Old 05-11-2013, 10:58 PM   #1
b737jets OP
Baja Explorer
b737jets's Avatar
Oddometer: 172
LC4 Piston Issue
I just purchased a 2002 Adventure which had a few engine issues from the previous owner mostly clutch and bearing stuff as far as I was told. anyways after getting it rideable again and I started to ride it and it was puking excessive oil in my airbox. Did a leakdown check and it was at 40% yikes anyways open heart surgery revealed a broken compression ring and this damage. I have never scene anything like it anyone else out there scene it before
b737jets is offline   Reply With Quote
Old 05-12-2013, 03:20 AM   #2
tHEtREV
Captain Awesome
tHEtREV's Avatar
Oddometer: 7,931
I saw it on a KLX250 once...
Had between 55 and 60 000 Klm on it, but the damage was much more severe than that.
tEAM iDIOT.
A KDX is way cooler than what ever you ride...
tHEtREV is offline   Reply With Quote
Old 05-12-2013, 11:26 PM   #3
bmwktmbill
Traveler
Oddometer: 5,218
Jets,
Does this look familiar?
Did your head gasket blow(mine did twice in the same place above the notch)?
IMHO at some point in time my machine got hot and the ring broke, leaking compression did the rest.
I blame the PO.
Again IMHO.
BTW my bore had a few scars and some stuck aluminum that I removed gently, then I used fine emery wet/dry to smooth the scars and break the glaze on the chrome...I just stirred it up a very little. emery on a sponge. Put in a new piston, ran like gang busters but oil in the airbox got worse and worse.
Well I was in Panama so first I rode home to the USA and then pulled the head off when I got back and couldn't stand the mess. I redid the guides and seals, reground the valves... used my local auto machine shop.
Now all is well. Running strong and no oil blow by.
Running premium fuel these days(used to run regular before(Ok so maybe that did it??).
Anyway you will enjoy the return of POWER.
FWIW I rarely run under 4000rpm now.
No more lugging for me.
The engine loves to rev and I am running 17/42 gearing so it's drop the clutch and go.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill screwed with this post 05-12-2013 at 11:48 PM
bmwktmbill is offline   Reply With Quote
Old 05-12-2013, 11:40 PM   #4
oldxr
oldxr's Avatar
Oddometer: 1,151
Make sure it is not to lean.If you bought it used from a high altitude area and it was tuned for altitude and you brought it down to sea level there could be a jetting issue.Or a cooling system problem.If you have a local bike shop with a good dyno operator with a/f printout on a dyno run I would head there after break in.That piston got hot.Even something as stupid as a partially plugged fuel filter could cause this under a sustained high load condition.
oldxr is offline   Reply With Quote
Old 05-13-2013, 10:07 PM   #5
b737jets OP
Baja Explorer
b737jets's Avatar
Oddometer: 172
Wow that's crazy almost the same thing except no blown head gasket as far as I know. the guy I bought the bike from went to Chile, Peru, Argentina. When i got the bike I cleaned the carb cause bike had not ran since 2008 upon return from So. America, the Carb was uber lean on idle circuit 1 turn out and the rest of carb set up was ok for the most part main was 162.5 the pilot jet 45 but the needle was only on 2nd clip and on tear down the whole intake downstream from throttle had this crazy tan buildup almost like a clay layer weird.
b737jets screwed with this post 05-14-2013 at 05:04 PM
Old 05-14-2013, 12:03 PM   #6
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,241
Mine did about the same. I blame the thin L-shaped rings. They break and then a little broken bit wears out a hole like a pebble in a riverbed.
I put in a Wossner piston which has regular rings, re-nicasil'd the liner and it has been better than stock ever since.
Luke is online now   Reply With Quote
Old 05-14-2013, 05:03 PM   #7
b737jets OP
Baja Explorer
b737jets's Avatar
Oddometer: 172
Yeap Luke that's what im doing too... Wossner and Recoating the cylinder
Old 05-14-2013, 07:54 PM   #8
bmwktmbill
Traveler
Oddometer: 5,218
Maybe just hone the cylinder? Your piston looks good in the sense that it never stuck.
Take a good look at the cylinder head while it's off.
b
Bill Shockley
Old 05-15-2013, 09:38 AM   #9
Droptarotter
Oddometer: 1,301
You are lucky you are only dealing with a one cylinder engine with this.
My buddy's vintage XKE did the same thing........but.....the little piece of ring managed to bounce around in the one cylinder it came from.........then exited out an intake port and proceeded into the next cylinder where it did in that set of piston/valves.
Next up was a broken aluminum bell housing.......but that is another story!!!
Some people have all the luck!
Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is online now   Reply With Quote
Times are GMT -7.   It's 02:52 PM.
