Old 05-04-2013, 05:48 PM   #1
rattis OP
rattis's Avatar
Oddometer: 1,129
Question High idle
Hi, my best -07 990 ADV took upon it's own to rise the idle to about 3000 rpm yesterday, after shutting of the engine and restarting it it was fine.
But today it's done quite a few times and then it woprked alright
As I'm off to Baja tomorrow I need some advice:
What is / was it do I need to buy some parts?
I imagine that the amount of competent 990 mechanics in Baja are very few if any at all.
I wish I had bought a GSA a long time ago
and now I drink Orange Crush as well, double up now, a 990Adv and a 950 SER
rattis is offline   Reply With Quote
Old 05-04-2013, 06:39 PM   #2
DeeGee
I'm a Yorkshireman thanoz
DeeGee's Avatar
Oddometer: 1,862
Have you done the 15 minute idle trick??
DeeGee is offline   Reply With Quote
Old 05-04-2013, 07:54 PM   #3
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,835
I thought it was a load of voodoo horse crap first time I ever heard about it, but do the 15 min idle. Turns out the ECU does some 11010001010010 crap.
Also, at least with mine, I've noticed that if I let the bike warm up to about two bars (I turn it on then get my gear on) that it runs better at low RPM's before it makes it to four bars. If I start it then ride it before two bars it still runs well just tries to do a little herky jerky crap. I think it takes that long for the ECU to do it's boot thing or something. But by the time it makes it to two bars either way it's good to go.
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 05-04-2013, 11:35 PM   #4
Martynho
No more Chilegringo.
Oddometer: 407
Tps
If the 15 min idle trick doesnt work, this could be the first sign of your TPS (throttle position sensors, on the injector bodies) going south. Mine had similar symptoms then got worse and worse.
You either need a dealer or use tuneECU to sync the throttle bodies after you install the new TPSs
Good luck
BTW the root cause of the TPSs buggering up was oil ingress into the airbox from a shot seal on the balancer shaft
Martynho is offline   Reply With Quote
Old 05-05-2013, 02:17 AM   #5
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 888
Before you go crazy (i did), happened the same to me 990.
what is the condition of your battery? Fluctuating current of a dying battery will mess up the ECU and idle control causing the high idle you mention.
My case i stopped the bike, kill switch off/on and start again. Fine at 1500rev. Later riding noticed the idle was a bit high and engine braking was more a engine accelerating.
Don't go yet mess up with the TPS. check the battery, give it a good charge, and verify the starter solenoid on low engine right. There's a small thin plate that goes to the bike contacts (2) that makes the current connection from rectifier to the battery.
Me 990 had that little plate corroding thus the charge was random, depending on engine vibration.
A new battery solved most of the issues, but by that time i already had mess up (tempation got the best of me) with the TPS, so added a bunch of new variables to the confusion.
Raid de L'Amitiť 2011 RR (link)
690R
Old 05-05-2013, 11:28 AM   #6
Katoom72
Katoom72's Avatar
Oddometer: 831
Something is steering the stepper motor, check electrical connections and health of the battery. When u turn the ignition on the stepper motor turn the intake butterfly's fully open and then closed, check if it does the full cycle.
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Old 05-05-2013, 02:41 PM   #7
NKL
Oddometer: 166
Have you adjusted the throttle cable recently?
NKL is online now   Reply With Quote
Old 05-05-2013, 11:43 PM   #8
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,883
One more thing to check.
I had bar risers installed. They got throttle cables too tight, so when I turned the bars, the bike revs accelerated...
Cheers.
Old 05-06-2013, 09:59 AM   #9
HooliKen
Awesome is a flavor
HooliKen's Avatar
Oddometer: 2,888
I am not intimately familiar with the intakes on the 990 but I will guess they are not a whole lot different than the ones on my 950. That said, have you checked for any intake/vacuum leaks. These will generally get worse at operating temp.
Cheers
Ken
"People in this country sleep peaceably in their beds at night because rough men stand ready to do violence on their behalf." George Orwell
950R Super Enduro - 450EXC - Gas Gas TXT 280 - 2000 Honda XR100R - 1988 Honda Z50R
HooliKen is offline   Reply With Quote
Old 05-10-2013, 07:38 PM   #10
rattis OP
rattis's Avatar
Oddometer: 1,129
Question stuck in Mexico
nothing worked the battery is 6 months old Li battery and there are no doubt swhen cranking , it starts like any thing and the high idle is random, but it's a bit hairy to drive in the mountains.
So I'll have to schlepp it back to the US, which is
the best place closest to Tijuana?
Holiday is intercoursed!!!!!!!!!!!
Old 05-11-2013, 02:55 AM   #11
Ajaa kuin mummo
÷÷.'s Avatar
Oddometer: 280
My bike sometimes gets the "high idle" -bug if I start riding immediately after starting warm engine. If engine is warm and I let it idle for 20 - 30 s after start, it idles ok.
Pics and vids
÷÷. is offline   Reply With Quote
Old 05-11-2013, 01:44 PM   #12
Gustavo.Ramos
Oddometer: 888
Brilliant!
can't proceed with holiday even with occasional high idles?
690R
Old 05-12-2013, 04:41 PM   #13
rattis OP
rattis's Avatar
Oddometer: 1,129
Laugh Could but won't
Originally Posted by Gustavo.Ramos View Post
Brilliant!
Going up mountains is OK, but going downhill without engine brake, you can do that.
Lots of mountains where I'm going
Safety first
Old 05-12-2013, 05:03 PM   #14
Gustavo.Ramos
Oddometer: 888
Safety first
been there done that, not fun ride
690R
Old 05-13-2013, 06:05 AM   #15
Kobus Kruger
Oddometer: 7
I also have the high Idle. Very dangerous at times.
After battery replacement no difference.
Then I did a 15min idle and it is much better now !!!! BUT not gone. It idles now at 1800-2000 rpm whereas before it reached 3000rpm easily . Thus it seems a good reset is the answer.
Think next for me is a TPS calibration...This needs to be done at KTM or someone who can connect to ECU. I am keeping a close eye on my idle. It is much better now and almost worth ignoring.
Kobus Kruger is offline   Reply With Quote
Times are GMT -7.   It's 07:15 AM.
