Old 05-12-2013, 09:41 AM   #31
jon6.0 OP
jon6.0's Avatar
Oddometer: 546
Ideally you want to fix the shake and then install a steering damper. Installing a damper on a bike that is doing the death wobble will only mask the problem and wear out your damper faster. It seems the 990's don't like going over 60-65mph with soft knobbies like the 908RR front tire. I might try a MT21 on the front after the T63 depending on how much I like the T63. The T63 tread pattern looks like it will be a better choice for something that sees highway speeds though.
2013 KTM 690 Duke w/ performance cam, airbox, and Akrapovic full system. 300lbs and 74.5rwhp
2011 KTM 250XC with lots of protection stuff for when I bounce it down a hill.
jon6.0 is offline   Reply With Quote
Old 05-12-2013, 09:55 AM   #32
kaptinkaos
Just some nOOb
kaptinkaos's Avatar
Oddometer: 573
^--- What he said, except they do like 65+ on knobbies, just not on pavement, lol! It's a tire designed solely with dirt in mind. Why the Baja has those tires stock and not an R or S suspension will forever elude me.
'13 Honda CRF450X
'13 KTM 990 ADV Baja
'08 KTM 450 EXC-R
'07 F650GS Dakar (Gone to a good home!)
kaptinkaos is offline   Reply With Quote
Old 05-12-2013, 10:06 AM   #33
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,946
Originally Posted by fridgyis View Post
A steering damper is going to be my fix I think.
Pick the right tyres - this will go away, as the others have said a steering damper is not the right to correct this.
I don't that I would say the 908 a soft knobby - I think they are too hard, tyres like Scorp Rally, Karoo 2, TKC 80, Michelin Starcross are all softer the 908 and work much better.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Old 05-12-2013, 11:00 AM   #34
jon6.0 OP
jon6.0's Avatar
Oddometer: 546
The 908 knobs are fairly tall. Which I think is making the knobs squirm around leading to the death wobble. This would account for reports of people saying it got better with some miles on a 908. They are wearing the knobs down, thus less squirm and less wobble. The T63 has a much shorter knob right off the bat and a bit harder compound. How long does a Scorp Rally last?
Old 05-12-2013, 01:52 PM   #35
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,946
The Front are about the same as a Karoo the rears not about 2/3 of say a 908. But awesome grip.
Old 05-14-2013, 07:48 PM   #36
Porkchops
Oddometer: 5
Laugh Phew, not just me then
So I got my Baja on Friday eve and dropped her off Monday morning for her 600 mile service. Head wobble was really disconcerting. I joined Adv to see if anyone else was having the issue.
It's controllable as but I would not want to be fully loaded and experience this. I will keep watching to see what the fix suggestions are and report back on anything I may learn.
Hurrah for forums!
Porkchops is offline   Reply With Quote
Old 05-14-2013, 09:57 PM   #37
jon6.0 OP
jon6.0's Avatar
Oddometer: 546
Hurrah for forums!
The front is very under-sprung. It makes the front sit nose down. This makes the front less stable at speed. The real fix is stiffer springs and proper front sag. I just ordered some .62's from Slaven's today. Stock is .48 if I remember right. Proper suspension geometry will make the bike less picky for tire selection.
Old 05-14-2013, 10:02 PM   #38
Porkchops
Oddometer: 5
Question if I may be so bold.....how much do you weigh?
Ok. Cool. Im 240llbs dry. Just put new springs on my Ktm 450 xcw so I will be interested to hear how yours work. How much do you weigh?
Old 05-15-2013, 04:48 AM   #39
jon6.0 OP
jon6.0's Avatar
Oddometer: 546
275lbs. The stock rear spring should work fine for you. I'm a actually running my rear with the preload turned full soft right now. Once I put the fork springs in, I will probably be around 3-4 turns in from full soft on the rear.
Old 05-15-2013, 05:18 PM   #40
Skinner
Mr.KTM
Skinner's Avatar
Oddometer: 5,728
My thinking must be backwards! I always thought to stop the tank slappers you weight down the front end. A light front end will feel loose?
You might be an ADVRider if:
You recognize your friends by the sound of their mufflers.
http://www.meetup.com/Chicagoland-Du...torcycle-Club/
www.jimstarwaltteam.com
Skinner is online now   Reply With Quote
Old 05-17-2013, 10:38 PM   #41
Porkchops
Oddometer: 5
Laugh headshake
I talked to the mechanic who also owns a 990 and he put .70 springs in the front to combat the issue.
Old 05-18-2013, 01:05 AM   #42
jon6.0 OP
jon6.0's Avatar
Oddometer: 546
Jeff Slaven told me to run .62's in mine. I don't think the stock valving will be able to control .70's. That seems too much unless you weigh 350+ lbs. I'm 275 and will be having the .62's installed next week during the first service.
www.slavensracing.com
Old 05-18-2013, 03:42 AM   #43
gkNQ
Northern Adventurer
Oddometer: 300
I have a Scorpion rally on the front (with HD tube) no head shake at all. Just did a 3000km + trip mostly dirt however some 100kmh plus tar, good grip in all conditions and no issues. Also have a ralle moto damper and while this is one of the best things that I have ever put on a bike it will not fix a tyre issue including alignment or balance.
Ps When the Scorpion rally is done I will go the same again, used to have 606's on my 640.
gkNQ screwed with this post 05-18-2013 at 03:51 AM
gkNQ is offline   Reply With Quote
Old 05-18-2013, 04:54 AM   #44
fridgyis
Fridgy
Oddometer: 49
Head shake
I have the same bike as well. It shakes its head severely at highway speed. I have a 19-17 combo set up for street and it is fine with that set up. The stock tires are brutal! However they are a must off road.I have ordered a steering damper from pro Moto billet and will report on that when it is installed. I have also installed stiffer springs because the stock ones suck.
fridgyis is offline   Reply With Quote
Old 05-18-2013, 09:24 AM   #45
kaptinkaos
Just some nOOb
kaptinkaos's Avatar
Oddometer: 573
Hey Jon, just an update for my head shake. Gone with a bit of adjusting to the forks. I'm still gonna go heavier for springs and stretch them a bit, but it's all better now! Today = some new tires and doodads too, :)
'13 Honda CRF450X
'08 KTM 450 EXC-R
Times are GMT -7.   It's 01:49 PM.
