Old 10-29-2014, 01:17 PM   #1
Hill Climber OP
Oddometer: 318
Speedometer setting?
Does anyone know how to change the default setting of 2205 front wheel circumference to a lesser value?
I found this solution, but it doesn't apply to my 2012 990 Adv
Step one: Mode = Trip F
Step two: Hold both buttons for 5 seconds
Step three: hit "mode" until "19" shows...hit "mode" again until "17" shows
Step four: Hit "set"
08 ktm530
12 ktm990Adventure
Hill Climber is offline   Reply With Quote
Old 10-29-2014, 01:30 PM   #2
twisted-hog
twisted-hog's Avatar
Oddometer: 289
I'm curious on this also, speedo is out 5+km/hr at 70km/hr and up when checked with my Garmin.
I'd like to have my speedo bang on. I figure if it reads faster than I am going then the odometer will read higher also?
Couldn't resist I
Baja Cerveza Conquest
twisted-hog is offline   Reply With Quote
Old 10-29-2014, 01:35 PM   #3
Sumi
Sumi's Avatar
Oddometer: 1,780
http://www.advrider.com/forums/showp...13&postcount=8
it's the same for the non-R 2009+ 990s as well.
Old 10-29-2014, 01:39 PM   #4
Merlinx1
dreamer
Oddometer: 18
is there a solution for a 1190r?
Merlinx1 is offline   Reply With Quote
Old 10-29-2014, 01:44 PM   #5
Sumi
Sumi's Avatar
Oddometer: 1,780
I'm afraid there is not.
Old 10-29-2014, 02:27 PM   #6
Hill Climber OP
Oddometer: 318
Thanks for the link!!!!!!
Here's a Copy/Paste of the article:
I finally found the wire to disconnect!!! On the 990R, it's the brown/black wire.
I tried to disconnect what the could be 18 pin wire with no luck. Since there's no pink and no brown/grey wire, I tried the purple, it doesn't work. Finally, it was the brown/black one.
So to adjust the wheel size on a 2010 990R Adventure,
1- press MODE to go to TRIP 1
2- Hold the MODE key for around 10 sec
3- It will show actual wheel size. Use the MODE key to increase the wheel size and the SET key to decrease it
4- Hold the MODE and SET key to exit
I'm guessing that the Brown/Black wire is the Brown with a Black stripe?
And I'm guessing that afterwards you leave this one disconnected/cut?
08 ktm530
12 ktm990Adventure
Old 10-29-2014, 03:11 PM   #7
rean1mator
Oddometer: 179
Is this possible with a 2006 950?
2006 KTM 950 Adventure
rean1mator is offline   Reply With Quote
Old 10-29-2014, 03:28 PM   #8
wilmar13
Oddometer: 662
I have not done so, but people have posted on here that you can get your dealer to reflash your speedo to a 1190S or Superduke (programmed for a smaller wheel). The speedo and ECU are separate so I guess there is no real downside.
'14 KTM 1190-R
wilmar13 is offline   Reply With Quote
Old 10-29-2014, 03:45 PM   #9
Sumi
Sumi's Avatar
Oddometer: 1,780
It is. See first post of this very thread.
Old 10-29-2014, 06:15 PM   #10
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,137
Caveat
I went back to the default setting. At default, the speedo and the odo were both off, but oddly they were off by different percentages.
When I set for 19", the speedo was almost exactly in agreement with my GPS, but the odo was off by a greater percentage than it was before, but in the opposite direction.
I decided that a more accurate mileage reading for maintenance purposes was more important than an accurate speed reading, especially when the speedo error is on the safe side.
My bike is an early '04, but I wouldn't be surprised if all years have similar results.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 10-29-2014, 07:49 PM   #11
Whele
Oddometer: 54
A setting of 2140 gives me exact agreement with my Sat Nav on a flat road.
Whele is offline   Reply With Quote
Old 10-29-2014, 09:50 PM   #12
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,938
Depends on the tire.
"Son, you can't do both"
Old 10-30-2014, 05:12 AM   #13
Whele
Oddometer: 54
Sure, and even the amount of wear on the same tyre makes a difference over its lifetime. However I am not sure I am so concerned about the 1 or 2 km/h difference. In standard form the discrepancy was 14km/h at 80km/h
Old 10-31-2014, 01:12 AM   #14
fridgyis
Fridgy
Oddometer: 49
Speedo change
On the990 there is no need to cut the wire. The connector will come apart with a small pick on either sides.......carful it is fragile. I have no pictures but it can be done. Remove the brown black wire then the function will work as it did on earlier models. I simply put some heat shrink on it and tied it back.
Good luck!
fridgyis is offline   Reply With Quote
Old 11-02-2014, 11:39 PM   #15
Hill Climber OP
Oddometer: 318
Good luck!
Thanks. I'll give this a go. (Like the idea of protecting the open pin with heat shrink)
Can anyone think of a reason why one would want to re-connect this connector ever again?
08 ktm530
12 ktm990Adventure
Times are GMT -7.   It's 05:07 AM.
