Old 05-08-2013, 04:49 PM   #1
Chunche OP
Forever fixin things
Chunche's Avatar
Oddometer: 12
New guy, DT175 woes
My uncle had this DT175 sitting in his garage for 15 years, then one day he decided he wanted it gone. When he called and offered to just give it to me, the obvious response was a definite yes. Brought it home, drained and cleaned the gas tank, petcock, and carb (which was stuck closed). It has an auto oiling system for the gas, but my uncle thought it didn't work for some reason. So just to be sure I disconnected that and mixed up some 32:1 gas. After about ten kicks I got it to fire up and run, and then even got to ride it around the block a few times. My buddy hopped on it, took off down the street and then I got the "hey come help me push" phone call. Long story short, the throttle slide had a big gouge in it from somebody trying to pry it open with a screwdriver, and the carb body had a matching gouge. The throttle got stuck wide open and my buddy panicked and couldn't figure out how to shut it off so it ran for a few minutes wide open. Ordered a new carb on ebay, hooked it up and now it won't start at all. It won't even try and burp, not with starter fluid, not on gas, nothing. My first thought was spark, but I pulled the plug and it's got a strong blue spark. I'm fairly certain it's getting gas, but even if it wasn't it should still try and do something with the starter fluid. I got a compression tester from oreilly's and it read 60 PSI. I put a little two stroke oil down the whole and retested and got 70 PSI. I read a few places online it should have way higher compression than that? Maybe the rings fried from being run wide open? And would low compression be enough to have it not even try and start? I'm new to 2 strokes so this is all a learning process for me
and a pic of the bike for fun
Chunche is offline   Reply With Quote
Old 05-08-2013, 06:15 PM   #2
D.T.
Difficult but useful
D.T.'s Avatar
Oddometer: 11,932
I had one of those in the 125 version. Had a terrible flat spot in the jetting I remember.
Didn't hit the kill switch??
Those were prone to rusting the inside of the motor. I would check for that. Too late? 60-70 is around the bare minimum for pressure. Maybe the rings got fried.
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 05-08-2013, 11:15 PM   #3
Chunche OP
Chunche's Avatar
Oddometer: 12
So when we got it started, we had unhooked the killswitch and ignition switch. I don't know why, but somehow the bike is wired to still have spark with those unhooked. Had it been me, I would have just yanked the wire off the spark plug to kill it. My buddy didn't think about this and tried to kill it by dumping the clutch but it just kept going on him. Finally got it pointed up a hill in third to kill it.
Old 05-09-2013, 05:04 AM   #4
Highside>Lowside
Hairier Than Thou
Highside>Lowside's Avatar
Oddometer: 1,077
Eek
Is the kill switch now connected and funtioning correctly??
If not, that is your first order of business...
00 M944,95 620RXC,82 FT500,85 V65 Sabre,01 1150GS,82 XJ650r,91 XV920r,82 V50 Monza,77 TT500, R75/6, etc...
Highside>Lowside is offline   Reply With Quote
Old 05-09-2013, 07:48 AM   #5
mudgepondexpress
Oddometer: 1,168
I love old DT's! Your is a 79 I believe...so here is what I can tell you.
1) File that gouge down with a file and sandpaper. Done right it will make -0- difference in the running of the DT.
2) Jetting stock sucks! Mine was way too rich and I had to go down 1 on the pilot and 2 on the main. Don't do this unless you know what you are doing.
3) The ignition is a continuation of ground...ala it breaks the ground, not the hot side of the system.
4) The autolube systems is awesome on these. Just disconnect the hose from the carb and plug the barb. run it on premix and make sure the autolube tank has a good supply. After a while you should see oil come out from the hose. It is a very small amount and doesn't shoot out, kind of dribbles (think prostrate problems). That is all you need! If it works hook it back up and start using straigt gasoline.
5) Don't forget the 175 is a 6 speed. Mine could hit 80+ on a good day with no wind and flat...but throw in a headwind and 65 was the best it could do. No matter how hard I rode it (and I rode it with a light switch throttle), I would get 58 mpg.
6) 18 hp and 216 or so lbs...it is a fun little bike. I miss mine greatly....wish I had it back.
7) Don't forget a new spark plug...D8ES I believe.
Kenny
mudgepondexpress is offline   Reply With Quote
Old 05-09-2013, 09:43 AM   #6
Chunche OP
Chunche's Avatar
Oddometer: 12
Yes, I hooked it back up to avoid the same problem
Kenny
I got a new carb off ebay for cheap, that functions properly.
