Old 05-17-2013, 06:46 PM   #1
hillbillypolack OP
Grumpy Old Goat
hillbillypolack's Avatar
Oddometer: 6,146
Linked brake nerd question - 2012 GS
This afternoon I swapped the rear brake lever to the GSA design with the flip down beartrap. I did this since the standard GS lever felt it was engaging too low despite my adjusting it.
The swap was easy, straightforward. I checked the brake was operating normally and the calipers weren't dragging. On a ride this afternoon I noticed two things : one was that the rear brake felt warmer then the fronts when I stopped for gas. I often use both F & R brakes mostly out of habit. Since the GS has linked brakes, when I use the rears am I using too much rear (thus heating the rotor too much)? Or is it possibly a by product of the smaller rotor taking more heat due to smaller surface area?
The second thing I noticed was the banjo fittings were / are a light blue tint. At first I cringed, thinking I was cooking the fluid and discoloring the fittings. The rotor isnt the rainbow dark blue of a dragging brake pad, so I looked at the front fittings which are also light blue. I didn't notice this before, but the systems feel like they are operating as they should.
So I guess my question is if I am using the rear brake on a GS (with linked brakes) am I using too much rear? Or is a little more heat for the rear rotor considered normal?
I found Jesus. He was behind the sofa the whole time.
1996 M900 2012 GS 2008 Megamoto 2008 S2R
2006 HP2e
hillbillypolack is offline   Reply With Quote
Old 05-18-2013, 09:58 AM   #2
200GRLSWC
Oddometer: 107
Don't know if this is useful or not, but my experience with rear brakes on the GS.
First, I almost never touch the rear brake lever, unless I'm on dirt. Since I ride 98%+ on street, that means I effectively never touch my rear brake lever.
When I had my '06 GS, my rear brake pads were down to metal at the first 6,000 service. I was astonished. The dealer suggested I might be resting my foot on the rear brake lever, but I knew that was nonsense. Back in those days I had the dealer do the work (that very bill was the driver that broke me of THAT habit), and they replaced the rear pads. I sold that bike with about 20,000 miles on it, and never needed to replace the rear pads in those additional 14,000 miles. Clearly, something had changed.
On my '08 GSA I just finished the 24,000 mile service (I do my own service now), and the brake pads have plenty of life left in them, both front and rear. (Yes, I ride like an old man, get over it. ) Again, clearly something was different than my experience on the first 6,000 miles of my previous GS.
I suspect that on some GS bikes the "linked brakes" mechanism that apportions some pressure to the rear caliper even when you use only the front brake lever only may in fact provide too much pressure to the rear, causing excessive wear on the rear pads. I think that's what happened on my '06 GS, and that then the dealer either adjusted or replaced something in the linked brakes mechanism and the distribution of braking force was changed to prevent excessive rear pad wear.
Just one rider's experience.
200GRLSWC screwed with this post 05-18-2013 at 03:14 PM
200GRLSWC is offline   Reply With Quote
Old 05-18-2013, 07:37 PM   #3
hillbillypolack OP
Grumpy Old Goat
Oddometer: 6,146
Thanks. Kinda my thoughts as well. I'm used to settling the rear with a bit of rear brake on other bikes. That 'habit' followed me on the GS. I likely would not have noticed the rears being warmer than the fronts if I hadn't changed out the brake pedal. The bike brakes well enough by using the front brake lever but really stops when both ends are clamped down tight in an emergency.
I did a coast-down check to ensure neither end was dragging (up to 40 mph then coasting to a stop. then feel the rotors for any heat). Neither was. I also took a closer look at the brake line fittings. All are a light blue color which again I didn't notice before. Not a biggie, but seeing the coloration on the caliper fitting had me thinking I was cooking brake fluid!
2006 HP2e
Old 05-19-2013, 10:16 AM   #4
Mudcat
Unregistered
Mudcat's Avatar
Oddometer: 4,472
I completely ignore the linkage system on my 05. I use the brakes as if they are conventional hydraulic disc brakes and I believe the brakes perform better doing this.
However, I have been led to believe that on later model GSs, 2008+, one can not ignore the linkage system as I do. This has completely ruled out a new BMW for me.
I've got to be cool
Relax
Take a long long ride on my motor bike
Untill I'm ready
Mudcat is offline   Reply With Quote
Old 05-19-2013, 10:54 AM   #5
Snarky
Vodka Infused.
Snarky's Avatar
Oddometer: 1,342
Cry no more, they act just like any other bike when you touch the rear brake.
ALL ADDERS ARE PUFFS!
2012 BMW R1200 GSA, 2009 Kawasaki Versys (sold), 2001 Yamaha XT225 (sold)
PC Gamer? Support Star Citizen! Save PC Gaming and bring back Space Sims!
Pledge today! Service guarantees citizenship. @ http://www.robertsspaceindustries.com Thanks.
