Old 07-09-2013, 12:31 PM   #286
nwpa
Generally amused
Oddometer: 499
Originally Posted by oz97tj View Post
My dealer called last week to say my new switch has arrived. I need to get down there this week to have it replaced.
Mine arrived today; need to have it replaced now. Apparently a shipment made the states. Wonder if it's a new design?
nwpa is offline   Reply With Quote
Old 07-09-2013, 12:34 PM   #287
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
I think it's way to soon to see a redesign...unfortunately.
EJ_92606 is offline   Reply With Quote
Old 07-09-2013, 07:05 PM   #288
ironklad
Oddometer: 85
I've been told by my dealer that the switch has been redesigned and none available in the US at the moment. I still need to have them officially inspect mine but he's put one on order as a precaution.
ironklad is online now   Reply With Quote
Old 07-09-2013, 07:06 PM   #289
nwpa
Generally amused
Oddometer: 499
He may want to order a few...
Old 07-10-2013, 12:00 AM   #290
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Well given that the K16 had the same switches and issues and they installed them on the new GS as well, I think it's a little bit optimistic to think that all of a sudden they have redesigned and manufactured a new switch. Just because BMW has no parts in stock doesn't necessarily mean the part has been redesigned...it more likely just means they've had to replace a lot of broken switches and ran out of inventory. Perhaps your dealer can pull up the parts diagrams in the BMW system and show you the new part?
Old 07-10-2013, 12:22 AM   #291
NLS
My bike needs washing...
NLS's Avatar
Oddometer: 3,187
Ineed more probable.
NLS
My Blog
When the going gets tough, the tough get going...
NLS is offline   Reply With Quote
Old 07-10-2013, 12:29 AM   #292
Roadscum
Oddometer: 2,495
Yeh, just like the fuel strip issue...... How many years before that got addressed. They still put that sh!t system in the R12R. Before any design change occurs they first need to acknowledge a problem with the existing switch gear. That's not likely to happen for many years.
I hear the engineer that designed the fuel strip was promoted in put in charge of switches gear design!
Regards, Paul
"One of the things that make motorcycling so great is because it never fails to give you a feeling of freedom and adventure." - Steve McQueen
Roadscum is offline   Reply With Quote
Old 07-10-2013, 02:09 AM   #293
nwpa
Generally amused
Oddometer: 499
It does look like there is a superseded part number fwiw.
Old 07-10-2013, 06:41 AM   #294
smithdt
Oddometer: 83
Can you advise where your seeing the old and new part numbers?
thanks
smithdt is offline   Reply With Quote
Old 07-10-2013, 06:51 AM   #295
nwpa
Generally amused
Oddometer: 499
thanks
http://www.maxbmwmotorcycles.com/fic...1&rnd=04302013
Old 07-10-2013, 07:49 AM   #296
cug
Oddometer: 5,022
They don't. The R1200R doesn't have a fuel strip anymore - since 02/2013. It doesn't have a fuel level display anymore either ... just a warning light when you go on reserve. Same as if you didn't buy the On Board Computer.
And don't get me started on that - it's a completely shitty solution, but unfortunately typical "big corporation thinking".
cug is offline   Reply With Quote
Old 07-10-2013, 08:14 AM   #297
Roadscum
Oddometer: 2,495
I didn't realize they made that change in 2013. They fixed the problem by removing the fuel indicator. Clever engineering...
There's no reason to believe the "big corporation" is going to do it differently with the switch issue. No wait, they can't simply remove the switch gear can they?
BMW will start paying attention as soon as peeps stop buying the products, until then we're on our own.
I really really want a GS-L but not one that comes with issues designed in.
It's beyond my comprehension way that "big corporation" can't get it right, then won't make it right.
Rant over... Sorry.
Regards, Paul
Old 07-10-2013, 04:15 PM   #298
iride4u
iride4u's Avatar
Oddometer: 321
While I believe a small number of bike have switch issues, I wonder how many are caused by heavy fisted riders.
I know that I will take flack for this post, but I have been living with the new type of switch for over two years. Yes last year the switches on the GTL started to fail at the end of summer. Both were replaced under warranty with new part numbers.
We here about problems over and over but not about bikes without problems and there are many more of them.
iride4u is offline   Reply With Quote
Old 07-10-2013, 04:19 PM   #299
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 19,202
Are you suggesting that some of the switch cluster failures are operator error?
Old 07-10-2013, 05:12 PM   #300
nwpa
Generally amused
Oddometer: 499
Mine started failing when I used the right turn signal on the highway. The turnsignal starting turning off the cruise. After a week the cruise would not stay on at all. The bike was 13 days old.
I guarantee you the failures are not due to "heavy fisted" riders. You're even talking about failed switches on your bike. Were you heavy fisted?
As for hearing about bikes with problems, read the title of this thread. This isn't the "tell us about the problems you don't have" thread.
We've had one post on a starter failure, one post on a leaking jug, one on a cracked windscreen, a couple on rear brake wear, and a lot on both front end vibration/wobble and left switch failure. These are not rare issues. (I probably missed some reported issues...these are the ones that come to mind).
Times are GMT -7.   It's 05:13 AM.
