Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 03-12-2014, 12:23 AM   #121
gunshot72
Knee down complete
Oddometer: 319
Originally Posted by pyarnall View Post
With that down out of the way, you will be able to see, (mirror and flashlight), a knob that is X shaped below the lowest (high beam) bulb. That is the up and down. Turn clockwise to raise the beam, counter clockwise to lower.
On my 2014 1190 ADV the screw turns the other way, counter clockwise to raise the beam! Even though the manual says it like you say! :
gunshot72 is offline   Reply With Quote
Old 11-06-2014, 09:52 AM   #122
bick51
Oddometer: 21
1190 Adventure Speedo Error
Most of us are using GPS to get accurate speedo measurements. But for my own interest, I went in to the owner's manual for the gear ratios (primary, secondary, and 1st thru 6th gear) to generate a table of RPM/Speed by gear. This assumes a stock 150/70ZR 18 rear tire. The resulting table of RPM/Speed, and RPM for specific speeds is shown in the attached pic.
Just turned over 4,000 miles yesterday, and from experience the table looks about right. I usually don't even think about shifting into 6th until I see ~62 mph on the speedo. Even then, it lugs and will quickly run back up to the 'sweet spot' in the torque curve around 4,000 rpm if I don't pay attention - well above legal speeds on back roads. The result is that 6th has become the 'freeway only' gear.
bick51 screwed with this post 11-06-2014 at 02:17 PM
bick51 is offline   Reply With Quote
Old 11-07-2014, 12:18 PM   #123
DirtJack
DirtJack's Avatar
Oddometer: 1,600
Nice spreadsheet. Here are links to a web based program I put together so you check gearing setups for any bike. The bike's gearing setups are stored in the URL so you can bookmark different setups. I have a set of dirt wheels with a 45 tooth rear sprocket for my 1190R Here's the link for that. The link for the OEM wheels and gearing. I'm using an actual measured circumference for the rear of 82.13 inches which is a little different than what you used.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack screwed with this post 11-09-2014 at 04:11 PM
DirtJack is offline   Reply With Quote
Old 11-09-2014, 10:48 AM   #124
bick51
Oddometer: 21
KTM 1190 Adventure Speedo Error
DirtJack makes an excellent point. Actually measuring the tire circumference is always worth more than a calculation by Excel (compounded by the sin of showing 10 significant figures). The calculated circumference was 82.5 in. DirtJack put the number at 2086 mm, or 82.13 in. At 4,000 miles on the Conti Attack, I measured 81.5 in. The smaller 81.5 inch number would drop the 6th gear speeds in my table by a little over 1%. Probably in the noise anyway, as I find the response time of the digital readout to be somewhat slow - and at 6K rpm in 6th I'm focused more on hanging on than watching the readout.
bick51 screwed with this post 11-10-2014 at 02:11 PM
Times are GMT -7.   It's 03:15 PM.
