Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 11-07-2014, 01:49 PM   #1
seanmbcc OP
Oddometer: 37
1190 speedo accuracy!!!
Hi, I've been doing some long spin over the past two days in heavy rain so I've had a chance to make an observation while the speed was slow!
My speedo reads approximately 10-15% higher than what I am traveling at according to my GPS. Is it possible that it is set/calibrated for the 21 inch wheel on the R version!!! The would roughly equate to the difference in speed being displayed. Can the wheel size be selected in the operator menu or through diagnostic menu maybe?
Has anyone else had it noticed this issue?
While driving at 60mph GPS shows 51mph
Thanks for help
Sean
seanmbcc is offline   Reply With Quote
Old 11-07-2014, 01:51 PM   #2
Sumi
Sumi's Avatar
Oddometer: 1,799
It works like that because of law reasons (the R version is also off). Can't be worked around on the 1190 or the 1190R.
Old 11-07-2014, 01:56 PM   #3
waterboy222
Dirt Road Explorer
waterboy222's Avatar
Oddometer: 103
I have the same issue on mine.. I just go off my GPS until theres an update to fix it..
waterboy222 is offline   Reply With Quote
Old 11-07-2014, 01:57 PM   #4
seanmbcc OP
Oddometer: 37
Hello Sumi, thank you for you reply but what lay states that the speedo reads inaccurately. Why would this not be the same in my car or other bikes, curious for anymore info you have in that.
Thanks again
Sean
Old 11-07-2014, 02:02 PM   #5
Sumi
Sumi's Avatar
Oddometer: 1,799
Thanks again
Sean
Because KTM is an EU manufacturer, so EU/Austrian laws apply on the production line, and on EU produced bikes the speedo must be off (on the safe side) a couple percents.
Old 11-07-2014, 02:06 PM   #6
NewToMe
safety 3rd
Oddometer: 1,135
I am guessing that what they really want to avoid is reading too low, lest they be liable for speeding problems. Also still guessing, but they also figure that the speedo should still read high with the largest outside diameter tire that will fit the standard wheel. US regulations are said to allow up to 10% inaccuracy.
NewToMe is offline   Reply With Quote
Old 11-07-2014, 02:29 PM   #7
seanmbcc OP
Oddometer: 37
Thank you for the update, learn something new every day eh!!
Old 11-07-2014, 02:38 PM   #8
seanmbcc OP
Oddometer: 37
Thank you too for response nothing to worry about so! I just thought incorrect wheel size was selected in software! (For R model)
Old 11-07-2014, 03:13 PM   #9
NewToMe
safety 3rd
Oddometer: 1,135
All of the 1190 Adv seems to be wrong by about 9% (someone said it was 9.5%, but even the GPS speeds are seldom that kind of accurate.) I have learned to just speed ;-)
Old 11-07-2014, 03:30 PM   #10
clogan
Oddometer: 13
Is odometer similarly inaccurate, showing more miles traveled than actual?
My KLR spodosols reads high, as does my C-14, my wife's Focus, and her old Honda Accord. Honda ran into trouble a few years back because of it: warranty coverage by miles ended sooner that it should have due to overstated miles driven.
clogan is offline   Reply With Quote
Old 11-07-2014, 03:31 PM   #11
Barekat
Looking to get dirty
Barekat's Avatar
Oddometer: 540
Nice. Only 10% reduction on the factory warranty with the inaccurate odometer.
2015 KTM 1290 SA 229kg/160hp/104ft-lb... Ordered and waiting north of Toronto
Barekat is offline   Reply With Quote
Old 11-07-2014, 03:34 PM   #12
Sumi
Sumi's Avatar
Oddometer: 1,799
On the 950/990 the odometer is spot on (the speed is off also, as this is once again required by eu laws). So I'm guessing that the 1190 is the same - giving you the 100% warranty:)
Old 11-07-2014, 04:02 PM   #13
carden260
Oddometer: 38
A better title would be lack of accuracy. Its actually a problem. DOT allows for a 5% error I believe and almost every bike I have seen is at least 8-10% off.
carden260 is offline   Reply With Quote
Old 11-07-2014, 07:09 PM   #14
DirtJack
DirtJack's Avatar
Oddometer: 1,600
The DOT reg. is no more than 10% error, I think. Mine is right at 10%.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 11-08-2014, 02:19 AM   #15
FuzzyDunlop
Oddometer: 283
The 1190 warranty in Oz is unlimited kms, so the ODO being off does not make a difference in that regard. Is it not the same in 'Murica?
Currently riding 2013 KTM 1190 Adv R
FuzzyDunlop is online now   Reply With Quote
Times are GMT -7.   It's 10:43 PM.
