Old 06-12-2013, 03:34 PM   #151
KermitBike
usually lurking
KermitBike's Avatar
Oddometer: 18
switch and other problems
I hadn't noticed this thread so posted my list of issues with the GS-LC on the other thread at http://www.advrider.com/forums/showp...postcount=9448
Yeah, I had switch problems -- the cruise control and especially heated grips switches both stuck. This was after riding through a hellacious storm in Montana. They both recovered after drying out for a few days, but this is obviously a defect.
My cross country ride (7200 miles in 12 days of riding) was a great test for the new bike.
-Karl
2013 BMW R1200GS LC
1976 BMW R90/6
KermitBike is offline   Reply With Quote
Old 06-12-2013, 08:37 PM   #152
iride4u
iride4u's Avatar
Oddometer: 321
-Karl
Karl
Your write up is very informative.
Who ever is making the switches for BMW is doing a very poor job. As a K1600GTL owner as well as a R1200GS LC owner I can see the switch problems. On the K16 the problems seem to be heat related on the GS they seem to be water related. Some people have had luck with WD40.
Spence
iride4u is offline   Reply With Quote
Old 06-12-2013, 09:13 PM   #153
Rauven
I like the cold...
Oddometer: 201
Originally Posted by treg View Post
Have they changed them since the first ones?
Possibly. They have a new part number.
Rauven is offline   Reply With Quote
Old 06-13-2013, 04:16 AM   #154
iride4u
iride4u's Avatar
Oddometer: 321
Originally Posted by Chirozilla View Post
For the third morning in a row with temps in the upper 70's my left controls worked perfectly. When I checked them at 1 PM they had failed again. Temp 90. This is consistent with the previous two afternhttp://www.k1600forum.com/forum/bmw-k1600-lighting-electrical/21705-1700-miles-rain-left-handlebar-controller-failure.htmloons. Any one experienced similar situation and have a cure besides riding with a ice pack strapped to the controls ?
As a temporary fix cover the switches when you leave the bike outside in the sun. This may give you a little longer life until the dealer can get a replacement switch.
This is one of the many threads on the K1600 forum.
http://www.k1600forum.com/forum/bmw-...r-failure.html
Old 06-13-2013, 10:57 AM   #155
oz97tj
oz97tj's Avatar
Oddometer: 843
Add me to the switch failure list. They worked well on the trip I just got back from but today riding it the cruise was trying to run away from me if I set it by oushing forward on the lever or use the accel function. Dealer called and they put an order in for new parts.
'15 KTM 500 EXC / '13 BMW 1200 GSW / '05 Honda ST1300 / '04 Husqvarna TE510
oz97tj is offline   Reply With Quote
Old 06-13-2013, 06:19 PM   #156
Chirozilla
Oddometer: 5
Heat sensitive left control cluster
My dealer spoke with there rep today. He informed them that heat sensitive control failure was a result of cracked controller housing that expands with elevated temperature resulting in loss of conduction. Temp cools housing contracts thus connection made and controls regains normal function. Only cure is new cluster. This would be considered a cluster F--k. Leave on a 10 day ride in 14 days. New part 30 days out.
Chirozilla is offline   Reply With Quote
Old 06-13-2013, 06:50 PM   #157
Wdwrkr
Wdwrkr's Avatar
Oddometer: 2,041
Hey ya spence. I was wondering when you were gonna make it to these parts. Welcome friend
My mind is the most dangerous neighborhood I ever enter
Wdwrkr is online now   Reply With Quote
Old 06-13-2013, 08:05 PM   #158
Mattpar
Oddometer: 45
Clutch wont completely dissengage and noises
GS LC, with 729 miles. Trailered it up the dealer for its 600mi service(oil engine change, shaft oil change, visual inspection, and road test. Dealer did that, test drove the bike) all ok. I drove it 150 feet to my trailer. Reloaded it back on the trailer the same way(straps on the handle bars, away from the clutch and brake reservoirs)Towed it 1hr home, took it off of the trailer. Got onto the bike, clicked it into 1st gear, grabbed a fist full of clutch, started it up and it lurched forward a few inches when it started and ran. Went to ride to the garage but stalled it. Noticed the clutch lever friction area was REAL close to the full grab on the lever. Restarted, lurched a few inches forward. Rode it to the garage(170ft from street to garage)
Once at garage, Key ON, motor OFF, in 1st gear, clutch lever to the handle bar grip. I noticed it wouldnt roll easily. I had to PUSH it to get it to roll. Then I noticed the clutch was not disengaging all the way. I could hear it slipping. what the heck?!?! Then I noticed the gear grinding noise in the video.
