Old 05-26-2013, 06:58 AM   #91
atg OP
Oddometer: 225
Originally Posted by Go_With_The_Flow View Post
I want to thank 'gr8ridn, ATG, NWPA' and others who have responded. Has anyone tried to copy the full OS from a Navigator IV and transfer all data to the Zumo 660??
As Garmin stated, the units are identical and all the pins are active on the units.
Im wondering if it could be resolved with a simple transfer of all the OS?!
I certainly would be quite interested to know the results of such experience !
Andre
atg is offline   Reply With Quote
Old 05-26-2013, 08:03 AM   #92
NLS
My bike needs washing...
NLS's Avatar
Oddometer: 3,177
Originally Posted by atg View Post
Hi NLS;
From what I could find out there are 3 wires out of the rotary switch. They run straight to the main electronic module located under the rider seat.
I believe that the bike's CPU send its commands to the GPS through a single wire, the third wire on the triple wire plug.
Andre
Interesting.
So...
a) BMW most probably can utilize the wheel otherwise if they wish on an update.
b) Would be interesting to understand what kind of protocol GPS receives from a single wire (it must be some kind of serial connection).
NLS
My Blog
When the going gets tough, the tough get going...
NLS is offline   Reply With Quote
Old 05-26-2013, 08:04 AM   #93
maximo de la maximus
Abracadabra Holmes
maximo de la maximus's Avatar
Oddometer: 56
check this out...
If you don't absolutely have to have use of the control wheel AND you want wired audio AND you don't want to fidget with the three wires:
http://www.advrider.com/forums/showthread.php?t=876608
The electrical tape solution works. I did this and carefully drilled a hole in the GPS bracket aligning with the audio input. After threading an extension under the body work a "permanent" input jack resides lower right above my right leg.
MdlM
maximo de la maximus is offline   Reply With Quote
Old 05-26-2013, 08:30 AM   #94
MaddBrit
Now officially a Yank.
MaddBrit's Avatar
Oddometer: 23,852
It doesn't sound like there any any major problems with this one, and the switchgear issue is getting sorted and will no doubt get better moving forward. Thats very good news.
Have any of you put any real mileage in yet? (meaning over 5K).
I had enough issues with my 06 GSA (first production run) to keep me off new BMW's. It will be interesting to see if the drive chain is now sorted with the new model.
PS I bought a new Victory just over a year ago. I am very pleased to report not a single issue - not a squeak or a leak - in 13K miles. As it should be.
Just happy :)
MaddBrit is offline   Reply With Quote
Old 05-26-2013, 08:31 AM   #95
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,646
Who has the most miles on their new Sporkhead?
Old 05-26-2013, 11:02 AM   #96
nwpa
Generally amused
Oddometer: 499
Here are some pictures of the windscreen cracking I'm seeing
nwpa is offline   Reply With Quote
Old 05-26-2013, 11:49 AM   #97
PhaseShifter
PhaseShifter's Avatar
Oddometer: 186
Almost looks like "china" quality
how much you payed for this German top quality product?
it's a bloody shame this hapens with top-priced bikes
PhaseShifter is offline   Reply With Quote
Old 05-26-2013, 12:41 PM   #98
oz97tj
oz97tj's Avatar
Oddometer: 833
Looks like someone get over zealous while torqueing down the windshield mounts. Thats about the only thing that would cause fracturing like that to the windshield. That would also mean it was the dealer who did this.
'15 KTM 500 EXC / '13 BMW 1200 GSW / '05 Honda ST1300 / '04 Husqvarna TE510
oz97tj is online now   Reply With Quote
Old 05-26-2013, 12:44 PM   #99
nwpa
Generally amused
Oddometer: 499
I look at the value of this thread not as a chance to bash anything, but simply to share issues that are popping up, to compare experiences with other owners in case there is a trend, pattern, or experience that can be of value to owners.
I love the bike. So far, without a doubt, it is the best I've ever experienced. This issue may be a quality issue, or it may be a part that was overtightened. I haven't seen anyone else mention it, but was sharing here to have owners keep an eye out.
Old 05-26-2013, 12:46 PM   #100
nwpa
Generally amused
Oddometer: 499
I was wondering that -- do these shields come installed or does the dealer put the shields on? (This was the same dealer that broke the pannier lever).
Old 05-26-2013, 01:13 PM   #101
268
268's Avatar
Oddometer: 168
The dealer definitely has to put the screen on. Saw mine being uncradled and the screen wasn't on te bike.
268 is offline   Reply With Quote
Old 05-26-2013, 01:16 PM   #102
oz97tj
oz97tj's Avatar
Oddometer: 833
Yup, dealer puts them on. Sounds like your dealer has someone who relies on muscle for everything instead of finesse.
Old 05-26-2013, 03:44 PM   #103
NLS
NLS's Avatar
Oddometer: 3,177
Exactly. This is definitely dealer installed.
This happened on my GS and was a mix of dealer error (too tight) and some over-powered pressure cleaner (in some gas station somewhere). I didn't notice it right there, else I would make them pay for it.
Dealer replaced the screen anyway.
Second time around, I also installed rubber rings myself. Maybe this is also a solution for '13.
NLS
My Blog
Old 05-27-2013, 04:28 AM   #104
Andylaser
Heavy Metal
Andylaser's Avatar
Oddometer: 1,095
The GPS firmware is tied to the PCB electronic serial number. Just transferring it across wont work. This is also why you cant download the Nav V OS on to the Zumo.
You would need to hack some pretty robust security algorithms to do it.
Sent from my binary data processing apparatus using magic and wires
OLD SKOOL HEAVY METAL
Andylaser is offline   Reply With Quote
Old 06-03-2013, 03:55 AM   #105
IB1
IB1's Avatar
Oddometer: 1,026
I was in germany for a long weekend and had quite a bit of rain during 2days. On saturday my left hand control cluster failed. No turning signal, no horns, (DRL switched to night mode), ... On sundayevening the system sometimes came back very briefly after starting. (DRL symbol in the instrument flickered) and went back out immediately after.
The garage will replace it tomorrow.
IB1 is offline   Reply With Quote
Times are GMT -7.   It's 03:45 AM.
