Old 08-23-2013, 07:17 AM   #76
TowPro
Lets ride
Oddometer: 3,221
Originally Posted by murpies View Post
Yep. But they (BMW) will sure take note , if anything happen , they will blame it on the HID . To make matters simple. Just change it to stock if going down.
Can't change back to stock. Its would be hard to explain the 3/4" hole drilled in the rear access disk where the HID harness Grommet goes.
Will the aluminum tape stop the problem from getting worse, then remove the tape before selling bike later?
2015 KTM 690 Enduro R
2014 R1200GS - My Naked Street Touring Bike
2000 KTM LC4 640 E - currently up for adoption with 3200 miles
TowPro screwed with this post 08-23-2013 at 07:23 AM
TowPro is online now   Reply With Quote
Old 08-23-2013, 09:18 PM   #77
murpies
murpies's Avatar
Oddometer: 154
Just went to the dealer, saw both of our bikes and was told it a wear and tear issue . Tats ridiculous . A headlight tat wear n tear in less then 3years n mileage only 16k. They will write in and see what's the out come. Unacceptable !! My pal is lucky cos his still under warranty. So likely will replace a new one for him . But mine abit tricky , if they recognize that's the issue , they might replace mine in good faith . But if not , then I will just paste the alu foil n see Wat's next.
murpies is offline   Reply With Quote
Old 08-24-2013, 02:12 AM   #78
Snowy
Oddometer: 1,838
Yeah, I really couldn't be bothered even chasing BMW for it.
I did a freeway run in a storm last night, 300kms in the dark, with massive side wind and rain. My new light is so much better than the standard light that it was worth suffering the failure just to explore the options. I enjoy riding it in the dark so much more now.
Now I'm looking at HID as an option. With the better optics and reflector I think it will really light up the night then.
Snowy is offline   Reply With Quote
Old 08-24-2013, 04:52 PM   #79
murpies
murpies's Avatar
Oddometer: 154
BTW wat headlight are you using now? Any pic? I was thinking if mine got replace , I will use the LED light as an option as LED produce less heat then the standard bulb. correct me if i'm wrong.
Old 08-25-2013, 04:50 AM   #80
Snowy
Oddometer: 1,838
This one.
Old 08-25-2013, 05:17 AM   #81
dpm
Oddometer: 191
you can buy the rear cap as a spare part.
dpm is offline   Reply With Quote
Old 08-25-2013, 05:22 AM   #82
murpies
murpies's Avatar
Oddometer: 154
This one.
nice
Old 08-25-2013, 05:39 PM   #83
TowPro
Lets ride
Oddometer: 3,221
I know, but warranty just expired 2 days ago anyway.
Never got a notice trying to sell me an extension, but did get a letter trying to sell me road side assistance.
Old 08-25-2013, 05:43 PM   #84
TowPro
Lets ride
Oddometer: 3,221
This one.
did you ever give more detail on your 7" light? Like where do can I get the housing you used?
Old 08-27-2013, 11:14 AM   #85
JRWooden
Oddometer: 4,267
I called Sylvania
I just called Sylvania - they make the SilverStar Ultra H7 bulbs which is all I have used in my headlight since the OEM bulb burned up. I explained what was happening and asked for their input.
The lady I spoke with was very nice and said that it was not possible (in her humble opinion) that the bulb caused the reflective coating to scorch. She says that the bulbs have the same 55watt energy consumption as a "standard" H7 bulb and do NOT run at a higher temperature than the OEM bulbs.
FWIW .... that's what Sylvania says....
Old 08-28-2013, 06:42 AM   #86
murpies
murpies's Avatar
Oddometer: 154
I agreed with the lady. Even mine , using the oem bulb is scotching the reflector.
Old 08-28-2013, 10:15 AM   #87
PatrickM
Oddometer: 366
Just a data point, but I switched out the regular bulb a bit more than 10,000 miles ago for a slim mount ballast and HID (DDM IIRC) and haven't had any scorching issues.
PatrickM is offline   Reply With Quote
Old 08-28-2013, 10:20 AM   #88
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,451
Simply a Trail Tech 8" race light with a DOT assembly installed..here it is..and comes with the 8" as well..
Cyclops Lighting
"Ignorance is a powerful tool when applied at just the right time..sometimes even surpassing knowledge.." EJ Potter
Bill-66 is offline   Reply With Quote
Old 08-28-2013, 10:45 AM   #89
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,753
how many miles do you have on you GS right now?
Loutre is online now   Reply With Quote
Old 08-28-2013, 10:49 AM   #90
murpies
murpies's Avatar
Oddometer: 154
Can take a picture n show us your headlight ?
Times are GMT -7.   It's 06:42 AM.
