Old 05-11-2013, 04:41 PM   #16
joexr
Oddometer: 3,773
Originally Posted by Valleyrider View Post
Yes, it was the cover of the Clymers manual. It's me from a magazine shoot at the old Orange County Raceway in Irvine Calif. Never knew that they were using me as a model!! No pay for it....
Thought so. I had a '77 GT500. Had the Clymer manual too , but I don't remember the cover. Cool.
Old 05-11-2013, 05:58 PM   #17
baloneyskin daddy
bikaholic
Oddometer: 2,158
Are you sure the throttle isn't sticking wide open.
baloneyskin daddy is offline   Reply With Quote
Old 05-11-2013, 08:42 PM   #18
Chunche OP
Forever fixin things
Chunche's Avatar
Oddometer: 11
Well I may have found the culprit. I pulled the cylinder, the gaskets looked good but I found this
The top ring had a weird bend on the front of it, to the point where it didn't want to come off of the piston without some help. As you can see the piston has a matching bend. Other than that the piston didn't have any gouges or broken bits to it. The bend was on the very front, directly in front of the exhaust.
The cylinder didn't appear to be damaged however.
That's a picture of the exhaust port, where the bent ring was. The spot on top is just an oil spot, you can see the smudge where it wiped away with my finger. No gouges or anything that can be felt with a finger. So maybe just a light hone and a new piston and rings (and gaskets obviously)?
The only thing that concerns me is a comment on another forum I posted on about the crank. It was pointed out to me that I neglected to change the 15 year old crankcase oil (stupid mistake) and possibly damaged the crank. How does one go about checking if the bottom end is trashed too? Since it's this far apart I'd rather make sure everything else is working before I put it back together. The connecting rod moves side to side about an 1/8 inch, does this indicate worn bearings?
Chunche is offline   Reply With Quote
Old 05-11-2013, 10:07 PM   #19
Valleyrider
I Survived The '60s
Valleyrider's Avatar
Oddometer: 1,870
First, something went in or out the exhaust to do that kind of damage.
Do you have a strange rattle if you shake the exhaust pipe?
Some side to side play is normal at the piston end of the rod.
The important thing to look at is the crank end. Is there any discoloration of the rod? can you get any play if you lift the rod straight up and down with the rod at top dead center? If so, the crank will need freshening up/rebuilt.
The "Crankcase Oil" you refer to is not in the crank area. It lubricates the transmission. You should probably make sure it has the proper amount of oil in it, but it is not the cause or future cause of any crank issues.
http://www.flickr.com/photos/14934865@N07/
'07 1250 Bandit, '06 650 VStrom, '78 SR500E
'68 Yamaha DT1, '78 TT500 and no money
http://www.flickr.com/photos/48000856@N06/
Valleyrider is offline   Reply With Quote
Old 05-13-2013, 12:15 AM   #20
Chunche OP
Chunche's Avatar
Oddometer: 11
I believe the crank is ok, no discoloration, no play up and down. I did however get a chance to take a closer look at the cylinder, and I think you're right about some sort of debris entered the exhaust port. There's no rattle in the exhaust so I'm not sure where it would have come from. Could built up carbon cause such damage? Because there was quite a bit in the exhaust port. I also found damage to the cylinder wall that matched the damage to the piston and ring right above the port, so I'm going to take it down to a local bike shop tomorrow and see if it can be bored out, or if I'm looking at a new cylinder.
Old 05-13-2013, 05:17 AM   #21
joexr
Oddometer: 3,773
I think by rattle in the exhaust he meant the piece that went thru the motor is probably in the pipe now.
Old 05-14-2013, 12:26 PM   #22
Chunche OP
Chunche's Avatar
Oddometer: 11
Ok so I took it to a local bike shop, and can get it bored out for $62. He wasn't exactly sure how far they'd have to bore it out but I'm going to need oversize pistons and rings. Anyone know where to get parts for this bike? I looked on Wiseco's website and they have the pistons, in a few different oversizes but I can't seem to find bigger rings anywhere except a few random ones on ebay. I even went to the local yamaha dealership and they can't get any parts except the stock size piston and rings. Any suggestions on where else to look? I don't want to pay the guy to bore the cylinder only to find out I can't get the parts I need to put it back together
Old 05-14-2013, 12:53 PM   #23
WRW9751
7th Day Adventurist
WRW9751's Avatar
Oddometer: 449
The damaged ring was most likely due to a exhaust port that wasn't chanphored (sp) they probably didn't angle ground at the top of the port. If your tolerances are OK just replace the piston and rings.
WRW9751 is offline   Reply With Quote
Old 05-14-2013, 08:28 PM   #24
Chunche OP
Chunche's Avatar
Oddometer: 11
On the cylinder wall, directly above the exhaust port, there is a gouge out of the wall that matches exactly the bent ring. So I can't just put it back together because of the damage. As far as I know this motor has never even been apart, so nobody did any work to the exhaust port
Old 05-14-2013, 10:00 PM   #25
clicheche
clicheche's Avatar
Oddometer: 72
wicked get!
i have one too! (1980) but its red. i think i like the blue!
B8es ngk spark plug, to answer an earlier post.
adjust the carb as per the book and she'll kick right up once you get that piston taken care of.
the oil lube will work. i'm experiencing it as we speak.
http://s1346.photobucket.com/user/cl...tml?sort=3&o=1
-brent
(first they ignore you, then they laugh at you, then they fight you, then you win)
clicheche is offline   Reply With Quote
Old 05-16-2013, 09:19 AM   #26
gloud
Oddometer: 158
Just search ebay on DT175 piston they are out there, you share a piston with the rare YZ175 and a few other bikes. (I used to have one and had to buy 2 pistons over the 2 years I ran it as a daily driver. (One was bad jetting) the big thing is to make sure the piston has the windows on the skirt. they are good little bikes. I would check your bottom end really good to make sure none of the
bearings or bits came loose. and change out the crank seals. (if you don't you will likly be sorry as you can suck oil from the right and air from the left , the air one will cause you to run lean.
Oh and a thought, make sure your reeds are intact, if one broke off it could have caused this problem. (the bent ring/dent)
gloud screwed with this post 05-16-2013 at 01:12 PM
gloud is offline   Reply With Quote
Old 05-17-2013, 09:36 PM   #27
Chunche OP
Chunche's Avatar
Oddometer: 11
I will take a look at the reeds, thanks. I did find some pistons and rings on ebay, and they're actually close (ish) to my house at a bike shop. So I'm going to go take a look at them next week to make sure they're not super cheap chinese junkers
Times are GMT -7.   It's 07:03 PM.
