Old 05-18-2013, 07:27 PM   #16
JRWooden
Oddometer: 4,230
Originally Posted by Air0ne View Post
That means we have to remove the glass... is it easy to do?
I have not done it, but hear that it is not very easy ... the glass is apparently "glued" in to the frame ..........
Old 05-18-2013, 07:42 PM   #17
Snarky
Vodka Infused.
Snarky's Avatar
Oddometer: 1,342
(No HID or anything else that strong)
HID would've saved it. They run cooler than Halogens. Sorry about your loss, that's an expensive part, hence your rock guard. Almost a shame a rock didn't get it, but that it was an internal meltdown instead. I would thoroughly check your wiring after/during repair, if it got that hot there, who knows where else it was hot.
I would say, like someone else mentioned, that the culprit is likely that the two arms that hold the filament apart, connected together somehow and turned your lightbulb into a heater. I'm not sure how this can happen, perhaps a manufacturing flaw combined with some sort of jolt from a pothole or offroading; somehow viberating them together and they fused.
Any other bike probably would have probably popped a fuse first, it's odd that the CANBUS system didn't switch it off and save it. Like I said, a damn shame.
ALL ADDERS ARE PUFFS!
2012 BMW R1200 GSA, 2009 Kawasaki Versys (sold), 2001 Yamaha XT225 (sold)
PC Gamer? Support Star Citizen! Save PC Gaming and bring back Space Sims!
Pledge today! Service guarantees citizenship. @ http://www.robertsspaceindustries.com Thanks.
Snarky is offline   Reply With Quote
Old 05-18-2013, 07:59 PM   #18
madefrtv
madefrtv's Avatar
Oddometer: 427
on an 05 12gs melt a headlight. The bulb was just slightly unseated
whoa, dude...
madefrtv is offline   Reply With Quote
Old 05-19-2013, 01:01 AM   #19
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,022
Having worked at a Dealer for 3 yrs, I never seen any issues like that. I usually keep tabs on used parts from various sources and have only seen one on the Flea Market here and one on Kijiji but not recent. I have my broken glass original here I wanted to repair one day with this: http://stores.ebay.com/Dawn-Knights/...=p4634.c0.m322
If you do get a new one, maybe I could buy your old one and do a repair on mine and post the results here. See if I can get the glass out by heat without breaking it. You're not too far from me. That's about the only consolation I can think of.
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is offline   Reply With Quote
Old 05-19-2013, 03:58 PM   #20
Tor
Native Viking
Tor's Avatar
Oddometer: 803
I had the unit replaced under warranty on my 2010 F8GS a year or so back (high beam side). Sylvania 55W. It discolored the reflective surface black above the bulb. When I got the bike back, they had put a stock bulb back in .
"Be Always Sure You Are Right - Then Go Ahead"
2005 Honda ST1300 / 2010 BMW F800 Gelände-Straße
Tor is offline   Reply With Quote
Old 05-19-2013, 05:01 PM   #21
Air0ne OP
Adventure reader
Air0ne's Avatar
Oddometer: 163
So, they know about it !!!
BMW F800 GS 2009
Ckeck out my ride reports
Air0ne is offline   Reply With Quote
Old 05-20-2013, 05:18 AM   #22
LukasM
Oddometer: 5,384
I have seen quite a few cases of stock bikes with burned reflectors.
Getting the glass out undamaged will be impossible IMO, it's glued in there with a ton of adhesive, which won't get soft enough unless you heat it up to a level where the housing will melt as well.
Old 05-22-2013, 07:27 AM   #23
Air0ne OP
Adventure reader
Air0ne's Avatar
Oddometer: 163
BMW F800 GS 2009
Old 05-28-2013, 01:10 PM   #24
Air0ne OP
Adventure reader
Air0ne's Avatar
Oddometer: 163
Hi there,
I was wondering... is it possible to have LED lights instead of halogen? If I have to buy another part, I would like to minimize the risk of having the same problem again...
BMW F800 GS 2009
Old 05-28-2013, 02:21 PM   #25
epicxcrider
epicxcrider's Avatar
Oddometer: 645
Had the same problem, housing was replaced under warranty at 17k miles
Been through any stream crossings? Did you get water or excess moisture in the headlight?
Old 06-05-2013, 11:16 AM   #26
Air0ne OP
Adventure reader
Air0ne's Avatar
Oddometer: 163
I never noticed any water inside mine...
BMW F800 GS 2009
Old 06-05-2013, 11:20 AM   #27
Air0ne OP
Adventure reader
Air0ne's Avatar
Oddometer: 163
I tried to find a solution with BMW Canada and my BMW dealer. Both declined, so I decided to sue them in small claims court. Now it's time for me to go see an expert at Transport Quebec to check the part...
wish me luck...
BMW F800 GS 2009
Old 06-07-2013, 07:48 AM   #28
Gaspare
Almost dirt rider
Gaspare's Avatar
Oddometer: 62
Same story.
The overheating is simply normal with such a power... with halogen lamp, because of bulb temperature.
If you put HID before an evident damage, the part is saved.
In case of even a small burnt, no way: the HID light is not reflected and goes straight to heat up the plastic body - despite to the lower bulb temperature.
Anyway: good news.
Not necessary to buy BMW OEM part: the whole part is corresponding to CEV713-714 (CEV is the producer) code. Let's try to search by Google..
PS - OEM code BM.63127697751
Gaspare screwed with this post 06-07-2013 at 08:59 AM Reason: PS
Gaspare is offline   Reply With Quote
Old 06-07-2013, 08:05 AM   #29
Air0ne OP
Adventure reader
Air0ne's Avatar
Oddometer: 163
Originally Posted by Gaspare View Post
Same story.
Anyway: good news.
Thx a lot bro... I found that: http://www.ebay.com/itm/FANALE-FARO-...item2ec5f66e51
BMW F800 GS 2009
Old 06-07-2013, 09:05 AM   #30
Gaspare
Almost dirt rider
Gaspare's Avatar
Oddometer: 62
yep!
Don't know about the shipping cost; anyway last year I bought mine for 180 € with a dream-discount to a local automotive parts store.
Good deal.
Times are GMT -7.   It's 05:48 AM.
