Old 05-22-2013, 08:35 PM   #31
rboett
posser noob 205
rboett's Avatar
Oddometer: 1,702
try cranking down the pre-load a bit on the REAR shock, that will cause increased downward pressure on the front,,,, give it a try
That'L do Pig,, That'L do
rboett is offline   Reply With Quote
Old 05-22-2013, 08:59 PM   #32
Voz OP
Voz's Avatar
Oddometer: 463
I am running lowest setting preload, 1 rider no luggage. Soft setting for suspension.
I have not been on a freeway since my last post but will report any updates here. For the moment I have no concerns, not quite sure how to again simulate e very slight wobbles I originally posted about now.
Sydney, Australia
2013 R1200 GSW Red - Blown Engine & Gearbox (clutch basket nut issue) - AUG 14
2015 R1200 GSW White - NOV 14
Voz is offline   Reply With Quote
Old 05-23-2013, 03:50 AM   #33
Dockstrada
Dockstrada's Avatar
Oddometer: 238
I Just rode another 450km on the weekend mostley tar avarage speeds 100 to 120 kph for long stretches total so for 1000km in 2 weeks since new no problems no front wobbles , what a great machine
R1200GSA H2O
Dockstrada is offline   Reply With Quote
Old 05-23-2013, 05:13 AM   #34
IB1
IB1's Avatar
Oddometer: 979
Originally Posted by Voz View Post
I just came back from a 100 Klm run with the local sports bike club, lots of twisties and suburban main roads and about 5 Kim of freeway.
I could not get the bike to exhibit any wobble in the bars tonite.
I note that my front tyre was showing 2.1 bar and rear at 2.5 bar. Last nite the front was at 2.2 bar, can't imagine that is significant just thought I'd mention it.
Recommended pressure is 2.5 up front and 2.9 for the rear wheel. Mine is at 2.3 front and 2.6 rear at the moment. It was at 2.5 and 2.9 when new. I'll get some extra air in them before my next trip.
IB1 is offline   Reply With Quote
Old 05-23-2013, 05:15 AM   #35
IB1
IB1's Avatar
Oddometer: 979
Lately the wobble has been gone. At 110 and 120 kph it's not there (neither at 120 mph )
4200 km so far.
Old 05-23-2013, 05:15 AM   #36
bemiiten
League of Adventures
bemiiten's Avatar
Oddometer: 4,901
try cranking down the pre-load a bit on the rear shock, that will cause increased downward pressure on the front,,,, give it a try
+1
bemiiten is offline   Reply With Quote
Old 05-23-2013, 07:26 PM   #37
madefrtv
madefrtv's Avatar
Oddometer: 427
the manual also states that damping must be increased along with preload. Has anyone tried this?
whoa, dude...
madefrtv is offline   Reply With Quote
Old 06-03-2013, 06:06 AM   #38
At adventure
AB
Oddometer: 133
I am also getting a front wheel vibration through the bike (handlebars etc) above 80km. I have spoked rims with Metzler Tourance tyres. The vibration only started at 1500km and the bike has now done 3200km. Only really noticeable on smooth roads in a straight line. I have played around with the tyre pressure and it is worse at lower PSI. I also noticed I have two balancing weights inside the wheel. Not sure is this is normal? I have also closely inspected the tyre rotating it whilst on the middle stand and it looks perfect!? Dealer tells me it is within normal tolerance but I think not! Trying not to be anal but it definitely worse than the videos of other GWCs I have seen. All advice, suggestions or comments welcome.
At adventure is offline   Reply With Quote
Old 06-03-2013, 09:46 PM   #39
MarcGSA
Flashing Snowflake?
MarcGSA's Avatar
Oddometer: 13
Handle bar shake!?!
It is a common event with a block and staggered block design. Situation that I had with my GSA 09. The Tourance, Anakee and other have a tendency to wear on a slight wedge so that at a certain RPM (speed) it will create a handle bar shimmy and if not taken care of can induce other odd situations. For my sake I remounted the tire backwards to wear it the other way but one must have more caution in the wet stuff and do not recommend it, but I did it anyway for the extra tire life. Running the tire with pressure on the high side will posepond the wedge wear effect.
Also if the rear wheel has some free play from whatever (final drive bearing loose, pivot bushings,..) it will give similar symptoms.
MarcGSA is offline   Reply With Quote
Old 06-08-2013, 06:00 AM   #40
IB1
IB1's Avatar
Oddometer: 979
If all is right: my video of the front end wobble. Appears between 85 and 75 kph. The front wheel has been rebalanced since then.
The wobble only appears in certain conditions.
Old 06-08-2013, 06:09 AM   #41
nwpa
Generally amused
Oddometer: 499
Definitely not on mine. I Have metzelers and spokes.
nwpa is offline   Reply With Quote
Old 06-08-2013, 07:05 AM   #42
IB1
IB1's Avatar
Oddometer: 979
Same wheels and tires, but this can't be noted with hands on the handlebar. And since it was rebalanced it got better.
Old 06-08-2013, 07:29 AM   #43
wabtklr
wabtklr's Avatar
Oddometer: 100
Wobble, what wobble???
I rode away from the dealer and rode home 130 miles at 65 to 105 mph and experienced no wobble. Could it be a specific road surface condition, does it happen in the same location?
People sleep peacibly in thier beds at night because rough men stand ready to do harm on there behalf. George Orwel
wabtklr is offline   Reply With Quote
Old 06-08-2013, 11:22 AM   #44
Hambonee
Hambonee's Avatar
Oddometer: 176
just over 500 miles on mine. No wobble what so ever
Actually..most stable bike at speed have ever ridden...does wonders for high speed travel on busy road..bike is just solid..
Hambonee is offline   Reply With Quote
Old 06-08-2013, 02:48 PM   #45
RichBMW
RichBMW's Avatar
Oddometer: 1,981
On our way back from Italy a couple of weeks ago, we went on the autobahn in Germany. With panniers and soft luggage, I took mine off the clock, over 150mph, GPS verified at 144mph. No wobble. No shake. Nothing. Anyone with headshakes need to get your bikes checked out.
2015 BMW S1000R Sport
2015 BMW R1200GSAW
RichBMW is offline   Reply With Quote
Times are GMT -7.   It's 05:44 PM.
