Old 05-16-2013, 03:59 PM   #1
2wheelride.com OP
Oddometer: 11
NEW! Go Cruise Aluminum Throttle Lock
After 3 years on the road, we are introducing our new Go cruise throttle control.
The new Go Cruise Aluminum is CNC’D from 6061 aluminum alloy.
We keep clean design and affordable price for our customers as usual.
The new tension gear design allows you quickly open/close by one hand, and easily to set tension you need.
We have a special price for this summer,
aluminum black is $30.95
aluminum chrome is $35.95
FREE shipping in the United States.
Please go to www.2wheelride.com for more details.
2wheelride.com is offline   Reply With Quote
Old 05-17-2013, 05:31 PM   #2
acap650
acap650
acap650's Avatar
Oddometer: 724
Not sure how they can make this out of metal with actual moving parts for only $10 more but wow, this could solve the most challenging problem I have with the plastic G-C - deploying it requires more effort in my right hand than I can muster given my aging joints. Adjusting the friction may help here.
The other issue I have is that minor speed adjustments are not as easy as with a typical friction device where once the friction is set adjustments only require a twist up or down. I don't think the new AL version will fix this.
Still, given the huge price gap between typical friction locks and GC it has great value. Now if the good old vista-cruise would fit more bikes it would blow away all of them.
acap650 is offline   Reply With Quote
Old 05-17-2013, 06:31 PM   #3
beechhunter
beechhunter's Avatar
Oddometer: 231
Got one.
I just bought one. Looks simple enough and a fair price. Thanks
beechhunter is offline   Reply With Quote
Old 05-19-2013, 07:41 PM   #4
2wheelride.com OP
Oddometer: 11
You only need one hand to operate the new go Cruis
Thank you for your order.
You only need one hand to operate the new Go Cruis
e
When you turn the tension gear, the clamp will open or Close both sides simultaneously,
making the new Go Cruise easy to set and remove.
Old 05-23-2013, 09:48 PM   #5
2wheelride.com OP
Oddometer: 11
Our Canada dealer
It is available in Canada Now!
Please contact
Matt Dynes
Motorcycle Innovations & Distributions
www.motorcycleinnovations.ca
Old 05-30-2013, 08:19 PM   #6
2wheelride.com OP
Oddometer: 11
Available in Australia Now!
It is available in Australia Now!
Please contact
Russell
Oneup Motorcycle Products
oneup.com.au
Old 06-02-2013, 09:27 PM   #7
justdirtyfun
justdirtyfun's Avatar
Oddometer: 342
I believe your explanation is
1. mount and set tension
2. operate GC identical to plastic version
Does that sound correct? I hope its as good as first version I'm using.
justdirtyfun is online now   Reply With Quote
Old 06-03-2013, 04:22 PM   #8
2wheelride.com OP
Oddometer: 11
Yes, that is correct.
It operates same as composite version
The difference between are
1. Adjustable tension
2. One size fits all bikes
3. Material: 6061 T6 Aluminum
Old 08-31-2013, 08:05 AM   #9
s boy
old guys rule!
s boy's Avatar
Oddometer: 60
just found and ordered this... really liked the composite version design (simple), but mine eventually broke.
2011 white wee
s boy is offline   Reply With Quote
Old 09-05-2013, 07:24 PM   #10
phunmusicphan
Dude
phunmusicphan's Avatar
Oddometer: 427
It looks like this will work with hand gards. Is this correct?
We are off like a herd of turtles!
phunmusicphan is offline   Reply With Quote
Old 09-05-2013, 07:28 PM   #11
Wlfman
Wlfman's Avatar
Oddometer: 1,293
Hopefully it lasts longer than your plastic model. I bought one of those and it broke in less than two weeks...
I ride not to add days to my life, but to add life to my days.
Those who say it cannot be done should not interrupt the people who are doing it."
"Now and then it's good to pause in our pursuit of happiness and JUST BE HAPPY."
Wlfman is offline   Reply With Quote
Old 09-06-2013, 09:43 AM   #12
HighFructose
Rollin Clubbies
HighFructose's Avatar
Oddometer: 2,090
cool, i like the simple look of this one
HighFructose is offline   Reply With Quote
Old 09-10-2013, 12:08 PM   #13
HighFructose
Rollin Clubbies
Oddometer: 2,090
mine arrived, really nice and lightweight. best part is the adjustment wheel makes a reassuring clicking sound while it rubs on the spring.
should be my favorite removable cruise to date
Times are GMT -7.   It's 05:15 PM.