Snarky is offline   Reply With Quote
Old 05-19-2013, 11:31 AM   #6
Mudcat
Unregistered
Mudcat's Avatar
Oddometer: 4,472
Yeah, I use both brakes almost all the time.
Are you saying I can ignore the linkage on the newer models without the front brake interfering with rear brake usage? Because if you are. I have heard from others on this forum that I cant.
I dont want linked brakes
I've got to be cool
Relax
Untill I'm ready
Old 05-19-2013, 12:09 PM   #7
Hambonee
Hambonee's Avatar
Oddometer: 180
I was told that(on my 2013) if you hit the rear brake first it disables the linking. Since I always do other than possible panic stops linked brakes not an issue
That being said now gonna go play with it to check stopping with just front then rear and front...got me curious...lol
Hambonee is offline   Reply With Quote
Old 05-19-2013, 02:47 PM   #8
/dev/null
/dev/null's Avatar
Oddometer: 177
How do you adjust the front/rear bias/gain on the linked braking system (08+)?
I too have been told by my dealer (who historically has offered sage advice) to avoid the rear brake almost entirely. Adding rear brake will simply overuse the rear. Use only the front in spirited riding or even a panic stop. Use the rear off-road only.
My introduction to this issue was a warped rear rotor. Pads were fine in my case, and the issue did not appear to be wheel/wheel flange related. When I swapped to my '11, 10k later, I did notice the replaced rear rotor felt as though it was beginning to warp again (in the lever, or with the rear pedal). I never did a heat check or coast-down check. My best guess is that the brakes were biased incorrectly (if this is possible)?
11 R1200GS TB, 09 FZ1
/dev/null is offline   Reply With Quote
Old 05-19-2013, 08:04 PM   #9
hillbillypolack OP
Grumpy Old Goat
Oddometer: 6,146
In a nutshell, that was my hunch.
2006 HP2e
Old 05-19-2013, 09:19 PM   #10
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,849
No you are not using too much rear when you use your rear brake. Brake just like you would on any motorcycle.
The habit of JUST using the front ALL the time ONLY is a bad habit.
One of the worse things you can do is use your front brake to come to a stop from a slow speed.
It's okay to 'scrub' some speed from your bike with front brake only, but using it for stopping is not correct, safe or judicious procedure.
James and Colleen Tucker.
Aut viam inveniam aut faciam
DMV work/insurance/registration/titles/address use/room rental/motorbike&vehicle buying/travelers help/problems solved
TUCKERS is offline   Reply With Quote
Old 05-19-2013, 10:56 PM   #11
Mudcat
Unregistered
Mudcat's Avatar
Oddometer: 4,472
Its bad technique but safer for many people.
I must say, I think the linage is crap.
I am confused as to what year the linkage can no longer be ignored. I know a couple of years ago BMWAtlanta, who is a BMW dealer, was advocating using both brake levers, ignore the linkage. Not that I find BMW Dealers completely creditable but he seemed like a real knowledgeable rider to me.
Anyway, on my 05 I can and do ignore the linkage system. And Im a happy camper.
I've got to be cool
Relax
Untill I'm ready
Old 05-20-2013, 04:36 AM   #12
/dev/null
/dev/null's Avatar
Oddometer: 177
The problem is that they're set up so using the front only gives you the correct bias. Adding rear gives you more rear bias. Brakes are only linked front to rear on these (at least 08-13 oilheads).
The bad habit aspect is very annoying to me, especially when I get on my FZ1 without linked brakes where I need to do things the "right" way.
Old 05-20-2013, 08:01 AM   #13
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,522
Could you have installed the lever to high so that your foot is resting on the pedal, applying rear brake all the time?
On my 08 if I add too much rear brake the ABS kicks in on the rear tire.
scooteraug02 is offline   Reply With Quote
Old 05-20-2013, 02:11 PM   #14
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,424
I ignored it on my '05. I also ignored it on my wethead test ride. I plan on ignoring linkage when my wethead is eventually delivered. I always use the rear brake at low speeds; both brakes for quick stopping.
The "over braking" worry is, IMHO You can feel the braking power and adjust the pedal appropriately. If you really go overboard on the rear the ABS will kick in to let you know.
marchyman is offline   Reply With Quote
Old 05-20-2013, 06:14 PM   #15
justinallen03
Oddometer: 213
I don't think the link is heating up your rear brake any more. The linking applies pressure somehow (I think its a servo motor/pump) based on the front brake input. Your input to the rear brake pedal would have to overcome this pressure applied by the pump before you would generate any more braking force. I don't think it takes much more than what the linking system provides to lock up the rear, or at least what ive thought after burying the rear pedal on a stop. I think you would notice excessive rear pad wear too.
I think the rear stays hotter mainly because airflow is greatly blocked by the wheel and swingarm, and what air it does get is heated up from crossing the engine and cat.
I personally like the linking...one less thing to worry about during the oh shit moments. The times I don't want it I just flip off the ABS.
justinallen03 is offline   Reply With Quote
Times are GMT -7.   It's 01:48 PM.
