Old 10-30-2013, 01:39 PM   #1171
ShaftEd
ShaftEd's Avatar
Oddometer: 3,351
Originally Posted by gsrich View Post
You can fix the gas cap problem yourself. You may not want to!
Look for an o-ring that is not quite as fat. My BMW dealer had one on the shelf that fit an older bike, maybe the oil pump seal for a older boxer. Re-assemble the gas cap using the thinner o-ring and the stupid cap will stay together and seal just fine.
My new cap took 4 weeks to arrive from Germany. The old cap with the thin o-ring stayed together the entire 4 weeks. The new cap has stayed together. I think someone at the factory is using the wrong part.
gsrich, Thanks for this info. I was able to go to San Diego BMW where Geoff in parts found the correct o-ring. Seems to work just fine. Seals the cap and tank without putting to much pressure to have it all fall apart. In case anyone needs this fix, here's the p/n 11147722366.
ShaftEd is offline   Reply With Quote
Old 10-30-2013, 01:45 PM   #1172
JetSpeed
Naviator
JetSpeed's Avatar
Oddometer: 3,343
BMW is updating the maintenance schedule for the new GSW, as we all know there is no alternator belt change required on this bike but they are going to require replacing the water-pump every 12,000 miles as part of the scheduled maintenance, this is of course, if your water pump lasts that long.
Reminds me of my old KTM 950 Adventure.
Pull chocks.
JetSpeed screwed with this post 10-30-2013 at 01:58 PM
JetSpeed is offline   Reply With Quote
Old 10-30-2013, 01:51 PM   #1173
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,451
Originally Posted by JetSpeed View Post
BMW is updating the maintenance schedule for the new GSW, as we all know there is alternator belt change required on this bike but they are going to require replacing the water-pump every 12,000 miles as part of the scheduled maintenance, this is of course, if your water pump lasts that long.
You. Have. Got. To. Be. Kidding....
Settles it for me..I won't be looking into a GSA any longer...
That's two times a year for me....
"Ignorance is a powerful tool when applied at just the right time..sometimes even surpassing knowledge.." EJ Potter
Bill-66 is offline   Reply With Quote
Old 10-30-2013, 02:01 PM   #1174
JetSpeed
Naviator
JetSpeed's Avatar
Oddometer: 3,343
I'm kidding, but that is what KTM did after discovering the LC8 water pumps crapped out in short order, they turned the pumps into a scheduled maintenance item and required replacement every 10k miles.
Pull chocks.
Old 10-30-2013, 02:10 PM   #1175
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,451
Old 10-30-2013, 02:21 PM   #1176
deacon51
deacon51's Avatar
Oddometer: 381
Originally Posted by ShaftEd View Post
Gas cap just fell apart in my hands. You can see where the o-ring that give tension to the cap so it doesn't leak is too thick. How the hell does BMW screw up something so simple as a gas cap
I got mine back together and it seems to be holding. Dealership said it took six weeks to get one in for the last guy, will give me a call.
deacon51 is offline   Reply With Quote
Old 10-30-2013, 02:36 PM   #1177
Roadscum
Oddometer: 2,426
Regards, Paul
"One of the things that make motorcycling so great is because it never fails to give you a feeling of freedom and adventure." - Steve McQueen
Roadscum is offline   Reply With Quote
Old 10-30-2013, 04:40 PM   #1178
Voz
Voz's Avatar
Oddometer: 491
So my GSW went into the dealer after losing power and displaying the check engine icons.
Dealer just called to say Left Throttle Body sensor. After I parked it, started up and all ok and the fault has not repeated for them.
Codes are now reset and the bike is ready to pickup.
Sydney, Australia
2013 R1200 GSW Red - Blown Engine & Gearbox (clutch basket nut issue) - AUG 14
2015 R1200 GSW White - NOV 14
Voz screwed with this post 08-05-2014 at 05:49 AM
Voz is offline   Reply With Quote
Old 10-30-2013, 05:38 PM   #1179
bobbybob
Oddometer: 707
Originally Posted by Voz View Post
They started going on about the Canbus system and how I may have contributed to it by splicing in relays for my GPS and splicing into the indicators and brakes for my Admore LED lights on my Givi top box.
I would have asked them right then and there to explain how that could have contributed to the throttle body sensor issue. Sounds like typical dealer/BMW bs, trying to pin a component problem on the owner.
bobbybob is offline   Reply With Quote
Old 10-30-2013, 06:54 PM   #1180
stevie88
That's gotta hurt
stevie88's Avatar
Oddometer: 19,309
Cool, that is easy to remember. Replace the final drive every other water pump change.
I wasn't born with enough middle fingers.
stevie88 is offline   Reply With Quote
Old 10-30-2013, 08:00 PM   #1181
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,451
Old 10-31-2013, 03:06 AM   #1182
NLS
My bike needs washing...
NLS's Avatar
Oddometer: 3,174
I agree that sometimes dealers (of any product) do have the tendency to try to pin the owner even for unrelated sh*t. Yet, it is not always the case. Sometimes they are right. We cannot expect to cut wires and re-route things and still keep the warranty intact. Yes that someone installed a new non-approved windscreen cannot be blamed if the rear break fails, but sometimes is not that clear.
NLS
My Blog
When the going gets tough, the tough get going...
NLS is offline   Reply With Quote
Old 10-31-2013, 03:12 AM   #1183
NLS
NLS's Avatar
Oddometer: 3,174
Nice one.
Now I'll wait for your next supportive to BMW joke for a change (...that will never happen).
In stand-up comedy the comedian hits you right where your soft spot is, in front of everybody. He usually gets this "right" because (a) sooner or later does the same to himself and (b) you actually pay him to do that to you. I don't see this here.
Such cases I will just call "Old Guys in Muppet Show Syndrome". Nobody ever forced them to see the show, yet they did it (just to find faults in it) for some unknown reason.
NLS
My Blog
Old 10-31-2013, 04:19 AM   #1184
Russ
Russ's Avatar
Oddometer: 16,906
If you read this thread BMW must mean -- Bitch, Moan and Whine .
I've done 18 000K on mine and have enjoyed every single moment on the bike, the clutch reservoir weeps a bit, who cares the dealer will sort it out at the next service.
Ride the bikes, let the service guy's worry about things, all LC Gs's are under warrantee for a long time to come
Russ screwed with this post 10-31-2013 at 04:54 AM
Russ is offline   Reply With Quote
Old 10-31-2013, 06:04 AM   #1185
bobbybob
Oddometer: 707
So explain how it affects it? Sounds like the dealer has convinced you to assume the position.
Times are GMT -7.   It's 04:30 AM.
