Go Back   ADVrider > Riding > Face plant
Old 05-09-2013, 10:23 PM   #1
juddspaintballs OP
Never too many bikes
juddspaintballs's Avatar
Oddometer: 478
I wrecked on the way home today
I'm OK 100%, just a little sore.
I was on my way home from work this afternoon and it had just stopped raining after about 5 minutes of light rain. It poured the last two days so I know there was no oil on the road, but it is a very tar heavy section of road that I was on, still wet, when it happened. My rear end got loose and before I knew it I was sliding down the road sitting upright on my arse. My only thought was, "I hope the bike doesn't hit me in the back." It wasn't quite a highside since I rode the bike all the way to the ground.
I know it landed on the right side with the headlight pointing diagonally forward towards the left hand ditch and the tail end pointing diagonally backwards towards the right hand ditch. I came off forward of the bike sitting on my butt sliding down the road. As best I can tell, the right tip over wing dug in and flipped the bike over to the left side. There is road rash on the top of the dash board and the top of the passenger back rest so the ST had to have been upside down at some point. The left side took the brunt of the impact. The bike actually came to a rest on the right side.
Without taking plastic off and digging in, it appears that the left tip over wing got crushed and probably tweaked the frame. There's a lot of oil on the ground and all over the bike and it appears to originate from the left side. The oil filter is in tact so it's possible I cracked a component of the engine. I'm fairly certain the bike will be totalled by insurance. NADA on an excellent machine lists it at over $4480, and I think I have a very good case for calling it in excellent shape given the recent upgrades and immaculate pre-wreck condition of the plastics and the fact that the odometer reads under 100,000 miles.
First gouge in the asphalt.
[img width=600 height=800]http://img.photobucket.com/albums/v494/juddspaintballs/ST1100%20wreck/20130509_161932_zps3b49dcee.jpg[/img]
Second gouge (hidden inside a muddy footstep)
Oil
KTM 250EXC | KLR650
You can't say happiness without saying penis.
juddspaintballs is offline   Reply With Quote
Old 05-10-2013, 12:01 AM   #2
AzItLies
Oddometer: 347
Well that sucks Man, good yer okay.
With that mud and stuff, certainly looks like treacherous conditions.
Time to sit back with a cold one and thank yer lucky stars.
Cheers
AzItLies is offline   Reply With Quote
Old 05-10-2013, 06:22 AM   #3
Falconx84
Lurker
Oddometer: 379
glad to hear you're intact. I did almost the same thing last night on my drive home. I'm still not sure how I kept it upright with the front wheel sliding.
Hope you get a nice insurance payout... remember to claim your gear, too... with my insurance anything that contacts the pavement is considered damaged and gets replaced
V-Strom DL1000k7
Falconx84 is offline   Reply With Quote
Old 05-10-2013, 06:27 AM   #4
NJ-Brett
Brett
Oddometer: 6,717
Wow, those big heavy bikes really bust up in a crash!
Glad you did not bust up in the crash!
NJ-Brett is offline   Reply With Quote
Old 05-10-2013, 06:29 AM   #5
doc4216
Chronic High Fiver
doc4216's Avatar
Oddometer: 409
Wow!!! definitely glad you're okay!
"A straight road never made a skilled rider"
'06 White VFR
doc4216 is offline   Reply With Quote
Old 05-10-2013, 06:36 AM   #6
8lives
Dharma Bum
8lives's Avatar
Oddometer: 2,021
Glad to hear your ok,2 wheels allow things to change quick.Im guessing the little redhead in the picture is glad your ok,hope it all works out,scary stuff,thanks for posting/sharing to show us all it does happen,my son had a guy pull out in front of him,totaled the bike and messed up his knee,we got a new to us R6 sitting in the garage and he just got out of surgery and his knee is ok.
What would you do if you weren't afraid?
Bobcat Goldthwait is my mentor.
8lives is offline   Reply With Quote
Old 05-10-2013, 07:35 AM   #7
luckygrownup
Oddometer: 133
Sounds like you had a washout. Normally, you get that in the mud or dirt. My guess is you tried to counter steer right before you found yourself sitting on the pavement. Washouts happen quick.
Good to hear you are OK.
luckygrownup is offline   Reply With Quote
Old 05-10-2013, 08:30 AM   #8
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,451
Looks like the bike in binned. Glad to hear you're okay, though. If the frame isn't twisted maybe you could buy it back for a song and put all the plastic bits that exploded back on it.
Most importantly, you're fine.
That isn't like any part of Maryland I know. This probably wouldn't have happened in Glen Burnie.
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
Schlug is offline   Reply With Quote
Old 05-10-2013, 10:05 AM   #9
juddspaintballs OP
Oddometer: 478
Yes, a washout makes the most sense. It was a very wet and tar heavy road. once I knew going down was inevitable, my focus was staying clear of the bike.
I will probably attempt to buy it back, either to part out the accessories not covered (I only have $1000 extra in accessory coverage) or to put all of the good bits on a different ST1100. I just did a bunch of brake and carb work to it and I hate to see several hundred dollars of upgrades go to waste (thousands if you actually totalled everything up on the bike that isn't stock).
Sore today, twinge in the neck, but otherwise doing alright. Certainly not upset about this wreck or the bike. If you ride enough, this stuff happens. At least I have the KLR to ride on my trip to the BRMC next week.
KTM 250EXC | KLR650
Old 05-10-2013, 10:17 AM   #10
NJ-Brett
Brett
Oddometer: 6,717
It happens to some people.
Mostly to the people who think its likely to happen.
Old 05-10-2013, 10:34 AM   #11
DirtReeper
Oddometer: 508
Glad youre ok, wouldnt have happend if you were on the KLR
KLR 650 KLaiRe, dirty red head
Quoth the Darth Peach: "Must work to afford Bikethings"
Quoth Dorzok, it's a BMW. just activate the levitation function that's part of the optional accessory outer space adventure package.
DirtReeper is offline   Reply With Quote
Old 05-10-2013, 11:25 AM   #12
8lives
Dharma Bum
8lives's Avatar
Oddometer: 2,021
I agree,well I ride a KLR and it naps from time to time.
Old 05-10-2013, 12:43 PM   #13
bogey78
bogey78's Avatar
Oddometer: 579
Extremely glad you are OK other than being banged up a little bit. Also, sad to see that bike all tore up but as you said, there will be another to take its place.
Were you in a curve when it happened? I can't tell by the photos. I assume you were leaned and hit a slick spot---but wasn't sure.
Again, glad you came out of it basically uninjured.
Bogey78
IBA#33560
bogey78 is offline   Reply With Quote
Old 05-10-2013, 05:39 PM   #14
juddspaintballs OP
Oddometer: 478
I was out of the curve a good distance already. It was hot all day, the road is heavy on tar, and it had just sprinkled enough to get everything wet. So hot tar and water are a bad combination with a bike apparently. I've ridden many thousands of miles in the rain with that bike without an issue. Can't control everything...
KTM 250EXC | KLR650
Old 05-10-2013, 07:25 PM   #15
bogey78
bogey78's Avatar
Oddometer: 579
That is a freaky way to go down. Again, glad you are ok.
Bogey78
IBA#33560
Times are GMT -7.   It's 01:07 AM.
