Old 05-12-2013, 08:21 AM   #16
opticalmace OP
opticalmace's Avatar
Oddometer: 151
Good tip about measuring the braking distances. As a scientist-in-training I appreciate the objectivity.
That is definitely what I am going to try next.
opticalmace is offline   Reply With Quote
Old 05-12-2013, 09:32 AM   #17
Capt Crash
Capt Crash's Avatar
Oddometer: 227
Yes. Objective measures. DAMN! Scale says I go 235...must be broken...
Yeah, that Capt Crash http://www.HowitDoneCrash.com
Author of "Life, Motorcycles and..." & "The Elemental Motorcyclist"
Any Bike is Better Than No Bike.
Capt Crash is offline   Reply With Quote
Old 05-12-2013, 09:45 AM   #18
Fajita Dave
Fajita Dave's Avatar
Oddometer: 717
When I first got my street bike (after I hit a deer with it) I practiced emergency braking religiously for a while. I measured the distance of each stop simply to keep track of my progress.
While doing that on clean pavement I felt like I couldn't brake any harder because it would just hover the rear tire across the ground practically from start to finish (in an emergency it never works out that smooth). I didn't think I could stop any faster then that... until I started gripping the tank with my knees harder instead of weighting the handlebars. This kept the rear tire on the ground a little longer and shaved a few more feet off my stopping distances from 60mph.
The mountain bike experience will definitely help! Riding downhill I'm sure you've felt the front tire start to wash out from to much front brake. Its the same feeling; theres just a lot more mass involved that takes getting used to.
2008 GSXR 600
2001 CR250R
Fajita Dave is offline   Reply With Quote
Old 05-12-2013, 10:22 AM   #19
MADurstewitz
MADMark
Oddometer: 159
Downshifting will radically reduce your stopping distance. It may save your life one day.
MAD
(yes, those are my real initials)
MADurstewitz is offline   Reply With Quote
Old 05-12-2013, 10:27 AM   #20
Barry
Just Beastly
Barry's Avatar
Oddometer: 7,318
How exactly does downshifting give you more stopping power than using the rear (and front) brake to maximum effectiveness?
Tail of the Dragon at Deal's Gap... Avoid it now, do a trackday.
Do not do business with Myrtle West Cycle... Not a reputable vendor by a long shot.
Barry is offline   Reply With Quote
Old 05-12-2013, 11:05 AM   #21
Capt Crash
Capt Crash's Avatar
Oddometer: 227
Placebo effect.
Old 05-12-2013, 11:56 AM   #22
opticalmace OP
Oddometer: 151
This study appears to contradict your statement:
http://www.promocycle.com/documentat...morfrein_e.pdf
In fact they suggest completely disengaging the clutch for the entirety of the braking maneuvre.
Old 05-12-2013, 12:17 PM   #23
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,266
Originally Posted by opticalmace View Post
Thanks guys, this info is really useful!
About threshold braking, I used to (downhill) mountain bike a lot. My bikes had very strong hydraulic disk brakes. I think it is probably helping a bit, though it's certainly a different feeling slowing down several hundred pounds!
I mountain bike a lot. Mostly X-country type single track; the most technical I get is rock gardens. My bike also has very good hydraulic discs on it.
If you have good experience with that kind of brake, you are already better at modulating your squeeze and knowing to SQUEEZE and not grab than most people on the street already riding motorcycles.
Very hard braking leaves rubber on the street whether or not you lock the brake. YOu may be very close to locking the brake though, so be cautious. As mentioned, if the brake locks the front wheel, the bars will lose all feeling, and you can recover by releasing the brake enough to get the tire rolling again.
What was not mentioned is that this will happen in about a second or two, and if you don't release the brake well within that time frame, you are going down. Two wheeled vehicles with rake and trail in the fork need the front wheel to be turning and gripping a surface or the bike can't stand up for long!
Keep at it.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 05-12-2013, 02:33 PM   #24
mfgc2310
Oddometer: 137
Hang on to the bike with our knees and try to keep weight off the bars. Also try the same braking with a passenger if you carry a passenger on occassion.
mfgc2310 is offline   Reply With Quote
Old 05-12-2013, 11:44 PM   #25
Andyvh1959
Cheesehead Klompen
Andyvh1959's Avatar
Location: Da frozen tundra eh? 1.5 mile west of Lambeau
Oddometer: 716
LuciferMutt finally said it right. When you are effectively braking hard, the front tire contact patch is distorted by the loading as it squashes down and spreads out. All that deflection of the tire contact patch "shears" off rubber under heavy braking. Totally normal.
