Go Back   ADVrider > Riding > Regional forums > Canada
Old 05-10-2013, 02:37 PM   #1
scholz OP
bush league
scholz's Avatar
Oddometer: 55
dyno shops in ontario?
What are some good shops with a dyno in Ontario? I'm trying eto get the fuelling right on a ktm 690 enduro, and am using the tune ecu program. Any info is appreciated! Cheers!
scholz is offline   Reply With Quote
Old 05-10-2013, 04:23 PM   #2
juames
Have Fun, Don't Die!
juames's Avatar
Oddometer: 2,537
Not sure where you are at, but there is a shop in Richmond (Ottawa) with a dyno...Richmond Motorsports.
2005 KTM 950 Adventure
Roaming Rally 2011RR12 RR13 RR14 RR15
"I don't hate people...I just feel better when they are not around." - Henry Chinaski
juames is offline   Reply With Quote
Old 05-11-2013, 05:55 AM   #3
huron52
Oddometer: 202
There is a guy in Fordwich Ontario that has a Dyno. He sells and installs turbos on bikes.
huron52 is offline   Reply With Quote
Old 05-11-2013, 07:55 AM   #4
GatSS
Canadian eh
GatSS's Avatar
Oddometer: 289
Thumb
Pro 6 Cycle in Etobicoke has a dyno. I know one of the mechanics there and he does great work.
Mat
2012 Super Tenere
2002 XR400R - plated
2009 CRF50
GatSS is offline   Reply With Quote
Old 05-11-2013, 08:36 AM   #5
cdndog
cdndog's Avatar
Oddometer: 87
Cycle Improvements in KW, and he knows KTMs.
cdndog is offline   Reply With Quote
Old 05-12-2013, 06:20 PM   #6
triplenickel
triplenickel's Avatar
Oddometer: 2,430
Are you just wanting to play? I don't know about the 690 but for the 990 there's so many proven combos documented on this site I would think the money would go better on tires and beer!
07 SE
PG007
Old 05-13-2013, 12:56 PM   #7
bigbadandugly
Oddometer: 410
I used Richmond Motorsports when I tuned my BMW (see link in signature). All I really got out of it for my $500 was the before and after dyno graphs because I found a map on the Dynojet site that matched my hardware setup. The operator tried a bit of henpecking fine tuning but I can't say it did much.
So what I'm basically saying is find a map that was done on a bike that closely matches your configuration and go with that.
BigBadAndUgly
Current: 2012 R1200GS
Past: 2009 Moto Guzzi Stelvio, 1979 Suzuki GS750L, XR350R, DT125, CT70
Dyno testing of a PC-V + Full Akropovic system on an R1200GS
bigbadandugly screwed with this post 05-13-2013 at 07:59 PM
bigbadandugly is offline   Reply With Quote
Old 05-13-2013, 04:11 PM   #8
CanadianX
Oh!? That is deep.
CanadianX's Avatar
Oddometer: 1,701
My 690 in factory trim did the backfire and stall game. Dumped the factory air filter and exhaust added a uni filter and fmf pipe and a tune and no more issues except for a little flat spot wbetween 4-5000 rpm, not terrible but noticeable. I'll work on it at some point to try and tune it out with tune ecu. I'd try some other tunes and see how it goes but I'd be very curious how you make out if you do dyno it
CanadianX is offline   Reply With Quote
Old 05-13-2013, 06:28 PM   #9
Drilldogger
Drilldogger's Avatar
Oddometer: 535
Orillia Motorsports is set up to dyno bikes.
Drillers' go deeper!
Drilldogger is offline   Reply With Quote
Old 05-15-2013, 05:45 AM   #10
Country Doc
Wanderer
Oddometer: 2,756
Good luck Ryan...you'll never get the fuelling right on a 690...swap it to a carb!
Country Doc is offline   Reply With Quote
Old 05-15-2013, 05:58 AM   #11
alekomotto
alekomotto's Avatar
Oddometer: 91
Great guys at Pro 6 cycle. One of their techs used to work for BMW and KTM.
alekomotto is offline   Reply With Quote
Old 05-15-2013, 12:21 PM   #12
scholz OP
bush league
scholz's Avatar
Oddometer: 55
Very funny, but might be the easiest route!
I am using a wings pipe and akra base map, but it seems a bit lean (spark plug greyish). No stalling issues and it is smoother than the stock map at low rpms. I am using tune ecu to richen up the entire map until I get it to a dyno that can remap ktms (cycle improvement's dyno is out of service right now).
Old 05-20-2013, 10:00 AM   #13
GatSS
Canadian eh
GatSS's Avatar
Oddometer: 289
Condor
Mat
2012 Super Tenere
2009 CRF50
Times are GMT -7.   It's 01:47 AM.
