Old 05-03-2013, 11:45 PM   #1
Phreaky Phil OP
Oddometer: 1,813
I need a new DR 650 frame
After finding this on my last trip I'm looking for another DR 650 frame.
Anyone out there got one. ?
I know I can get this one welded, but I wouldn't mind starting off with a better one.
Cheers,Phil
Phreaky Phil is offline   Reply With Quote
Old 05-03-2013, 11:49 PM   #2
PRITCH139
PRITCH139's Avatar
Oddometer: 595
Ah I've seen that happen before...
Try show and go motorcycles SA they had a few when I was looking.
IF YOU'RE GONNA BE DUMB,YOU GOTTA BE TUFF
http://www.youtube.com/watch?v=7TcOhIhY_s8
If you ride like lightning, you're gonna crash like thunder”.
PRITCH139 is offline   Reply With Quote
Old 05-03-2013, 11:52 PM   #3
atgreg
Africatwinarama
atgreg's Avatar
Oddometer: 10,023
look in the fleamarket
1990 RD04 Africa twin 750
350,000km and still going strong
atgreg is offline   Reply With Quote
Old 05-03-2013, 11:58 PM   #4
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,370
yep 1 in the fleemarket ... good things them DR's when your suspension reach's it limit the frame then takes up the slack
Sean-0 is offline   Reply With Quote
Old 05-04-2013, 12:17 AM   #5
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,219
That's horsepower that does that mate
I've got a burnt 06 frame that's on the stat writeoff register though if it's any good to you.
A vewwy good fwiend in Wome
Big Willy is offline   Reply With Quote
Old 05-04-2013, 01:27 AM   #6
Phreaky Phil OP
Oddometer: 1,813
this is whats made it crack.
See the gap between the swingarm and frame ? when you tighten up the swingarm bolt it pulls the side of the frame in and has stressed it until it stared cracking. That gap should be shimmed so there is no stress. The othere side of the frame is much thicker so the left side cops it ! With it cracked I can see the crack open up as I tighten it up
I have found the one in the flea market. Will be looking into Freight cost.
Should jump on one of those cheap flights for a weekend. To big for carry on luggage !!
Old 05-04-2013, 01:28 AM   #7
boulder
jersey boy
boulder's Avatar
Oddometer: 125
Over tighten swingarm bolt does it too!!
step up or step aside
boulder screwed with this post 05-04-2013 at 01:35 AM
boulder is offline   Reply With Quote
Old 05-04-2013, 01:28 AM   #8
Phreaky Phil OP
Oddometer: 1,813
How badly burnt ?
Old 05-04-2013, 01:36 AM   #9
0405canvet
Oddometer: 378
Welding
One hour welding time and added plate on the outside. This will be stronger than stock. No worries.
0405canvet is offline   Reply With Quote
Old 05-04-2013, 01:51 AM   #10
0405canvet
Oddometer: 378
When you weld all day on things that really need to be welded perfectly, like pressure pipe, then small mild steel jobs with low stress become an easy fix.
Old 05-04-2013, 02:03 AM   #11
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,219
Originally Posted by Phreaky Phil View Post
How badly burnt ?
It's straight but would need a bead blast and a repaint.
I'd be inclined to agree with the others' thoughts and repair yours though.
I've wondered whether an overtight drive chain could contribute to this btw. Something has to give if it's too tight.
KTM's and Yamahas normally crack the back hub.
Just saying.
Old 05-04-2013, 02:14 AM   #12
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,370
Yes i see the problem ..i was just taking the piss ....they are a good thing no doubt about it
i would follow the others leads and plate the frame .....maybe a fix is needed b4 it breaks for those who own the DR
hope it turns out well for you and you get her back on the rd in short time
Old 05-04-2013, 02:16 AM   #13
robmoto
robmoto's Avatar
Oddometer: 3,848
Do you have the 2 thrust washers or are they missing .
I ride alone and not a KTM in sight .
Menace Racing supported by Robmoto Industries
robmoto is offline   Reply With Quote
Old 05-04-2013, 02:35 AM   #14
Phreaky Phil OP
Oddometer: 1,813
Yes, the thrust washers are in place.
Old 05-04-2013, 03:17 AM   #15
robmoto
robmoto's Avatar
Oddometer: 3,848
If you get a new frame , or that one fixed, if it was me I would add 2 more they are very thin so that may over come winding the frame in a bit that's my thoughts .
Times are GMT -7.   It's 04:05 PM.
