Old 12-14-2013, 04:46 PM   #1666
Rocky TFS
Rocky TFS's Avatar
Oddometer: 589
Originally Posted by oalvarez View Post
No problems experienced with the exception of having to get back home.
Yeah, some of us still have to eat and sleep once in a while.
I'm envious, the high here was 25. Looking forward to getting down to Anza Borrego in March with a brand new GSW!
2010 Yamaha TW200
2014 BMW R1200 GS WC
Rocky TFS is offline   Reply With Quote
Old 12-18-2013, 11:10 AM   #1667
ShaftEd
ShaftEd's Avatar
Oddometer: 3,358
Anyone else have loose switch gear on their GSW handle bars. My left side grip and switch gear assembly has a bit of movement forward and back. Right side seems fine. On the left side I tightened the T10 torx screws that hold the switch cluster together, but this didn’t stop the movement. I’m leaning towards the “They all do that” feature, but thought I see what others experienced. Thx.
BTW, as an update on my previously leaky water pump weep hole (leaked for the first 2000 miles). It is still dry and doing fine for the last 1500 miles.
ShaftEd is online now   Reply With Quote
Old 12-18-2013, 12:25 PM   #1668
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,587
Mine have never been loose. The left switches are flakey (and getting replaced tomorrow ) but they are solid on the bar.
marchyman is offline   Reply With Quote
Old 12-18-2013, 12:45 PM   #1669
ShaftEd
ShaftEd's Avatar
Oddometer: 3,358
Thanks for the info marchyman. Maybe something is up with mine. Probably swing by the dealer and have them take a look soon.
Old 12-18-2013, 12:57 PM   #1670
gr8ridn
gr8ridn's Avatar
Oddometer: 413
I have noticed my switch gear on the left side also has slight movement. There is supposed to be an attachment screw under the inner grip facing towards the rider that might be loose. I haven't done anything with mine yet, everything else is working fine.
2014 R1200GSAW
Racing Blue, Premium Group, DWA
gr8ridn is offline   Reply With Quote
Old 12-18-2013, 01:29 PM   #1671
ShaftEd
ShaftEd's Avatar
Oddometer: 3,358
You're right. There is a T15 screw hiding under the grip rubber. Just pull back a bit, tighten and she's all set. Thanks!
Old 12-18-2013, 02:32 PM   #1672
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,649
Beat me to it!
Old 12-23-2013, 03:29 PM   #1673
pauljm
R1200GS WC
pauljm's Avatar
Oddometer: 77
Left hand switch gear. issues
Yeah mine was loose then the dealer tightened it when they replaced my switch gear for the latest generation switches as I was starting to have issues.
Everything was fine initially. Now the Cruise control switches off when I flick the cruise control lever towards me. Its supposed to decrease speed in increments but its cancelling the cruise control.
Also the whole switch block has come loose again after my last off road ride.
Dealer said bring it in & no doubt they will fix it buts its a pain. Should be able to re-tighten the switch block that's not really an issue.
Anyone found a solution without having to have the new switch block replaced? Some type of reset maybe??
R1200GS LC
pauljm is offline   Reply With Quote
Old 12-23-2013, 03:52 PM   #1674
Voz
Voz's Avatar
Oddometer: 491
Left switch gear High Beam Switch flaky
I have already had my left hand switch gear replaced to resolve the DRL button not working. Now I find that the High Beam switch goes on and off as I ride along. It is getting worse and is now more off than on, sheesh, 1M miles of testing, they must not have had these switches fitted.
Sydney, Australia
2013 R1200 GSW Red - Blown Engine & Gearbox (clutch basket nut issue) - AUG 14
2015 R1200 GSW White - NOV 14
Voz is offline   Reply With Quote
Old 12-23-2013, 05:10 PM   #1675
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,587
pauljm, when was your switch replaced? Supposedly there is a new part for the switch but some who got them replaced early got the old part. The cruise failure is what resulted in my warranty replacement last week.
It gets really fun when you pull the "reduce speed" lever toward you and it first decides its going to turn cruise off, then figures that since cruise is off you must want the resume function and turns cruise back on at your original speed.
Old 12-24-2013, 12:18 AM   #1676
IB1
IB1's Avatar
Oddometer: 1,026
I am on set number 3. The first time the entire left cluster failed. The second time the cruise control button party failed. Now it should be a different model.
Past bikes: 09 BMW F800ST
Current ride: 2013 BMW R1200GS
On order: 2015 BMW R1200GSA
Yes, still a rookie
IB1 is offline   Reply With Quote
Old 12-24-2013, 05:00 AM   #1677
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,649
I hate to ask, and have no reason for doing so other than idle curiosity, but have there been any reports of failed final drives on the GSW yet?
Old 12-24-2013, 05:42 AM   #1678
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,916
I have not heard of any. Hopefully the stronger, for the K1600, final drive used by the GSW will reduce/eliminate premature failures.
Jim
Old 12-24-2013, 06:07 AM   #1679
pistole
Oddometer: 1,292
jim , could you pls elaborate on that. Was there a "stronger" final drive starting with the K16 ?
the K16 suffered from a laundry list of issues , but final drive failures does not seem to be one of them.
and did this K16 final drive migrate to the GSW ?
thanks.
pistole is offline   Reply With Quote
Old 12-24-2013, 07:22 AM   #1680
JimVonBaden
"Cool" Aid!
Oddometer: 53,916
thanks.
The K1600 got a completely revised FD, if for no other reason than the FD switched sides. The power output of the K1600 is a LOT higher than previous bikes, and changes were made to accommodate this. Though the part numbers are different, because the housing has to accommodate the fender mounts at least, it is expected that BMW standardized the basics of the FD, which means the Wetheads should have stronger FDs capable of handling more weight (the K1600 is a heavy bastid), and more power. Time will tell, but hopes are high.
Jim
Times are GMT -7.   It's 08:23 AM.
