Old 05-17-2013, 09:35 AM   #1
Air0ne OP
Adventure reader
Air0ne's Avatar
Oddometer: 163
Thumbs down Headlight melted
Hi there,
It seems that my headlight has melted due to overheating. The problem is: I only used normal bulbs (No HID or anything else that strong)
Could someone tell me if it's a common issue?
BMW F800 GS 2009
Ckeck out my ride reports
Air0ne is offline   Reply With Quote
Old 05-17-2013, 09:40 AM   #2
jengel451
1 Cool MotherF#$cker
Oddometer: 799
You were using a 55W bulb? Seems odd
jengel451 is offline   Reply With Quote
Old 05-17-2013, 09:50 AM   #3
Air0ne OP
Adventure reader
Air0ne's Avatar
Oddometer: 163
Yes... but not a BMW one, a Sylvania
BMW F800 GS 2009
Old 05-17-2013, 10:47 AM   #4
Motorfiets
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,997
huh new one on me
Ben
My Photo's
Motorfiets is offline   Reply With Quote
Old 05-17-2013, 10:59 AM   #5
sarathmenon
Oddometer: 969
You are the first person to note something like this. To me it looks as though your bulb fused, and the damage is only to the bulb. So, I guess you got a lemon from Sylvania?
sarathmenon is online now   Reply With Quote
Old 05-17-2013, 11:06 AM   #6
jengel451
Oddometer: 799
if you can look through the bug guts and the glare and gaurd, you can see that the reflector bubbled.
Old 05-17-2013, 12:08 PM   #7
Air0ne OP
Adventure reader
Air0ne's Avatar
Oddometer: 163
Really? Cause I already read on ADV that others had similar issues but I wasn't able to find that back...
BMW F800 GS 2009
Old 05-17-2013, 12:37 PM   #8
dpm
Oddometer: 178
My recently-purchased 658 has the silvering "eroded" above the bulb, and a couple of blobs in the underlying black plastic. I've put a 35W HID kit in since, to ensure it doesn't get any worse; I'll probably add a small piece of aluminium tape over the darkened area at some stage too, to take the bad look off it...
dpm is offline   Reply With Quote
Old 05-17-2013, 01:34 PM   #9
Air0ne OP
Adventure reader
Air0ne's Avatar
Oddometer: 163
Thx to give us your feedback. I'm feeling better now as I'm not completely alone
BMW F800 GS 2009
Old 05-18-2013, 04:49 AM   #10
JRWooden
Oddometer: 4,257
AirOne ...
naw you are not alone ... there is a thread or two here somwhere of others with same issue more common on the hi-beam since the enclosure is smaller. I've got the problem as well, but not to the same "extent" ...
At one point there was talk of reporting it to the vehicle safety folks see if a recall might be in order but I don't think it ever took off.
BMW does not sell replacement reflectors, so unless you do a homebrew repair they will want to sell you a new HL assembly for some $400+ bucks.
On getting oils on the bulb, what my dad told me was that if you got oil "fingerprints" on the bulb that caused uneven heating of the bulb its self which would shorten bulb life - he always handled them with gloves on or a paper towel then wiped down with alcohol.
But even if you did this, I can't see how that would increase the amount of heat passed to the reflector by any significant amount ...
I'd guess the issue is that once the reflector starts erroding it absorbs more heat and the problem feeds on its self...
Disappointing to be sure
On repairing it, this is one comment I collected:
Headlight reflector repair
I used whatever kind of (chrome) paint was nearest or easiest to find at the store. I suppose bar b q or exhaust paint might hold up longer and perhaps plastic paint would stick better, never had a problem with any paint I used holding up but perhaps I just got lucky.
P.S. you need to use a patch saturated with rubbing alcohol to get the carbon and oil off where you are going to paint. only use a little and only where the oe paint is gone.
JRWooden screwed with this post 05-18-2013 at 05:01 AM
Old 05-18-2013, 11:51 AM   #11
gs_lad
Oddometer: 33
My front light also got a little burned, by using an ordinary bulb.
The explanation from the dealer was that the bulb wasnt clicked into place completely (by me) and touched the surface of the reflector, thus burning it.
You re definitely not alone, this is quite a common issue.
gs_lad is offline   Reply With Quote
Old 05-18-2013, 11:53 AM   #12
ebrabaek
Oddometer: 4,745
That said, I read a few weeks back that a vendor on fleabay now sells the housing, or at least the front part, way cheaper than the oem unit.
Erling
Old 05-18-2013, 12:50 PM   #13
JRWooden
Oddometer: 4,257
I can't find one on fleabay
I found this ... It's a nice pair, but not quite what I had in mind....
http://www.ebay.com/itm/BMW-Motorcyc...-/111000368551
Old 05-18-2013, 03:25 PM   #14
Air0ne OP
Adventure reader
Air0ne's Avatar
Oddometer: 163
Originally Posted by JRWooden View Post
AirOne ...
That means we have to remove the glass... is it easy to do?
BMW F800 GS 2009
Old 05-18-2013, 03:26 PM   #15
Air0ne OP
Adventure reader
Air0ne's Avatar
Oddometer: 163
BMW F800 GS 2009
Times are GMT -7.   It's 11:32 AM.
