Old 05-11-2013, 12:04 AM   #1
jon6.0 OP
jon6.0's Avatar
Oddometer: 546
New 2013 990 Baja w/ head shake
I just picked up a 990 Baja today. Rode it home and on the highway the handlebars and shaking back and forth. Ride over a bump changing lanes and it gets much worse for a second. Adjusted the rear preload at a buddies house and it still does it. The fork tubes are flush with the triples. I was thinking of dropping them down some. The question is, how much? Could it also be loose steering head bearings?
Pics of new bike:
2013 KTM 690 Duke w/ performance cam, airbox, and Akrapovic full system. 300lbs and 74.5rwhp
2011 KTM 250XC with lots of protection stuff for when I bounce it down a hill.
jon6.0 is offline   Reply With Quote
Old 05-11-2013, 01:08 AM   #2
kaptinkaos
Just some nOOb
kaptinkaos's Avatar
Oddometer: 573
I just picked up the same bike and I'm pretty sure it's that lovely 908RR on the front combined with the uber soft suspension settings in the forks. I will know for certain in about a week when I get back to Canada and spoon something a bit more 50/50 on the front end.
'13 Honda CRF450X
'13 KTM 990 ADV Baja
'08 KTM 450 EXC-R
'07 F650GS Dakar (Gone to a good home!)
kaptinkaos is offline   Reply With Quote
Old 05-11-2013, 01:11 AM   #3
jon6.0 OP
jon6.0's Avatar
Oddometer: 546
I ran an MT21 on my TE449 and had no shake at all on the highway. I'll try setting the suspension to the sport settings and see if that helps before I try dropping the forks through the triples..
Old 05-11-2013, 01:13 AM   #4
kaptinkaos
Just some nOOb
kaptinkaos's Avatar
Oddometer: 573
Torque
You could check the torque also on the stem, but I think you would be able to notice some play in the whole front end if that was the issue. Put the bike on the center stand and move the bars back and forth to ensure nothing is binding or has a sticky spot. Possible the bearing got borked in assembly? Highly unlikely, but possible. Here's a link to the torques:
http://www.advrider.com/forums/showthread.php?t=310249
'13 Honda CRF450X
'08 KTM 450 EXC-R
Old 05-11-2013, 01:15 AM   #5
kaptinkaos
Just some nOOb
kaptinkaos's Avatar
Oddometer: 573
Lol, the TE is much smaller and lighter though... And the geometry is different. I like the MT21's, but the set I have is going on the 450. I'll put a Michelin T63 or TKC on the 990 I think. A bit harder of rubber compound.
'13 Honda CRF450X
'08 KTM 450 EXC-R
Old 05-11-2013, 01:58 AM   #6
jon6.0 OP
jon6.0's Avatar
Oddometer: 546
All the suspension settings were the comfort settings. Adjusted to sport just now. Hope it helps a bit. If not I'll drop the fork tubes through a little. If that still doesn't help I'll get a T63 or TKC.
Old 05-11-2013, 02:07 AM   #7
kaptinkaos
Just some nOOb
kaptinkaos's Avatar
Oddometer: 573
Did you check the stem nut too? Just put the front end in the air while on the center stand and tighten it until you see a little resistance in steering. Then back off a 1/4 turn. Then go put some miles on it and see if anything has changed. Only then would I throw a new tire on, :) (But the 908RR's are well known to be "snakey" on pavement". Down right spooky in the corners sometimes actually)
'13 Honda CRF450X
'08 KTM 450 EXC-R
Old 05-11-2013, 06:14 AM   #8
jon6.0 OP
jon6.0's Avatar
Oddometer: 546
I did not check the stem nut yet. If it really is the front tire, I'm going to be pissed. I've ran many different knobbies on the highway and never felt like that before.
Old 05-11-2013, 06:36 AM   #9
slidewayes
slidewayes
slidewayes's Avatar
Oddometer: 551
My first set of 908s scared the crap out of me . thats why I built a set of 17" s 20 minutes to change wheels. the best of both world's tell you put a Tarra Flex on the rear now your talking
slidewayes is offline   Reply With Quote
Old 05-11-2013, 06:38 AM   #10
NewtAZ
"did you say tacos?"