In the video. Starts off with key OFF, clutch level OUT, gear Neutral, rocking back and forward hitting the brake, then when i turn the key ON(@8 secs),it makes the noise. I turned the key off at 30secs, no noise. My brother came over and I rocked the bike and he said he thinks the noise is coming from the airbox/top of the motor area? No clue?
http://youtu.be/bfEB_MgB174
Dont know how to imbed videos.
So i called the dealer, told him what the dealio was. They said they didnt adjust anything, all they did was change oil and visually inspect brakes, fluid levels, etc,...they are gonna pick it up Tuesday. We'll see what happens from there.
Any thoughts on why it would make a noise with the key ON and not OFF? And why wont the clutch disengage fully?
Mattpar screwed with this post 06-13-2013 at 08:14 PM
Mattpar is offline   Reply With Quote
Old 06-13-2013, 08:17 PM   #159
iride4u
iride4u's Avatar
Oddometer: 321
I could not take the crappie suspension on the Tiger any more. I traded it in about two weeks ago and now am just waiting Engine guards, Boxes and a Remus exhaust. This is so much lighter then the K1600 it is a ball to ride. I wonder how many others from the K1600 forum are here also.
Old 06-14-2013, 12:08 AM   #160
NLS
My bike needs washing...
NLS's Avatar
Oddometer: 3,187
Please keep us posted.
Make sure you read the other clutch issue in the forum (which resulted in replacing the whole engine).
Curious: Why you trailered the bike back and forth?
NLS
My Blog
When the going gets tough, the tough get going...
NLS is offline   Reply With Quote
Old 06-14-2013, 12:38 AM   #161
atg OP
atg's Avatar
Oddometer: 239
NLS;
Could you kindly point me to the subforum and post number regarding the engine exchange due to clutch failure ?
Thanks,
Andre
atg is offline   Reply With Quote
Old 06-14-2013, 12:44 AM   #162
NLS
NLS's Avatar
Oddometer: 3,187
Originally Posted by atg View Post
NLS;
Thanks,
Andre
http://advrider.com/forums/showthread.php?t=877412
...but I think it is a different issue after all.
Anyway keep us posted.
NLS
My Blog
Old 06-14-2013, 01:31 AM   #163
oz97tj
oz97tj's Avatar
Oddometer: 843
NLS;
Thanks,
Andre
That was me. It wasnt clutch related. It was a far different issue.
Old 06-14-2013, 03:23 AM   #164
Mattpar
Oddometer: 45
Originally Posted by Sindarin View Post
My K1600GT does this as well. If you roll the bike key on engine off and grab the brake quickly the ABS pump activates. My guess it has something to do with the wheel speed sensor self test not being completed (thus wheel speed is deemed implausible) but the pressure sensors in the ABS controller see a quick spike in brake pressure and activate the ABS brakes as a redundant safety precaution until the wheel speed sensor test can be completed and actual wheel speed known.
Don't know about clutch issue.
Really... I was assuming that the abs wasnt active until the lights stop flashing after its been ridden the short distance to get the lights to stop flashing. But the level doesnt pulse when the abs kicks in and makes that noise. Makes some sense because the bike has to be on to make the noise.
Ill have to read up on that. Must of missed that thread. I trailered it because I didnt know how long the service would take and didnt want to be stuck at the dealer for 2+hrs. Wanted my truck there so I could go get lunch or hit the mall up and check out the honeys. I will keep yall posted
Old 06-14-2013, 06:46 AM   #165
iride4u
iride4u's Avatar
Oddometer: 321
I can't believe how patient you were with all the geniuses that replied to you problems and still are. Good luck with your LC.
Times are GMT -7.   It's 04:05 AM.
