Old 05-07-2013, 02:47 PM   #1
2Gordons OP
Parts left over...
Oddometer: 196
Old Carb Question
Hey All:
Time to work on the old beater bike that my bride rides occasionally. I went to start it up, and upon turning on the tank petcock, gas started running out the drain-tube on one of the carbs. I assume that's not right.
The bike is a Honda CM400T (twin) circa 1980 vintage. Gas appears to be running straight through the left carb, like a spigot. I'm wondering if it's a stuck float? Any tips what else to look for before I dive in? No gas leaking out the petcock, or fuel-line to the carbs.
Any good sources for rebuild kits for these old pumpers if that's what it comes to? This one doesn't go to the shop much... I usually try to muddle through on the old girl (the bike). Thanks for any input.
2G
History is what makes this site what it is. Get some. - Trip
My theory is if it has red pumps or batteries it is gonna give you trouble. - Vermin
2Gordons is offline   Reply With Quote
Old 05-07-2013, 02:54 PM   #2
emti
Oddometer: 271
It sounds like the float is stuck and or the needle is not seating tight. Try tapping on the float bowl, when that dosnt work you will need to remove the float bowl and see what is in there that is not clean fuel. emti
emti is offline   Reply With Quote
Old 05-08-2013, 02:41 PM   #3
groop
So much to ponder
groop's Avatar
Oddometer: 3,305
I agree that it sounds like a stuck float. As far as ordering supplies, I would guess just about everyone would carry rebuild kits as Honda used the same carbs on many models for many years. Is it a Keihen?
Anyhow, here's the BB page
http://www.bikebandit.com/houseofmotorcycles/1980-honda-cm400t/o/m2129#sch39743
Because you cannot eat a salad with a spork.
groop is offline   Reply With Quote
Old 05-08-2013, 03:27 PM   #4
emti
Oddometer: 271
Or try motorcyclecarbs.com emti
Old 05-08-2013, 09:39 PM   #5
qkenf4u
Oddometer: 201
Cool2
pull it/them off and soak them in carb cleaner/pine-sol (check out the thread on here) , get them clean and rebuild them with the kits on ebay
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
qkenf4u is offline   Reply With Quote
Old 05-08-2013, 09:43 PM   #6
8lives
Dharma Bum
8lives's Avatar
Oddometer: 2,022
But I always tap first,2nd blow through the fuel line,and if that doesn't get ya results then take it apart,banging with a wrench and a blow job will often loosen things up and stop the free flow.
What would you do if you weren't afraid?
Bobcat Goldthwait is my mentor.
8lives is offline   Reply With Quote
Old 05-10-2013, 12:39 PM   #7
2Gordons OP
Parts left over...
Oddometer: 196
Thanks for the tips.
Got it stripped down most of the way- 1 stuck bolt I can't get to. Need to buy a particular wrench, then I'll try and get them off this weekend. There's always one fastener on an old bike that won't budge...
Times are GMT -7.   It's 03:29 PM.
