Old 05-19-2013, 05:00 PM   #1
Racer111v OP
Racer111v's Avatar
Oddometer: 860
Stalling while idling nicely
My new to me 2004 950 will just stall while idling at a stop sign. While sitting at a stop light at about 1500 in neutral it will just shut off. If I just hit the starter button it will start right up like nothing happened. Sometimes it stall again after a few seconds, other times it will sit there and run for a few more minutes with out incident. I made sure my left foot was off the pegs.Any ideas?
2004 KTM 950 ADV ...............................1979 Suzuki RM400 VMX Race bike
2006 DR-Z400E plated........................... 2001 Ducati ST2 944
2001 YZ250N 2T plated.......................... 1986 Yamaha FJ1200
Racer111v is offline   Reply With Quote
Old 05-19-2013, 05:14 PM   #2
DrKayak
Retro Rider
Oddometer: 796
Sounds like the same behavior I have seen with my 950. Other threads suggested its a carb/fuel starvation issue and running the bike harder and more often will eliminate it. This strategy worked me. I have been riding it more than last year and have only had one random stall this year. I also have been adding fuel stabilizer every fill up as my 950 is not my daily rider.
Either way, I just consider it an annoyance not a major issue that needs fixed... Guess if I was due for a valve clearance check I would clean the carb while I had it off the bike. That should eliminate the issue.
DrKayak screwed with this post 05-19-2013 at 05:22 PM
DrKayak is offline   Reply With Quote
Old 05-19-2013, 05:15 PM   #3
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 957
check the choke cable.
stuck choke will turn the mix richer which under low revs can stall the engine.
690R
Old 05-19-2013, 05:42 PM   #4
wiseblood
Hall Monitor
wiseblood's Avatar
Oddometer: 13,289
I just had that same issue. When I took off the carbs, I saw that one of the intake manifold boots was quite loose. Also, my carbs were pretty out of sync. Once I fixed that up, I haven't had any stalling since.
FYI, this is on a 2007 950 SMR.
"Hard Work Often Pays Off After Time, but Laziness Always Pays Off Now."
Big Apple Tag-o-Rama Maps: Click Here!
wiseblood is offline   Reply With Quote
Old 05-19-2013, 06:22 PM   #5
Shunka
Supervision Required
Shunka's Avatar
Oddometer: 4,292
I had a torn gasket that was causing this after a valve adjustment. Worth checking out.
Shunka is offline   Reply With Quote
Old 05-19-2013, 06:33 PM   #6
Racer111v OP
Racer111v's Avatar
Oddometer: 860
Which gasket?
Old 05-19-2013, 07:29 PM   #7
mcmann
Motorcycle Maniac
mcmann's Avatar
Oddometer: 2,034
Have you checked the valves lately? Maybe a valve is too tight?
Vee2 "The Train", Wee2 "Muliti-Tool"
NC7X "Commuter Xtraordinaire"
mcmann is offline   Reply With Quote
Old 05-20-2013, 12:46 PM   #8
Shunka
Shunka's Avatar
Oddometer: 4,292
Not sure I didn't ask. It was found by 3 brothers in Costa Mesa when they were doing some other work for me, I just assumed it was a cylinder head gasket.
Times are GMT -7.   It's 06:19 AM.
