Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 05-13-2013, 11:45 PM   #46
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,069
Tyre choices and spare parts
Originally Posted by Martynho View Post
you could always drill the rim centrally in order to fit a tube, but that would mean going tubed forever as you would lose the seal.
Martyn
I believe you could install a second valve on the second hole. This way you will have the choice of using tubed tyres. In this case you could cancel the OEM off center valve all together.
For fueling I would suggest a backup fuel filter and fuel pump. A clutch slave could be waiting for you somewhere on your 30 kkms. Water pump cold be also an issue. I believe all the above are unchanged from 990 so you could capitalize on gained experience with these parts.
Cheers.
Old 05-14-2013, 12:38 AM   #47
AdventureLeo OP
AdventureLeo's Avatar
Oddometer: 92
Originally Posted by Deviant666 View Post
It's just a funnel with a filter on top that won't even allow water to pass through...it's well known at the States....
http://lmgtfy.com/?q=mr.+funnel
Hi
This mr. funnel thing is to big for me. But since it's well known over there I maybe get it when I need it. Good to know that something like this is available.
Greetings
"Träume sind zum Leben da! Man darf sie nur nicht vergessen"
http://www.freiheitenwelt.de
AdventureLeo is offline   Reply With Quote
Old 05-14-2013, 12:40 AM   #48
AdventureLeo OP
Oddometer: 92
He`s not a Chileno Martin, he`s a bloody spaniard . Me neither, I am a Brit, but we do enjoy a whisky or 5 together
There are hundreds (500+) of 990ADV`s here in Chile so as Goti rightly points out there is a good range of tyres available, and most of them are tubeless. I reckon the std (for a 990) Pirelli Scorpions are the best all round bet for the tarmac and gravel roads here in Chile. There are not many places you will be able to stretch the 1190`s legs fully to 260kph anyway.
I am not sure about the possibility of putting a tube in if the hole is offset, that sounds dodgy to me. I have already had issues on the rear with the valve detaching from the tube. In an emergency if you couldnt do a tubeless fix you could always drill the rim centrally in order to fit a tube, but that would mean going tubed forever as you would lose the seal.
In any case, Santiago awaits you with a warm welcome, just let us know when you are on approach. PM me or Goti.
Cheers, and good luck amigo
Martyn
Old 05-14-2013, 12:41 AM   #49
AdventureLeo OP
Oddometer: 92
Just a thought...It is a minimum of 3500kms from Santiago to Ushuaia so 7,000kms round trip, probably more like 8,000+. There is not much tyre availability down south unless you get them sent from Santiago (and you cant do this into Argentina, and tyre choice there is much more limited). Fully loaded up and with 150hp on tap I reckon the only rear tyre that will stand a serious chance of going the distance would be a Heidenau K60, which is tubeless. I would recommend you fit one before you come and you can also buy those here in Santiago, but only from time to time. They suck on the tarmac though in my opinion as they square off and the handling goes strange. Decisions, decisions...oh what fun!
I think I ask Heidenau just for sponsorship. ;-) It's a German Company anyhow....
Greetings
Old 05-14-2013, 12:55 AM   #50
Deviant666
Present
Deviant666's Avatar
Oddometer: 536
Originally Posted by AdventureLeo View Post
Hi
Greetings
Trust me it isn't, the smallest version is taking only 1/10th of the space of a medium size tankbag...there are many sizes to choose from and they'll save the day for you...unless of course you are really determined to be "adventurous"...
KTM 990 Adventure White 2009 R specced
ZZR1400 ABS 2008
Deviant666 is offline   Reply With Quote
Old 05-14-2013, 01:14 AM   #51
Burren Rider
Aussie Adventurer
Burren Rider's Avatar
Oddometer: 1,819
Again - tube tires are not possible on the 1190 adventure rim. This is because the hole for the tube is not in center of the rim. Maybe there is special tubes for that or a normal tube will do. If it works - I don't have a Problem. And TÜV - I don't care in SA.... ;-)
G'Day,
No worries fitting a Tube Type Pirelli Scorpion Rally in the front of the 1190 R (hole is not offset). Just pulled the tyre pressure sensor out and poked the valve stem through. Finding decent tubeless rears seems to be easier, the Mitas E-09 Dakar comes in a 150/70 18 and fits up nicely.
Good luck with your trip.
Cheers,
Danny
Burren Rider is offline   Reply With Quote
Old 05-14-2013, 01:28 AM   #52
AdventureLeo OP
Oddometer: 92
Originally Posted by Burren Rider View Post
G'Day,
Cheers,
Danny
AdventureLeo screwed with this post 05-16-2013 at 06:32 AM
Old 06-10-2013, 07:39 AM   #53
AdventureLeo OP
Oddometer: 92
Moin
just got sponsorship from Heidenau. They will sent me two front and 4 back tires for the trip. Just wonder how I get them shipped to Chile! Have to hide them in the big box... ;-)
It will be the K60 Scout. Should be good enough for now.
Old 06-10-2013, 11:15 AM   #54
Jaimoto
Spaniard in Chile
Jaimoto's Avatar
Oddometer: 1,305
There is no better tire than a free tire!
Jaime
Big, Loud and Orange KTM 990 Adv
Jaimoto is offline   Reply With Quote
Old 06-10-2013, 11:23 AM   #55
AdventureLeo OP
Oddometer: 92
Yes - I quess they will do for the start. Should be good for at least 36000 kilometers. I am thinking about to build some depots in Brazil and maybe Peru.
;-) I don't want to carry them all the way round.
Bye the way - got another sponsorship call from Touratech today. The will adjust my bike with almost all the gear they have for it. I don't really need all of it - but well - the best parts are free parts. To say it with the words of Goti.
By the way 2 - if someone has some storage place left for the tires around Santiago, Lima or a place in Brazil. Just let me know. Drinks will be on my bill when I cross by. ;-)
Old 06-10-2013, 05:18 PM   #56
Jaimoto
Spaniard in Chile
Jaimoto's Avatar
Oddometer: 1,305
I have an small storage in the apartment building I live, not sure it could take all your tires, we can storage the remaining in the balcony, but these tires will be a bit exposed to the elements.
Maybe we can find a better place -I'll do some calls - but if we can't and you are OK with that, then no problem, you are welcomed to storage them here.
Jaime
Old 06-10-2013, 06:13 PM   #57
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 4,061
Heya Martin
We may crossed paths down in South America somewhere, we are in Guatemala at present and will be heading south again in around thre to four weeks.
Best for getting all done and set up.
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 06-11-2013, 12:11 AM   #58
AdventureLeo OP
Oddometer: 92
Originally Posted by Two Moto Kiwis View Post
Heya Martin
Then maybe see u there! There are two main events for me on the trip. 1st the rally Dakar. 2nd. Soccer worldcup Brazil.
Before that I will explore Patagonia again...
Old 06-11-2013, 12:12 AM   #59
AdventureLeo OP
Oddometer: 92
That sounds good - I will keep you updated!
Old 06-11-2013, 08:46 AM   #60
Two Moto Kiwis
Homeless Somewhere
Oddometer: 4,061
Will see YOU there .... we are going too WOH HOH ... will finally see an 1190 in person
Times are GMT -7.   It's 05:41 AM.
