Old 05-18-2013, 03:50 AM   #1
fridgyis OP
Fridgy
Oddometer: 50
Side stand too long?
I have 2013 990 baja and run the stock wheels off road and a 19/17 combo on the highway. I am contemplating cutting an inch off the side stand because it is too long when running the 19/17 combo. It is difficult to get off the bike as it is too upright and almost tip over when on the side stand. If you are loaded with luggage it Iowa too long. Has anyone modified this? How much to take off?
fridgyis is offline   Reply With Quote
Old 05-18-2013, 04:22 AM   #2
Soberman001
Soberman001's Avatar
Oddometer: 758
Yes, I have done this when I lowered my bike. Pretty easy if you are good with a welder. BUT.. if you change between the stock wheels and the 19/17 wheels you might want to consider an adjustable side stand which uses a lengthening bolt/nut in the middle for quick changes (requires a wrench). One of the guys here in ADV makes them. Do a search.
Soberman001 is offline   Reply With Quote
Old 05-18-2013, 05:55 PM   #3
PABiker
Anywhere but here
Oddometer: 3,923
I do the same wheel swap, so I made the stand adjustable.
First cut the stand, press a nut inside and weld it in:
Then do the same to the base with a piece of all-thread, make the foot bigger at the same time:
Put it back together with a jam nut and adjust it for both sets of wheels:
'03 Suzuki DL1000 V-Strom
'12 Suzuki DR650SE
'10 Husaberg FE450 Plated
PABiker is offline   Reply With Quote
Old 05-18-2013, 07:13 PM   #4
Mr_Snips
Husky BRAAAAAAAAP!
Mr_Snips's Avatar
Oddometer: 352
You can try adding a few washers on the bottom two bolts of the relocator to change the angle...cheaper and easier.
Originally Posted by Reprobate
Familiar. My stock response: "Most people die in bed. So, where do you sleep?"
Mr_Snips is offline   Reply With Quote
Old 05-18-2013, 08:41 PM   #5
fridgyis OP
Fridgy
Oddometer: 50
Side stand shortening
Hey,,
I never thought of doing that! What a great idea! Oh the power of the forum always amazes me!
Old 05-18-2013, 09:20 PM   #6
Mr_Snips
Husky BRAAAAAAAAP!
Mr_Snips's Avatar
Oddometer: 352
I can't claim the idea. I got it from another inmate on here. Just passin it along
Old 05-19-2013, 10:46 PM   #7
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,097
Could you enlighten me?
Do you have a photo? Don't you need to unscrew these bolts to remove the adjusting washers and remount the screws? Isn't that more difficult from Pabiker's solution?
Cheers
Old 05-20-2013, 08:32 AM   #8
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,855
Cheers
The way Mr Snips is talking, it becomes a non-adjustable shorter sidestand and just leans more when on the 21/18 wheels.
07 Yamaha R6
07 KTM 950 Super Enduro
04 KTM 250exc- plated two-stroke
01 Kawasaki KE100
74 Honda MR50
brents347 is offline   Reply With Quote
Old 05-20-2013, 01:02 PM   #9
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,097
I see, thanks for the explanation.
So instead of cutting the sidestand, he repositions it, making it shorter to serve both wheel configurations.
Cheers.
Times are GMT -7.   It's 10:41 AM.