If this weren't the case how do you explain tire wear? Just the normal everyday action of acceleration and deceleration causes very slight shearing action of the tread at the road contact patch. Under heavy braking the shearing is increased, and if braking is increased until traction is broken, the tire slides/skids. Just up to the point the tire is still rotating, but there is sliding already taking place at the contact patch. This is the basic principle of ABS brakes.
All ABS systems rely on this shearing action. In fact, ABS systems don't even activate until the tire under braking is going 10% to 20% slower than the actual vehicle speed. That speed difference at the tire contact patch is shearing, almost sliding. That's why under ABS braking you'll hear tire squeal and see a tire track on the pavement. Here are some pic of braking practice I did a few years back. Repeated high effort stops from 60mph:
Those are tire marks on the pavement from the front tire. I practiced repeated stops to learn what I could do and to see how hard I could brake before the ABS system took over to avoid loosing traction. The action of heavy braking caused a much wider scuffed area on the tire than would be normal for just riding down the road. That was the result of about 20 stops, all from 60 mph.
When life throws you a curve,.....lean into it!
42+ year rider, 22+ year MSF Coach, Street, Dirt, Ice, ride em all!
Andyvh1959 screwed with this post 05-12-2013 at 11:59 PM
Andyvh1959 is offline   Reply With Quote
Old 05-13-2013, 05:52 AM   #26
Capt Crash
Capt Crash's Avatar
Oddometer: 227
No argument. The only issue is that often newbs mistake the rear for the front. A better way to be sure you're getting max braking is to practice and measure speed and distance--then there's no doubt. Imagine if you'd been leaving marks thinking you're at max but it's actually the rear (light and hovering)...in the emergency situation you've trained yourself to underbrake.
It's worth it to bust out a tape measure. Idaho STAR has published this:
"Some minimum standards for stopping performance (these are the standards that beginner level rider training or the DMV state test might use):
20mph 23 feet
25mph 31 feet
30mph 44 feet
Skilled riders should be able to stop their motorcycles in less distance:
20mph 15 feet or less*
25mph 20 feet or less*
30mph 30 feet or less*
*NOTE: these distances require pretty aggressive braking. Be careful, be smooth, and work toward these over time."
http://idahostar.org/_blog/News_Room...s_the_BRAKES!/
Old 05-13-2013, 08:11 AM   #27
Andyvh1959
Cheesehead Klompen
Andyvh1959's Avatar
Oddometer: 716
Those distances are equal to what we use for the 20 and 25mph quick stop braking exercise in the MSF BRC. Yes they take some effort and practice to attain but are not out of the realm of any cycle rider.
The pics above were taken on a day I practiced high effort braking from 60 mph. I used 150 feet as my standard for a 60 to zero stop. On a rural road I measured off 150' with a tape measure, marked the start and 150' mark with a paver brick I could easily see. Then I made repeated stops in both directions. When the bike was stopped, I'g get off and measure from the 150' marker to the leading point of the tire vertically to the ground. With practice I was regularly stopping within 135 to 142 feet. I made at least 20 stops, in both directions to compile enough stops to develop my average. Some stops did engage the ABS, most did not.
On a braking distance calculator I found, for 60 mph in 150' it calculates to 0.80G stopping force. So even at 150' from 60 mph, there is room to stop shorter yet assuming good traction and a possible 1-G force. Someone earlier said if you are leaving "blackies" there isn't much left, traction wise. True, as in this case the blackies I left were indicative of sliding action at the front tire beginning during the braking event. Since I was able to achieve shorter than 150' stops from 60 mph, I was doing more than 0.80-G stopping force. But just because you leave some blackies behind does not necessarily mean you are on the edge of traction, but you are getting close. Practice, practice, practice, know what you CAN do before you HAVE to do it. Develop the memory and the muscle action of these techniques to overcome the PANIC reaction common to those who do not practice.
Andyvh1959 screwed with this post 05-13-2013 at 08:26 AM
Old 05-13-2013, 12:10 PM   #28
MADurstewitz
MADMark
Oddometer: 159
Try it.
MAD
Old 05-13-2013, 12:13 PM   #29
shaddix
Oddometer: 647
Try it.
Not sure why anyone should believe anything without understanding how or why it works.
shaddix is offline   Reply With Quote
Old 05-13-2013, 12:52 PM   #30
joexr
Oddometer: 3,773
A lot of guys here could tell you thousands of things you'd never understand.
Times are GMT -7.   It's 09:34 PM.
