Old 11-20-2013, 07:10 AM   #31
Maoule
Maoule's Avatar
Oddometer: 552
I got the steel forged ones and modified them a bit. First, I drilled and countersunk 10mm holes the length of the irons; that lightened them about 2-3 ozs. each. Next, I narrowed and rounded the spoon ends to ~5/8" then smoothed out the finish and polished the ends. Lastly, I smoothed and polished the bead breaker ends. The forks slip under the rim flange fairly easy and, even though they'll still scratch the paint, the spoon ends don't gouge the aluminum as before.
Maoule is offline   Reply With Quote
Old 11-21-2013, 03:16 AM   #32
genghis9021
Arak Connoisseur
genghis9021's Avatar
Oddometer: 239
Motion Pro bead breaker levers
Originally Posted by ciedema View Post
As I said I don't like the side stand. It works for sure, but is awkward if you are by yourself on a fully loaded bike. These are light and faster than using the side stand.
Yeah that is complete crap. They great to use I have used them heaps of times, as for weight they weigh 9 ounces nothing.
Um, what he said.
I've used them less than 10 times but . . . my GOD they work well. Everyone who's watched me use them has expressed near awe at their efficiency.
Nobody blinked when I mentioned the price. And while I prefer the normal aluminum MP levers . . . these are a fine 3rd, if you really need it.
2011 Husky TE 630 2011 Husaberg FE 570S
2006 KTM 950 'S' ADV 2005 Suzuki DRZ 400 SM
"The perfect is the enemy of the good." 4 bikes in 3 countries.
Orange, it's the new black Tour.
genghis9021 is offline   Reply With Quote
Old 11-21-2013, 07:52 PM   #33
5 speed
Oddometer: 949
[QUOTE=ciedema;21370657]I can do that with anything other the 4" rim on the back of the Adventure, generally not even that extreme, a quick lever under the edge of the rim and bang it is done, but I can't do it this rim due the safety bead. I could be to unco though :)
I agree; bought these and received a week before my first flat on the 950; very lucky for me. They work like a charm. The easiest I have ever had actually and it was the rear. Nicely made as well.
5 speed is offline   Reply With Quote
Old 02-13-2014, 02:08 PM   #34
Dan Diego
Oddometer: 1,017
Comments on the pros and cons of tbe forged steel vs. aluminum ones?
The steel ones appear heavier and longer but could be used as tire irons.
The shorter ones would pack easier but don't look useful as irons.
Thoughts?
I have no interest in living a balanced life. I want a life of adventure.
Dan Diego is online now   Reply With Quote
Old 02-13-2014, 02:23 PM   #35
catalina38
Contrarian
Oddometer: 1,659
I own the longer steel version and they fit under the seat of my 990R, I have only used them at home but they easily broke the bead with a 908RR on the stock rear rim. I got them for the extra length and leverage since the 908RR's can be tough to remove and side stand method can be inconvenient depending on the trail conditions. I used the short aluminum version recently on a buddies dirt bike as tire irons and they worked fine, but didn't try the bead breaking feature.
http://www.motionpro.com/motorcycle/partno/08-0536/
A mangy man chasing a cautionary tale
Lurking more and posting less
KTM 990R 500EXC
catalina38 is offline   Reply With Quote
Old 02-13-2014, 02:28 PM   #36
crazybrit
crazybrit's Avatar
Oddometer: 8,559
I didn't even know there were two versions. I see now there are:
steel: http://www.motionpro.com/motorcycle/partno/08-0536/
alum: http://www.motionpro.com/motorcycle/partno/08-0519/
I recently bought the (shorter, more expensive aluminum version) but have yet to use them. I'd probably only ever need them on the 950 as I have no issue breaking dirtbike beads using standard 6" irons. So for 950-only use if the longer steel ones fit under the seat they might be the way to go. They are cheaper and I can't imagine any less-effective.
Expect more replies saying you don't need either and to just use the side-stand
crazybrit screwed with this post 02-13-2014 at 02:33 PM
crazybrit is offline   Reply With Quote
Old 02-13-2014, 02:36 PM   #37
bomose
bomose's Avatar
Oddometer: 1,284
You just need the sidestand. Kidding. I have the shorter ones and was able to break the bead on an '04 950. It surprised me, but after spending the money I was sure glad..
