Old 05-19-2013, 05:20 AM   #1
Two Brothers OP
Tire Guru
Two Brothers's Avatar
Oddometer: 322
Lowering the 650GS
Hey guys can I get any help or advice on lowering 650GS. I have a short wife and daughter. Thanks in advance for any advice.
Two Brothers is offline   Reply With Quote
Old 05-19-2013, 06:01 AM   #2
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,769
get lowered suspension kit from hyperpro front and back costs about 250
Loutre is offline   Reply With Quote
Old 05-19-2013, 06:59 AM   #3
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,470
The only difference between the F650GS standard height vs low height is the rear shock. They come up used all the time in the FM for +/- $200.
For a more spendy option (but a much improved ride), Ohilns makes a F650GS low height rear shock too.
For the front forks, you have a few options. Factory, the front forks are raised in the triple tree 1/8-1/4 inch. I've raised mine as much as 1 inch. I've since lowered them back up to flush with the triple tree. Hyperpro makes lowered front springs which are progressive spring rate. I believe the real bang for your buck will the adding Gold Valve intimidators.
BlastOff Adventures
Nothing (ad)ventured, Nothing Gained
Everything you want is on the other side of fear.
Dorito is offline   Reply With Quote
Old 05-19-2013, 07:01 AM   #4
bmwroadsterca
RadioFlyer
Oddometer: 166
Sidestand too
When you put on a low rear shock you also need to put on the shorter sidestand.
Both can be DIY if you are comfortable doing things mechanical.
mike
bmwroadsterca is offline   Reply With Quote
Old 05-19-2013, 07:47 AM   #5
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,254
.....and the centre stand will be too long.
Just a thought, you are aware of the "low" seat option right?
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is offline   Reply With Quote
Old 05-19-2013, 08:11 AM   #6
bmwroadsterca
RadioFlyer
Oddometer: 166
Centrestand not necessarily too long
My wife's bike is a lowered F650GS and I added the center stand after doing some research on the net. The bike goes up easily enough on the stand. The only tricky part is getting your foot in the right place as the stand wants to spring back up when you lower it down to access the foot pad. Have yet to drag the stand.
mike
Old 05-19-2013, 11:10 AM   #7
mustardfj40
mustardfj40's Avatar
Oddometer: 197
I have the standard F650GS center stand on my factory lower F650GS and was able drag the stand...
mike
mustardfj40 is offline   Reply With Quote
Old 05-19-2013, 11:22 AM   #8
bmwroadsterca
RadioFlyer
Oddometer: 166
Stand drag
Congrats!
mike
Old 05-20-2013, 12:23 PM   #9
Two Brothers OP
Tire Guru
Oddometer: 322
Thanks I hope to not have to lower much. I might be able to drop the forks in the trees we will just have to see.
Old 05-20-2013, 09:24 PM   #10
Eldon
950 ADV
Eldon's Avatar
Oddometer: 518
PM sent about lowering. My father just bought a lowered 2010 GS650 and would like to rise her back up to stock height. Let me know if you want to swap any parts.
PS it has the lowered seat too
05 KTM 950 ADV Black (FOR SALE)
06 YZ250 Smoker
Eldon is offline   Reply With Quote
Old 06-03-2013, 07:14 PM   #11
Two Brothers OP
Tire Guru
Oddometer: 322
Hey guys thanks for all the replies. Looks like I won't have to lower them much. I think I can drop the forks in the trees about 3/4 of an inch and be good on both. Ride safe guys.
Times are GMT -7.   It's 05:06 PM.
