40a's Avatar
Location: Idaho home of the fiesta bowl champ BSU bronco's
Oddometer: 1,431
Wolfman luggage
Is there a way to mount wolfman luggage to the stock GSA racks?
"Do today what other's won't, so you can do tomorrow what other's can't." Jody Sears-West Point
It is not enough to want to make the effort. Its in the doing, not just the thinking, that we accomplish our goals."
Just tell her my wife said it's OK-Handy
tvbh40a is offline   Reply With Quote
Old 05-03-2013, 09:00 PM   #2
bigbadandugly
Oddometer: 407
I have a GS with the Touratech Zega Pro luggage racks. Here's my setup that might give you some ideas.
The bags are larger than the frames, so frames offer good support and work well with the D-rings that are to be used with non-Wolfman racks. However, my concern was for the possibility of the exhaust pipe burning a hole in the Wolfman's in the event of a tip over. So I had an ADV forum member (TwinHeadlightErnie) make me a couple of backing plates out of aluminum and powdercoated. I decided to get one backing plate per side for each side as it provides protection for the Wolfman bags. The backing plate is not load bearing so it is fastened to the rack with tie wraps.
Here are some pictures:
Picture of the backing plate installed:
Top view of space between muffler and backing plate:
Bike with bags installed (the astute viewer will notice that I did not install the D-rings correctly, but this was just a trial):
BigBadAndUgly
Current: 2012 R1200GS
Past: 2009 Moto Guzzi Stelvio, 1979 Suzuki GS750L, XR350R, DT125, CT70
Dyno testing of a PC-V + Full Akropovic system on an R1200GS
bigbadandugly screwed with this post 05-04-2013 at 05:15 AM Reason: Change picture size
bigbadandugly is offline   Reply With Quote
Times are GMT -7.   It's 10:09 PM.