I prefer a short life with width to a narrow one with length-Avicenna
http://www.advrider.com/forums/showthread.php?t=810149 Ouray Adv
http://www.advrider.com/forums/showthread.php?t=800723 Cortez & Moab
http://www.advrider.com/forums/showt...=955211Chasing Dinosaurs
bomose is offline   Reply With Quote
Old 02-13-2014, 05:44 PM   #38
Themastermike
Passin gas
Themastermike's Avatar
Oddometer: 812
Every one talks of the side stand not being mounted the best then they want to use as a bead breaker? No thanks. And yes, my bike had the beef kit on it.
MP Al u menium bead breakers work well for breaking and spooning of a used rubber.
Sent from my DROIDX using Tapatalk 2
BBF 03-09-13 "It is cool. I was playing dakar racer It truly was a gr8 day of riding you bitch"
Themastermike is online now   Reply With Quote
Old 02-13-2014, 07:48 PM   #39
pne
pne's Avatar
Oddometer: 886
can these things break some stiff touring tubeless tires? seems like I could snap the tips off those aluminum ones trying!
Touring USA on a KTM Superduke, I have no idea what I'm doing:
http://advrider.com/forums/showthread.php?t=890358
pne is offline   Reply With Quote
Old 02-13-2014, 08:04 PM   #40
ciedema OP
мотоциклист
ciedema's Avatar
Oddometer: 1,971
I haven't tried - but I think they would work just fine. They are really quite strong.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Old 02-13-2014, 09:35 PM   #41
jonz
Miles are my mantra
jonz's Avatar
Oddometer: 2,436
I broke the beads on my ST1300 using the small aluminum ones.
JONZ
KTM 950 SE, KTM640 ADV ( Hibachi, risen from the ashes)
KTM520EXC (broken), KTM 400XC (the replacement)
Honda ST1300 ABS (newest addition to the stable)
STOC #326 IBA #217
jonz is offline   Reply With Quote
Old 02-13-2014, 10:58 PM   #42
woodchuckexc
Oddometer: 801
I have the alum MP breakers. Nice tool however I did have trouble breaking the bead on a Mefo mounted on my stock wheel. I ended up using the side stand on my 300. I will carry the MP tool with me so I can get out of a pickle but if I have a buddy with me I will use his side stand.
woodchuckexc is offline   Reply With Quote
Old 02-22-2014, 08:54 PM   #43
Monterey_BS
On or Off - not sure
Monterey_BS's Avatar
Oddometer: 249
Singing with the band...
I've a set of the AL breakers and have found they work as advertised on my 690 and 950. Although the sidestand method does indeed work, I don't always have another sidestand available.
Bob in Monterey
Monterey_BS is offline   Reply With Quote
Old 02-22-2014, 09:19 PM   #44
tacosupreme
tacosupreme's Avatar
Oddometer: 292
I used the aluminum ones to bust down my 37" military tires on double beadlocks. To make it extra interesting, when I assembled them several years ago the paint was still wet really welding the bead. I tried everything to get the bead to break. Sledgehammer. Hilift jack. Tire spoons and a sledgehammer. I was to the point that I was about to get out the sawzall and cut the old tires off. In desperation, I grabbed the aluminum breakers off the 990 and instantly felt like an idiot. I could break the bead with one hand. It's amazing the amount of leverage exerted with these things.
'12 990 with some orange stuff on it to make it go faster.
tacosupreme is offline   Reply With Quote
Old 02-23-2014, 05:36 AM   #45
5 speed
Oddometer: 949
Originally Posted by crazybrit View Post
I think by now, EVERY person understands that the side-stand trick exists. WE GET IT. We don't need another post stating it. This thread isn't titled "what technique should I use to break the bead", it's titled " Motion Pro - BeadPro Tire Bead Breaker and Lever Tool".
Please try to honor the topic/spirit of a thread, if you can't, then noone is forcing you to post on it.
And in that honor, these things are great!!! As you state the rear is quite the pain and most things mention may or may not work; example the original tire was on the bike for 3 years down here in the florida heat. Pretty much stuck on. Ended up taking that one to the shop as everything I tried failed.
Had a set of these for my blowout and once they are in there, 2 minutes and the bead is broken. Well worth the money and you know they are going to work. Whats not to like? Fully recommended.
Times are GMT -7.   It's 12:37 PM.
