Old 05-12-2013, 12:32 AM   #16
speedmonkey7 OP
speedmonkey7's Avatar
Oddometer: 337
Originally Posted by geometrician View Post
No mention has been made as to how the rear preload has been set- the differences in full-hard vs full-soft is quite a bit, and effects it on the side stand as well as when riding.
run the preload adjuster all the way in and count the turns out. The adjuster needs to be moved periodically to keep it from seizing, which can be pricey to fix when the knob breaks off in your hand
depending on your weight you may need a rear spring to get your sag in the ballpark
Currently I am running the manuals sport settings with another full turn on the preload both front and rear. I also just found a set of. 54 fork springs that I'll be installing. For now I I figured I'd give the rear a couple of extra turns on the preload. If that sucks I guess I'll go for a rear spring. I weigh around 230 with gear but am losing weight not gaining!
Sent from my SAMSUNG-SGH-I997 using Tapatalk 2
Speedmonkey7
"Ride with caution . And be thankful cagers are slightly more predictable than marsupials."
-XRman (fellow inmate)
speedmonkey7 is offline   Reply With Quote
Times are GMT -7.   It's 01:16 PM.
