Old 05-08-2013, 07:51 PM   #1
themocksta OP
Lost in this place
themocksta's Avatar
Oddometer: 85
KLR 650 pre 08 turn signal issue
Searched the web and ADV, could not find what I am looking for.
Anyway. Have an 06 KLR 650, replaced the stock headlight bulb with a much brighter 80/100 W. Also changed the fuse from a 10A to a 15A.
Now headlight works great, front flashers won't work at all and back flashers are on solid (unless I'm high on the RPMs in which case they blink fast) if turn signal switch is on. Brake light works OK.
What to do? Are the stock turn signals not drawing enough current now? Does the wiring harness need to be upgraded?
Thanks for your help!
Carpe the shit out of the diem. -Unknown
"That beaver cowboy hat may not have said anything disrespectful but you have to quarantine it if it starts chewing on the furniture or building a dam in the living room" -jamespowers
themocksta is offline   Reply With Quote
Old 05-08-2013, 08:13 PM   #2
2wheelsrbest
Oddometer: 282
Does it all work correctly when stock bulb is back in?
Craigslist is like a snowstorm, every Flake is different.
2wheelsrbest is offline   Reply With Quote
Old 05-08-2013, 08:17 PM   #3
Unstable Rider
Moto Fotografist
Unstable Rider's Avatar
Oddometer: 2,628
Any of it LED based now?
Never do anything you would be uncomfortable explaining to the paramedics...
Unstable Rider is online now   Reply With Quote
Old 05-08-2013, 08:20 PM   #4
8lives
Dharma Bum
8lives's Avatar
Oddometer: 2,022
I would put the stock bulb back in and retrace your steps.
What would you do if you weren't afraid?
Bobcat Goldthwait is my mentor.
8lives is offline   Reply With Quote
Old 05-08-2013, 09:50 PM   #5
Beezer
Oddometer: 5,884
the 80 watt low beam is prolly drawing the voltage down when the rpms are low & the flasher doesn't like it. sometimes replacing the flasher will do it since they get old & the contacts get higher resistance over time. Or, go to a solid state flasher
edit.... wait..... the front signals turn on & don't flash, or don't turn on at all? the flasher needs both front & rear to make it flash on the standard system. if the rear is steady & the front is dark then the front is burnt out or the wire is disconnected, or there is corrosion in the socket or connections.
if both front & rear come on but just sit there its the flasher
Beezer is offline   Reply With Quote
Old 05-09-2013, 04:02 AM   #6
themocksta OP
Lost in this place
themocksta's Avatar
Oddometer: 85
Front signals are dark. None of new system is LED based.
Will recheck the connections.
Times are GMT -7.   It's 09:13 PM.
