Old 05-12-2013, 04:43 PM   #16
Captdan OP
Oddometer: 184
Originally Posted by ozmoses View Post
Great!
But looking at your sig line begs the question-how's that /2 runnin'?
Good question, the /2 cranks each time I try and runs like it should. Very little issues with the /2. Gotta love the old airheads!
1965 Cushman super silver eagle, 1968 BMW R-60/2, 1974 R-90/6 cafe, 2008 R-1200 GSA.
Captdan is offline   Reply With Quote
Old 05-12-2013, 06:46 PM   #17
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,535
Originally Posted by Captdan View Post
Just took the r90 on a short 25 mile back roard trip. Ran like a bat, and stops great. Let's see, I took the master cylinder apart, flushed, and cleaned it but never noticed anything out of the ordinary. When she died and had no power I Simply started trouble shooting and she came alive... In the end, fixed nothing definitive, or at least anything I could put my finger on that was wrong... But she's back in action!
Just needed attention. Like we are sometimes.
---Albert Einstein
Old 05-24-2013, 09:33 AM   #18
erappaport
pray for rain
erappaport's Avatar
Oddometer: 292
Thanks gents, all good info, I think I'll take it apart this weekend and see what I can find. A flush and new fluid can't hurt...
DOT 3 fluid for the ATE disc brakes?
erappaport is offline   Reply With Quote
Old 05-24-2013, 06:05 PM   #19
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,535
DOT 3 will work.
We are supposed to use DOT 4 but if not available # 3 will work. They mix. BTW they also mix with water, they are hygroscopic. They absorb moisture from the atmosphere. This causes corrosion in the system and the brakes are supposed to be thoroughly bled every year. That is enough new fluid run through the system to completely change all the fluid.
Do not use the fluids that do not absorb water. They are not compatible with our systems.
---Albert Einstein
Old 05-25-2013, 12:14 PM   #20
erappaport
pray for rain
erappaport's Avatar
Oddometer: 292
Thanks. Was accustomed to using DOT 4 for the later models with Brembo brakes, wasn't sure about the ATE system. Did NOT know that 3 & 4 were compatible, always kept them far apart for fear of confusion.
Presumably the shockingly expensive synthetic stuff (DOT 5.1, if I recall correctly) that my KTM asks for is not hygroscopic?
Old 05-25-2013, 08:01 PM   #21
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,535
I think you are right the 5.1 does not absorb water. It is Synthetic. Supposedly compatible with 3 & 4 but nobody has told me we can use it.
DOT 4 has a slightly higher boiling point than DOT 3.
---Albert Einstein
Old 05-26-2013, 09:17 AM   #22
Captdan OP
Oddometer: 184
fYI: O'Reilly auto parts has dot 4.
Old 05-26-2013, 09:30 AM   #23
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,353
Some guys never get a break....I hate it when a brake is broken. I broke a brake but then got a break when the broken brake unbroke itself.
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
Old 05-26-2013, 03:16 PM   #24
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,535
I usually go broke when I work on my brakes. Think I'll go sit by the brook and contemplate this.
---Albert Einstein
Times are GMT -7.   It's 10:49 AM.