Oddometer: 39
990 baja shake
I just bought same bike with same issue. seems to only happen at higher highway speeds 70 MPH+. i have zero shake offroad. i think the problem is a combonation of soft forks and knobby tires. i took my bike in for its 600 mile service and told the mechanic about the shake and that the front end also dove under hard braking. i have also bottomed the front end twice while off road. the mechanic said he "firmed up the forks dampening 1 full turn. " On the ride home the shake was less noticeable but still there, but not as bad. My plan is to finish off the stock tires (which i LOVE off road), and try a less aggressive front tire. if the shake is still there my next step will be a Emig steering dampener/triple clamp kit.
oh... and i suggest you dont make any other suspension changes until you figure out the front end. too many changes at one time can make your problem worse. I dont think the rear preload would have anything to do with the front wobble. put it back to stock position and try firming up the forks first. once you have the forks dialed in, then deal with the back end.
BTW... you have a sweet bike!
NewtAZ is offline   Reply With Quote
Old 05-11-2013, 07:45 AM   #11
jon6.0 OP
jon6.0's Avatar
Oddometer: 546
Changing rear preload affects trail. Which will affect the front end.
Took it for a test ride and it is still shaking. At 85 mph the bars move 1.5-2". I put it up on the center stand and the bars move VERY easy side to side. Plus now I feel a slight catch in the movement just to the right of center. You can also hear a scraping sound when the bars move through that area.
Old 05-11-2013, 07:59 AM   #12
kaptinkaos
Just some nOOb
kaptinkaos's Avatar
Oddometer: 573
Well, I've had a lot of different bikes off road and ridden them on pavement too and run just about every type of knob and I too have not felt this particular head shake or twitch like my 990 does set up stock... I will be pulling my front end off to replace with an Emig 20mm offset anyway and I will keep the 908RR on the front to see what effect that has. I'll be going over the stem, bearings and seats with a critical eye also. I'll be looking for any sign of something out of shape or untoward in there. I won't put the dampener on until I know the head shake is gone as doing that will only hide the problem, not make it go away. Plus, you'd be punishing your dampener for something it's not intended to fix.
I do hope this isn't a manufacturing error or a factory mistake and it seems a bit too coincidental that your symptoms are IDENTICAL to mine. Here I was just was telling myself that 908's are snakey on pavement (because they are, I've run some before), but maybe there is a deeper cause to the head shake... God I hope not because I have 6 days to sort it when I get back to Canada before I leave on a 4000km shakedown ride.
Try tightening your stem nut up to the friction point (where the bars stop falling freely) and back it off just a tiny bit so they don't wanna fall fast. I'm hoping the scrape you hear is paranoia and that the head shake goes away after you tighten up the front end,
'13 Honda CRF450X
'08 KTM 450 EXC-R
Old 05-11-2013, 08:01 AM   #13
Sevv
Oddometer: 101
Really sounds like steering stem bearings. That notchyness you are feeling could be the racestarting to brinel.
Sevv is offline   Reply With Quote
Old 05-11-2013, 08:04 AM   #14
kaptinkaos
Just some nOOb
kaptinkaos's Avatar
Oddometer: 573
Just saw this too... Could spoon off the front tire and check your rim strip. I've never seen this before and in my opinion it would take effort to screw up a rim strip this bad, lol!
http://www.youtube.com/watch?v=gq-ux3YsSF8
'13 Honda CRF450X
'08 KTM 450 EXC-R
Old 05-11-2013, 08:17 AM   #15
kaptinkaos
Just some nOOb
kaptinkaos's Avatar
Oddometer: 573
More reading material to suggest suspension/steering head.
http://www.advrider.com/forums/showthread.php?t=319268
'13 Honda CRF450X
'08 KTM 450 EXC-R
Times are GMT -7.   It's 02:41 AM.