I'll worry about jetting when it actually runs
I pulled the gear out that runs the autolube pump so it wasn't just running the pump dry in case it does function. After I get the motor back together, I'll probably test the autolube system. It would be nice to be able to fill up at gas stations with worrying about mixing oil.
A light little bike with decent power + I'm a pretty light guy = what's going to be a very fun bike
Spark plug, check.
Chunche screwed with this post 05-09-2013 at 10:31 PM Reason: I can't spell apparently
Old 05-10-2013, 08:05 AM   #7
dan-c
Back
dan-c's Avatar
Oddometer: 13,725
Under the tank is a 6 way connector that you can uplug that bypasses the ignition switch, lights, etc so you can take off the lights and shit like that. Unplug it and see if it runs.
dan-c is offline   Reply With Quote
Old 05-10-2013, 08:09 AM   #8
woods wizard
woods wizard's Avatar
Oddometer: 891
I hate to say it but you prbably fried the top end. Exact same thing happened to my CT175. Throttle stuck wide open after a failed hillclimb, landed on throttle tube & held it wide open & spinning around in circles trying to cut off my feet as I tried to get it stopped. Upon teardown found it had taken a chunk out of the cylinder. Yours may not be that severe, but you will need to pull the cyl. off & inspect. Hope it didnt destroy the cyl. Good Luck.
Husaberg 570FE Tagged & Tarded / KTM 250 EXC
woods wizard is offline   Reply With Quote
Old 05-10-2013, 09:06 AM   #9
Scootern29
Scootern29's Avatar
Oddometer: 533
I concur with woods wizard. The chances are it siezed and stuck the rings. You will need to pull the top end. You may be able to get away with sanding the piston and freeing up the rings. But while you have it apart have it measured and maybe a new bore and piston is in order.
Scootern29 is offline   Reply With Quote
Old 05-10-2013, 10:36 PM   #10
Chunche OP
Chunche's Avatar
Oddometer: 12
Well I may have found the culprit. I pulled the cylinder, the gaskets looked good but I found this
The top ring had a weird bend on the front of it, to the point where it didn't want to come off of the piston without some help. As you can see the piston has a matching bend. Other than that the piston didn't have any gouges or broken bits to it. The bend was on the very front, directly in front of the exhaust.
The cylinder didn't appear to be damaged however.
That's a picture of the exhaust port, where the bent ring was. The spot on top is just an oil spot, you can see the smudge where it wiped away with my finger. No gouges or anything that can be felt with a finger. So maybe just a light hone and a new piston and rings (and gaskets obviously)?
The only thing that concerns me is a comment on another forum I posted the same question about the crank. Someone pointed out to me I ran the bike with 15 year old crankcase oil in it because I forgot to change it. How does one go about checking if the bottom end is trashed too? The connecting rod moves side to side about an 1/8 inch, does this indicate worn bearings?
Old 05-10-2013, 10:44 PM   #11
Valleyrider
I Survived The '60s
Valleyrider's Avatar
Oddometer: 1,883
Your compression is not going to get the motor started.
You should have around 120.. or somewhere there about.
Woods Wizard and Scootern 29 are correct.
http://www.flickr.com/photos/14934865@N07/
'07 1250 Bandit, '06 650 VStrom, '78 SR500E
'68 Yamaha DT1, '78 TT500 and no money
http://www.flickr.com/photos/48000856@N06/
Valleyrider is offline   Reply With Quote
Old 05-10-2013, 10:48 PM   #12
fallingoff
Oddometer: 3,677
brought back memories'
same bike and colour
could never kill it
once you get it sorted you will love it
cheers
fallingoff is offline   Reply With Quote
Old 05-10-2013, 10:54 PM   #13
joexr
Oddometer: 3,773
Valleyrider. What's the bike in your avatar? T500?
Old 05-11-2013, 12:08 AM   #14
spo123
Man About Town
spo123's Avatar
Oddometer: 853
Cool2
Your friend ruined the top end of the engine.
Good luck.....could be worse.....Plan on $250 or so.
spo
1973 /5 LWB Toaster
spo123 is offline   Reply With Quote
Old 05-11-2013, 04:15 PM   #15
Valleyrider
I Survived The '60s
Oddometer: 1,883
Yes, it was the cover of the Clymers manual. It's me from a magazine shoot at the old Orange County Raceway in Irvine Calif. Never knew that they were using me as a model!! No pay for it....
Times are GMT -7.   It's 08:24 AM.
